mount generator on a frame?
This is my idea, please fault it or otherwise.
I have chosen (right or wrong, its too late now) a Yamaha 2400is).
My suggestion is to fix a 2" tow receiver, 90 degrees to the A frame,l about 4-5 " behind the propane tank box. From that tow hitch receiver I intend to fit a small cargo carrier, sufficient for the generator size and then padlock it on.
Will the off center position (estimated weight of 100lbs) be a problem?
Can you forsee any other issues?
1983 Airstream Excella Tri axle 34 feet. Tow vehicle; Hummer H2
Advice sought,
