Old 04-26-2006, 08:41 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Need to find adaptor to go from this outlet on my generator to shore power line in AS
Want to go directly from the 30A fused outlet to the right on the generator panel to the shore power cord. Does anyone make such an adapter?
wacnstac is offline   Reply With Quote
Old 04-26-2006, 08:44 PM   #2
Images: 43
Here's the picture:
http://www.airforums.com/photo...atid=newimages
Old 04-26-2006, 08:52 PM   #3
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
I made a jumper for a similar situation- at my home, when the power goes out, I have an extension cord onto which I installed a male end for the generator, and another male end for the outlet at the house. Seems you could buy the required ends as well as a legnth of extension cord from Lowe's or similar place, and make one for your needs. Just make sure to get your polarity correct.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 04-26-2006, 08:54 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
I can't tell what the plug geometry is in your photo. Maybe you can draw it. There are loads of adapters out there. You just need the right one. I can check with my suppliers if I know what I'm looking for .
Old 04-26-2006, 10:29 PM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Looks like an industrial twist-lock 30A connector.
I would get a matching plug from a hardwre store, 1-2ft of 10-3 flexible cable, a 30A RV receptacle, and a metal box to fit it in.
Now you can make an adapter that will receive the 30A power cord in one end, and the pigtail from it will plug into the generator.
You could also cut off the end of a 30A RV extension cord, and install the twist lock plug on it, but that's expensive...RV extension cords are over $ 50.00 for the decent ones.
Uwe
www.area63productions.com
Old 04-27-2006, 06:55 AM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Home Depot or Lowes has everything you need. I built one for my 7500 watt Generac, which came with the plugs. I just bought the #10 cord, box and RV 30 Amp weather proof outlet. The HD here in Gainesville, has a generator section with all the plugs and generator goodies.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-27-2006, 07:19 AM   #7
Images: 59
It doesn't have 240v capability, so you could take out the L5-30R receptacle and replace it with a RV TT-30 receptacle. Might need to make the hole larger, and check that the plug would clear the case.
I wouldn't do it until the warranty runs out.
Old 04-27-2006, 08:22 AM   #8
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Your best bet is to build one. All the parts are available from a commerical electrical supplier or your can try lowes or home depot.
are you handy?
Michelle TAC MT-0
Sarah, Snowball
Old 04-27-2006, 08:46 AM   #9
Images: 43
I'm handy but I would have thought an RV dealer would have an adapter to go from one to the other. Seems like it would be a pretty common problem.
Old 04-27-2006, 11:04 AM   #10
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
This is scary--maybe I'm too nervous about these kinds of things. At my house, I separately power one circuit with the fridge(s) and one light. I cut that circuit just after the circuit breaker and install a relay that is energized from the generator. This prevents any potential mix of shore and generator power (could be catastrophic due to out-of-phase conflict when shore power comes back on) and eliminates the obvious danger of having a male connector that can be energized if you plug the generator in first (or unplug the house side first).
With this setup, whenever the generator is plugged in and on, the circuit is powered from the generator. Power sources are never cross-connected. No exposed male plugs ever have power on them.
You could install several relays to power as many circuits as you wanted and the generator could support.
Old 04-27-2006, 11:17 AM   #11
Images: 59
If I can add to Roger's comments, the power company doesn't like you to do that either. It can energize the power lines outside and give a jolt to the lineman that's trying to repair the lines.
I know everyone turns off the main breaker to prevent that. But someone else will see you do it , and try it themselves without remembering to turn it off.
Old 04-27-2006, 11:49 AM   #12
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
They make failsafe transfer switches for situations like these. They are not expensive. I have one at my house, for fridge, a few lights, tv and water well pump, off the Generac 7500. I also made a plug up to run my EU2000i into the transfer switch, so I can just power fridge, tv, Directv receiver and kitchen lights during the day, and during sleeping hours.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 04:39 PM
New power Convertor HOT! silverbullet Electrical - Systems, Generators, Batteries & Solar 4 09-24-2002 10:01 AM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 01:14 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
How to find the VIN#? Action Title, VIN & Registration 7 04-19-2002 11:15 AM
