Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 12-30-2008, 09:17 AM   #43
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
No Comment on C/S
Honda 2000
I can't comment on their customer service, my only phone call was when I ordered the kit. The carb was returned promptly after modification.
The conversion has worked flawlessly for 170hrs. Switching from LPG is easy, no exhaust fumes, lower exhaust temps. The only gas I carry now is in the Honda's tank, it's sealed very well and I have not had any fumes whether in the TV or coach. ( We carry the Honda in a 22gal Rubbermaid Action Packer)
Name:	HONDA CONVERSION add vid pix2-3 006.jpg
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 11-08-2009, 04:02 AM   #44
Profile:  2007 25' International CCD
Spring , Texas
Yamaha 3000iseb
I bought a yamaha 3000iseb and chose not to go with the propane conversion due to if yamaha was not making it as a propane unit then they must have had a good reason for it, since so many people are looking for that feature. Also, I did not like the way the regulator is mounted to the outside of the gen, but mainly my reason was that I felt that the people at yamaha designed the generator to run on gasoline and not for an aftermarket company to convert just the carb to propane and not take the rest of the gen into account.
Ken Michael is offline   Reply With Quote
Old 11-08-2009, 09:30 AM   #45
just jd.
5cats's Avatar
Profile:  2007 20' Safari SE
San Diego , California
Since Yamaha maintains their original factory warranty on these propane-converted units, perhaps they know a little more about the matter and they're ok for this "aftermarket company to convert just the carb to propane and not take the rest of the gen into account".
Rather than some fundamental incompatibility issue in the post-carburetor engine mechanics as you seem to imply -- or even more unlikely the electrical generation components (!) -- it's more likely Yamaha hadn't come out with a propane option themselves because
  • it's a relatively niche market;
  • would substantially increase the already-premium-priced bottom line to the customer;
  • plus, as you already noted, the large pancake regulator has to be packaged somewhere, and it just ain't all that sexy from a marketing perspective.
It's ok if you don't want to have the tri-fuel conversion, your post just comes off a bit like a wet blanket to those of us who have it and are very pleased with the results (and continued Yamaha support).
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 // xxxx
5cats is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 11:34 AM
Flying J Propane Question Pick On The Road... 5 10-26-2002 06:46 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 02:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 04:54 AM
Propane valve leak Dbraw LP Gas, Piping, Tanks & Regulators 3 06-14-2002 07:12 PM
