Old 01-17-2016, 04:57 AM   #15
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Pics and specs
Sure, SteveSueMac...
When loaded for travel the two Honda's ride on a plywood platform on wheels along with up to 2 20pound LP tanks at the front of the truck bed under the tonneau. Here's a pic (I chain and lock them in and have covers when they are not posing for pics):
To run the generators I roll them, platform and all to the tailgate and fire them up. In the rain I open the tailgate but leave them under the rear panel of the tonneau. The exhausts on the generators face rear to enable that mode of operation.
Here they are on the ground during a test. You can see the tee sitting across the top of the generators. The red 3/8" feed hoses came with the kits. The black hose is a stock Camco item connected to the trailer and the tee. The black wires are the Honda parallel kit. There is a 30 amp twist lock to 30 amp rv plug adapter in the companion unit and my standard furion 30 amp umbilical plugged into that:
Here's a close up of the Camco lp house and the tee:
I have a post somewhere in a prior thread with specifics on the tee. Let me know if you need anything that detailed
To all: Apologies for hijacking this thread!
GammaDog is offline   Reply With Quote
Old 01-18-2016, 09:50 PM   #16
baterup's Avatar
2016 27' Flying Cloud
Palmdale , California
Quick question to the group, How much LP does a unit use?
baterup is offline   Reply With Quote
Old 01-18-2016, 10:09 PM   #17
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Does anyone know if a conversion kit is available for a Honda EU3000iK. I think this is Also called the Honda handi or something like that
Thanks for any input
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 01-19-2016, 12:04 AM   #18
2016 23' International
Salem , Oregon
Check with uscarb.com. If they don't list a kit call them. Very helpful.
Dave
NoResults is offline   Reply With Quote
Old 01-19-2016, 07:14 AM   #19
Arcticfox's Avatar
Central , Canada
Thanks Dave - I will try to give them a call.
Old 01-19-2016, 07:24 AM   #20
GammaDog's Avatar
Images: 26
To baterup: I've done a rudimentary test of LP use. I ran both of my Honda 2000s with a load (I plugged a hair dryer into each at full heat) for one hour with the Eco throttles set to "off". I weighed each LP tank before and after with a bathroom scale. Within the accuracy of the scale, each generator burned 2 lbs of LP per hour.
Conclusions: 1. Gasoline is cheaper per hour than propane. 2. If both of my 30 lb LP tanks were full and no other LP loads were on ( furnace, water heater, fridge, stove) I could run AC for 30 straight hours, charge batteries for 60+ hours (running just one generator) on LP.
Solar panels vs portable generators ashe Electrical - Systems, Generators, Batteries & Solar 19 01-19-2015 07:18 AM
Portable Generators GeneratorGuy Commercial Listings 21 12-04-2007 02:42 PM
Portable electric generators,Q. on quality Ed Keyes Generators & Solar Power 18 10-16-2006 08:12 PM
portable generators kstampa Generators & Solar Power 59 03-07-2006 05:55 AM
