Old 11-26-2015, 06:43 PM   #15
Gainesville , Florida
There are two models of Honda 3000 gens. One is much quieter than a 2000 , the other louder.
Old 11-26-2015, 06:52 PM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by AnnArborBob View Post
Yes, running two H2000's together is noisier than running one (based on personal observations.) I don't know the actual impact on dB.
Twice as loud, which means 3dB higher.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-26-2015, 07:42 PM   #17
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
Yes the Honda is 59 at full load and 53 at 1/4 load
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 11-26-2015, 07:46 PM   #18
1977 Argosy 28
Irrigon , Oregon
Originally Posted by Argosy 7728 View Post
Yea I know it's louder 65db vs Honda 2000 - 59db. I am looking at it as a home backup and occasional boondocking.
Nowhere in this statement did I suggest using it in a campgound
Rod
AIR# 60278
Old 11-26-2015, 07:50 PM   #19
1977 Argosy 28
Irrigon , Oregon
Thanks to everyone that gave me constructive input.
Rod
AIR# 60278
Old 11-26-2015, 11:42 PM   #20
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I had the unusual opportunity to hear a Honda 3000 today followed by a Honda 2000 a few sites down the way (for my first real life "side by side" comparison) and the 3000 was definitely noisier than the single 2000. But nowhere near as obnoxious as a contractor generator.
As others noted, there are 2 Honda 3000s. The lighter, more expensive "Handi" is louder than the full-sized EU3000iS, which is why I said the full-sized one is quieter than a 2k.
David
Old 11-27-2015, 08:32 AM   #21
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
We have a Yamaha ei2000 that has been modified to run on LP, Nat Gas or gasoline and we hook it up to the auxiliary LP port on the Airstream at the front of the trailer. We never run out of propane!
Is the auxiliary port downstream from the propane tank regulator? That would mean two regulators, one on the trailer and one on the generator. Did you remove the regulator from the generator?
Kelvin
Old 11-27-2015, 10:02 AM   #22
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Kelvin
There is a part on the side of the converted generator that sort of looks like a regulator and I'm not really sure what it is, I suspect it's some kind of "LP carburetor" that serves to mix the LP and air. The LP feed for the generator is connected downstream from the stock LP regulator on the Airstream and the whole setup works just fine. The generator did ship with a separate regulator to be used when hooking up directly to a standard propane cylinder (which I do to use then hooked up to the AS) so I am assuming that it is designed to work after the regulator.
Bob Martel
WBCCI# 5766
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
1998-1999-2000 Excella Generator fphil Airstream Motorhome Forums 0 07-01-2002 09:34 PM
