Old 07-30-2014, 08:29 PM   #1
2016 30' Classic
Erie , Colorado
My AMSolar install
Second week of July I headed out from Denver to have AMSolar do an install on my 2014 FC 25 rear bed.
Install was estimated at 3 days. Got to the office at 8am and met Roger. We did paper work waiting for the Install Manager to get in. Turns out that Marvin Braun of PrecisionRV is running the shop this summer for AMSolar. I had previously talked with Roger on the phone and email and with Marvin's concurrence decided to put in the Blue Sky 3024iL controller and IPN Pro Remote.
For an inverter there is a new model from Magnum. The MSH3012M Hybrid is a 3000 watt inverter that can work in conjunction with AC power, either line or generator. What makes this unique is that it will use the available amperage from the AC line and supplement it with a draw from the batteries to supply power to the trailer. So I can run the A/C system with a Honda 2000i and the inverter will determine how much power is needed from the batteries to supplement the available 15-1600 watts of power are coming from the generator. Made a lot sense for not much delta in price.
When you get to the AMSolar shop the waiting room has a 'sales wall'.
Basically 3 sections. Right side for Charge Controllers,
Name:	Solar Controllers.jpg
Center section for remote heads.
And the left side for inverters.
Waiting room has a large library of RV related books and Oregon travel information.
Upstairs there is a sliding window where you can look out over the shop floor. Good spot to see what is happening on the top of your rig. Note the electric lift. Makes it much easier for the crew to get stuff to the roof and reduces the amount of time they need to spend walking on the roof.
My roof space allowed for 3 - 135w panels and 3 - 100w panels. The Winegard antenna takes up a lot of space. (Note that the 2015 AS coming out now use a Winegard Omni Digital antenna which is a round disk taking up much less space. Might check into getting the Sensar removed and replaced if I ever need another panel). Behind my rig is a Class A that was getting something like 1400w of panels installed.
Here's some photos of the install. Basically the first section of the roadside couch was pulled out. Magnum and breaker box installed in the forward area of the outside storage bin. Back wall of the storage area has the Blue Sky mounted. 2 of the 220ah 6V Lifelines went in the original battery box and the other 2 now fill the inside storage area under that front section of the bench seat. I still have external storage space between the two new pieces of equipment.
Seat section removed, front roadside. Breaker box and Inverter.
Name:	Inverter and Breaker Box.jpg
Magnum Hybrid Inverter
Name:	Inverter Instal.jpg
Inside the storage area. Magnum
Blue Sky in storage area back wall with Solar Panel on/off/breaker
Name:	Blue Sky 3024i.jpg
Not shown is a SurgeGuard 30amp surge protector that also has a remote.
Wednesday afternoon the crew was done and late afternoon I did the walk through with Marvin. Lot of information was shared. If you have read the manuals in advance it helps a lot to make the walk through more relevant. You will understand more of the knowledge that is being shared.
System has been fantastic. I'm seeing high 30ah, sometimes 40ah in full sunlight. Easy to switch the refrigerator to AC during they daytime after the batteries come up on charge (pulls about 27ah) and still adding power to the rest of the system. Tested the A/C and it drawing about 160ah. Running the Honda 2000i and setting the Magnum at a conservative 10a supply setting from the generator that gives me 80ah of generator power and drops the battery draw to 80ah. If the panels are adding 37ah then net loss to the batteries is a more reasonable 50ah.
Basically with the Magnum Hybrids you have a lot of options.
Great install, wonderful folks, got to meet Lew who came into the office one morning, Greg and Deb were in and out and Marvin who is a wealth of knowledge. And everyone else on their team that worked on my install.
All in all a first class experience.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-30-2014, 08:43 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thx for update!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-31-2014, 07:34 PM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Gary, thanks for the post. I ordered all my solar from AM last year (with some PM help from Lew). I installed 4 of the 100 watt panels, Blue Sky Controller, etc., and 2 Lifeline AGM's. I was really impressed with AM's terrific packaging, comprehensive instructions, etc. AND, more importantly, have been enjoying the advantages of solar in my trailer. Very interesting to see that the quality shows up when you're right there at their place!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-31-2014, 08:41 PM   #4
2005 28' Classic
Westfield , Indiana
Gary,
Did you install 220 or 300 AH batteries?
lem2582 is offline   Reply With Quote
Old 07-31-2014, 08:54 PM   #5
2016 30' Classic
Erie , Colorado
I did 220's since they fit with minimal adjustment in the front battery compartment and fit perfectly in the couch storage compartment. Challenge if I wanted to add a couple more is they would need to be on the roadside close to the other two batteries. I'll try this setup for awhile and see if I need to adjust anything.
Gary
2015 Classic
ProPride
NVPN
Old 07-31-2014, 09:11 PM   #6
2005 28' Classic
Westfield , Indiana
Thanks Gary! I am considering 300 AH but I am concerned about space and weight. More to noodle?!?! :}
Old 07-31-2014, 11:08 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
Don't forget that the GPL-6CT 300 amp/hour 6VDC golf cart batteries (or any other Lifelines) can be placed in any position except upside down for your installations. The orientation makes absolutely no difference in performance or safety.
Old 08-15-2014, 10:45 AM   #8
interstateflyer's Avatar
2017 25' International
Los Osos , California
We visited AM last Summer and were very impressed with their operation. They are doing an install on our 23D in September.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 08-15-2014, 11:28 AM   #9
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
23 Footer Solar Install
Would be interested in seeing detailed photos of your install. Seriously considering an upgrade to the factory solar install that I currently have. Been watching the solar threads and conversing with Lewster on getting it done. Thanks
tsunami is offline   Reply With Quote
Old 08-15-2014, 11:41 AM   #10
Dave at AM Solar did an install on a 2012 23D. They put two GS-100, 100 watt panels lengthwise behind the AC and one GS-135 crosswise in front of the AC.
Old 08-16-2014, 10:21 AM   #11
daveswenson's Avatar
Issaquah , Washington
Would it be rude to ask what AM Solar charged you for the installation?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-16-2014, 10:37 AM   #12
My AMSolar install
Not sure. It wasn't my trailer.
Btw....the 135 was lengthwise on the road side.
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Brake install -INSTALLATION/ADJUSTMENT/WIRING Sharon Lee Brakes & Brake Controllers 10 07-21-2002 07:47 PM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
