Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 10-14-2006, 10:45 AM   #1
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
LPG for Honda EU2000
I am looking at going to a pair of Honda EU2000's for the AS. Are these convertable to run on LP, and is it the thing to do or not? If it is feasible, what is involved and what does it cost?
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 10-14-2006, 10:49 AM   #2
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
Hey moose,
If you do a search on propane conversions you will find a ton on this. Im pretty sure you can get conversion kits for both Honda and Yamaha generators and that people are pretty positive about it. I think if I get a gen I will be doing a conversion. Maybe add a propane connection at the back of the trailer for the hookup?
Rodney
Experience hath shewn, that even under the best forms of government those entrusted with power have, in time, and by slow operations, perverted it into tyranny. - Thomas Jefferson
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 10-14-2006, 10:55 AM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
You may want to check out these web sites:
http://www.propane-generators.com/
http://www.propanecarbs.com/
Richard
Charter Member Four Corners Unit
Old 10-14-2006, 11:04 AM   #4
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Moosetags, I have an EU2000i that I did the conversion on myself. I am very happy with the result. I got my kit from propane-generators.com. The only conversion for the EU2000i is the kit that makes it LPG only. If you wanted to go back to gas, you would have to buy a new carb, as you have to drill the old one out for the new jet.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-14-2006, 11:38 AM   #5
Tim A.
Profile:  2002 19' Bambi
Lafayette , California
I also have converted a Honda generator (an EU2000i) to propane, also using a kit from US Carburetion (http://www.propane-generators.com/). The generator works great. The conversion is for low-pressure gas and, using parts from US Carburetion, I have a quick disconnnect for the low-pressure (after the regulator) supply to the trailer. It was possible to put all of the conversion stuff inside the generator by cutting out part of the gas tank and using that for a mounting bracket. Attached is a picture.
Name:	Honda 2000 - Tim A.jpg
Tim A. is offline   Reply With Quote
Old 10-14-2006, 12:16 PM   #6
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
I am going to return the propane conversion kit I purchased from USCarb for my Yamaha and exchange it for the Honda kit. Your conversion sure looks sweet. Could you provide more details? I'd like to do the same thing. Did you drill out the jet in the carb? It looks like the propane connection is now a QD under the gas cap.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 10-14-2006, 02:04 PM   #7
moosetags
moosetags's Avatar
A big thanx to everyone. The information that you have provided is very helpful.
Old 10-14-2006, 03:38 PM   #8
bhayden
bhayden's Avatar
Profile:  1978 24' Argosy 24
Woodinville , Washington
A friend recently bought an EU2000. He was told by the dealer that propane conversion would void the warrantee. If it's true that the Honda can't be set up to swtich from gasoline to propane that might be enough to sway my decision toward the Yamaha 2400. The little extra power with the Yamaha is nice but it's a good 20# heavier. I can't think right off hand why I'd want to run on gasoline if I had the propane option but I've been told that the total power available drops slightly with the switch to propane.
-Bernie
bhayden is offline   Reply With Quote
Old 10-14-2006, 05:07 PM   #9
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
I don't know about that power drop. I have a 14kW (47amp) whole house generator - propane powered. It's spec sheet gives a higher rating for propane over natural gas and regular gasoline (DON't ASK ME WHY????). The dealer I bought from stated that he could not understand why anyone would buy a generator to run off gasoline. Especially the small portable ones that rarely get the usage and have fuel get old in the tanks. BTW - on the MS coast post Katrina, the Honda dealers are doing record business on the Honda 2000 and 1000 models with the propane kits installed from the factory.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 10-14-2006, 08:17 PM   #10
bhayden
bhayden's Avatar
I guess the only reason for wanting to be able to use gas would be if you were in a situation where you didn't want to drag allong a propane bottle & hose. Of course if you have to drap allong a gas can then I'd rather pack the propane. Any guess how long a Honda would run at say half load with one of the disposable bottles? For that matter, what's the standard attachment thread, if there is one for the propane conversion. I'd hate to have yet another stinking adapter hose to carry around.
Old 08-28-2008, 08:43 AM   #11
bredlo
bredlo's Avatar
Profile:  1962 19' Globetrotter
Evanston , Illinois
Images: 20
Thinking about getting one of these and converting it for LPG. I'm surprised in my Googling that I'm not finding pre-converted models, but I suppose if that voids warranties it makes sense.
Found a dealer locally (30 minutes away in Schaumburg, IL) selling them today for $859. Not bad, huh?
Brad Abridged
bredlo is offline   Reply With Quote
Old 08-28-2008, 10:35 AM   #12
byamcaravanner
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
Good plan - good price.
Pair this with a good battery set-up and you should be able to pull up and camp just about anywhere. I'll meet you in the Brat Stop parking lot.
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 08-28-2008, 10:47 AM   #13
utee94
Profile:  1963 26' Overlander
Brat Stop?
Tell me more of this intriguing place...?
Old 08-28-2008, 04:52 PM   #14
byamcaravanner
Originally Posted by utee94 View Post
Brat Stop?
The Brat Stop is an infamous restaurant/entertainment venue/cheesemart in Kenosha, WI approximately half way between Chicago and Milwaukee.
They feature Epicurean entrées like the "Egg Von Brat" and top line entertainment like the John Mellencamp tribute band "Mellencougar" and punk band "Pistofficer"
It will be a must stop on your trip to the '09 International.
Steve & the crew
Horizontal LPG Bottles on "Limited" models Dwight LP Gas, Piping, Tanks & Regulators 15 05-31-2005 07:18 PM
lpg regulators gjohnson Parts Archive 2 06-17-2003 10:26 PM
What you wanted to know about LPG and more femuse LP Gas, Piping, Tanks & Regulators 0 04-24-2003 10:12 AM
LPG or propane in the bottles ? brunoffrance LP Gas, Piping, Tanks & Regulators 3 12-17-2002 03:18 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
