Old 08-23-2010, 05:34 PM   #1
1986 25' Sovereign
Greenwood , South Carolina
Question Need Solar Assistance
Good Evening everyone!!!!
I am in need of some help & don't know where to even start looking. Have an 86 Soverign (sp) that has solar panels on the roof of the Airstream. Went camping a couple of weeks ago & now the airstream is parked in the backyard. Went out to airstream yesterday & the solar panels are not working. Batteries are dead. I am guessing the batteries killed the panels???? Had a severe thunderstorn on Saturday, but sun was shining bright as could be on Sunday. Does anyone have any ideas of what might could have happened or what I need to do to repair them?
Please advise
Thank you so much for any help anyone can give me
Success101 is offline   Reply With Quote
Old 08-23-2010, 06:53 PM   #2
2008 23' International CCD
Denver , Colorado
Hmmm....if it were me, I'd look at the inline fuse first. Should be between the charge controller and the battery, I'd guess.
Then check the solar's charge controller. Is it working (lights on?).
If it's working, then start looking at wires. Maybe hail knocked out the connection at the solar panel? But given the "severe thunderstorm" I'd bet the fuse got popped.
Good luck
Jim and Marsha
"Tow'd Hall"
AIR #35886
JimmyT is offline   Reply With Quote
Old 08-23-2010, 08:23 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I would vote for the fuse.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 08-23-2010, 08:46 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
First: check the output voltage at the panels and see what they are giving you for when exposed to direct sunlight
Second: trace the wires from the roof and locate the charge controller (hopefully, you have one). Check the input and output voltages to verify that the controller is functioning properly.
Third, find the wires at the batteries and see if the output voltage from the controller matches the charging voltage present at the batteries. If there is no voltage from the controller, you probably have a fuse/circuit breaker that is tripped and not allowing the controller's output voltage to reach the batteries. Another possibility is an interruption in the circuit like a bad wire or corroded connection.
This will allow you to trace the voltage path and locate the problem.
Old 08-24-2010, 06:42 PM   #5
1986 25' Sovereign
Thank you so very much for the help. I will check them out!
Again, many thanks to each of you!
Carole
Roadside Assistance judybug On The Road... 17 04-03-2010 07:18 AM
I need some assistance with this one classygal Off Topic Forum 17 08-08-2008 06:27 PM
Help me please! Computer assistance steelbird312 Off Topic Forum 7 12-21-2006 10:13 AM
Assistance please SCBrat Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-27-2003 11:18 AM
