Old 05-13-2010, 01:25 PM   #1
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
Love my new solar package
I've had my new AS for 4 weeks now.
When I ordered it last Fall my dealer recommended putting in his own equipment rather than ordering the factory solar option. I took his advice and I'm loving it. There's such a freedom not to mention the whole green satisfaction thing about relying on oneself for most of one's energy needs.
He put two panels on the roof and a 1500w inverter. He removed the two batteries that came with the AS (can you say great front storage compartment!) and placed 4 group 27 Lifelines under the dinette seat (closer to the rear axles).
For me the great convenience is how they wired it. I have a remote inverter switch which when activated; automatically switches from the shore power inlet to the inverter; so that the whole RV has access to 110v; not just one or two outlets. It works really well.
See everyone on the road!!
ID:	102442   Click image for larger version
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is offline   Reply With Quote
Old 05-28-2010, 01:39 PM   #2
Newport Beach , California
Get that thing going downhill and your little Merc might just get ejected from the highway ! And I thought I was pushing the envelope with my choice of TV !!!
RognChris is offline   Reply With Quote
Old 05-28-2010, 04:39 PM   #3
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
I have no complaints with the factory solar on our trailer but I like the idea of switching over all the outlets to the inverter. Nice mod. I guess if your using AGM batteries they would be OK in the trailer but we value our under dinette seat storage and use it all. I wonder about the change in trailer weight distribution. Maybe less tongue weight and moving the weight of four batteries over the axles makes it easier for the ML320 to handle it.
-Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 05-28-2010, 05:32 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
[QUOTE=Rawn77;849020]I've had my new AS for 4 weeks now.
Hi Ron,
Enjoy that 'free' power!
Just a few cautions: if your entire trailer (all existing circuits in your breaker box) are indeed able to run from your inverter, your dealer probably installed a generator priority transfer switch with the inverter connected to where a gen usually goes. This will give you solar power, even if connected to shore power as the transfer switch uses the generator (now solar) as the priority whenever it is present.
Thee are 2 problems with this type of connection:
1. Your refrigerator will seek 120VAC if left on 'auto' and the heating element will run drain your Lifelines rather quickly.
2. Your air conditioner is also able to power up, although a 1500 watt inverter will overload if you try and probably burn out the inverter and the compressor.
So the moral of this PUBLIC SERVICE ANNOUNCEMENT is: BE SURE TO USE THE FRIDGE ON LP ONLY IF USING THE INVERTER AND NEVER TURN ON THE A/C, EVEN FOR A SECOND.
ENJOY!
Old 05-28-2010, 07:15 PM   #5
Rawn77's Avatar
Montreal , Quebec
My poor TV
Lewster: Your right about the connection. And yes, I do make sure about the fridge and AC/Heat Pump switches. I've had no probs so far.
As far as RogNChris & Silverback, my little Merc (Diesel) tows amazing! Just drove 450 miles today; never losing a single mph even up long grades on the highway. Set the cruise at 68 and got 14.7 mpg. I can't tell you how many 1/2 tons I passed pulling much smaller TTs with only this look on their face
Be well everybody!
Keep on streamin.......
Ron
Montreal, QC
2017 Classic
Honda EU3000
Hensley
Old 05-29-2010, 12:13 PM   #6
Be well everybody!
How much does that trailer weigh ready to hit the road after all the upgrades ? Your Merc is only rated to tow 7200 lbs, extra batterys, solar panels, inverters and satellite equipment aren't exactly lightweight additions to the trailer.
That look on peoples faces is for good reason, if you're actually towing that rig 68mph you better get used to being pulled over and cited for excessive speed.
Going uphill is never the problem, it's downhill where it gets a tad dodgy.
Old 05-29-2010, 04:48 PM   #7
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
I think those dealers in Canada will hook any tow vehicle to any Airstream!!
SafariSS is offline   Reply With Quote
Old 05-29-2010, 05:34 PM   #8
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Can you add more pics, batteries under the dinette seat for example?
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Value of Airstream Solar Package? Craftsman Generators & Solar Power 51 02-23-2018 06:53 AM
Will truck I love pull the A/S I Love? Pudentane Full-Timing 55 07-28-2008 04:53 AM
Boondocker Solar Package flyrodder Generators & Solar Power 9 12-21-2004 02:54 PM
Help (hopefully!) with the solar package :confused: CaliforniaStreamin Generators & Solar Power 4 12-10-2004 08:22 PM
Boon Docker Solar Package? joshua32064 Generators & Solar Power 47 03-10-2004 08:31 PM
