Old 04-17-2006, 07:51 PM   #1
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
Looking to buy a generator but,
I need to buy a generator,But what size? All i want it for is to run the air cond if i have to(must be real hot that day)And to recharger battiers.Everything else run off the battiers. Can anyone help with this
Angel73 is offline   Reply With Quote
Old 04-17-2006, 08:02 PM   #2
bill benton's Avatar
Mansfield , Texas
There are hundreds of posts on generators Just use the search menu at the top.
be prepared to do a lot of reading. There is more here than you would ever want to know. Most would say 3000 to 4000 watts either Honda or Yamaha.These are the two quietest
bill benton is offline   Reply With Quote
Old 04-17-2006, 08:26 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
The new Yamaha is2400 is very capable of running your roof air, is very quiet, is the inverter type which does not run at full speed all the time and is only 65lbs. Plus you can buy it ready-converted to run on propane.....not gasoline..........a real bonus for longevity, safety and maintenance!!!
Old 04-18-2006, 09:25 PM   #4
1999 35' Cutter Diesel Bus w/slide
Hillsboro , Texas
Thumbs up I Have it - ! !
I have an Onan 4000 Original, 450 minutes on it, never mounted in my trailer, I Bought a motor home, and now don't need it. Call me. 254-580-1428
Ed Watkins is offline   Reply With Quote
Old 04-22-2006, 11:08 PM   #5
Angel73's Avatar
1975 31' Sovereign
Images: 65
Are the Onan 4000 Quite.We need one that is.If so let me know how much...plus shipping
Old 04-23-2006, 06:16 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums! If for some reason you and Angel73 don't strike a deal, you can always list your generator here in the forums classified ads.
Old 04-23-2006, 08:58 AM   #7
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
The following is for non-inverter generators!
be careful of one thing. If a generator provides both 120V and 240V, it is probably wired with two windings in serial. This provides the total power output to the 240V plug, but only half power to each of the two 120V recepticles (each of the 120V recepticles is wired from the common connection between the windings and then to either end of the two windings, which means only the power from one winding is available to each recepticle).
So my 3500 Watt generator only delivers 1700 Watts at 120V (each recepticle), which is marginal for an AC that requires 13.5 Amps. I've looked at mine generator and it will be easy to rewire the windings in parallel, but I'd lose the 240V output, which I don't use.
By the way, YOU CAN'T PARALLEL THE OUTPUT OF THE TWO 120V RECEPTICLES without rewiring the windings--THEY ARE 180 DEGREES OUT OF PHASE!
Old 04-23-2006, 03:05 PM   #8
Angel73's Avatar
1975 31' Sovereign
Images: 65
Wow
more work than am in for at this moment.Wouldnt even know where to start on that,Thanks you
MH pre-buy suggestions jkleven Airstream Motorhome Forums 13 03-27-2006 07:21 AM
Questions about the 2003 International. Would you buy again/fair price. Debbie 2002 - 2005 International 29 11-07-2002 04:11 PM
newbie looking to buy Oak All Argosy Trailers 13 10-11-2002 10:17 PM
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
1980 Airstream Land Yacht - Should we buy? cbird01 Airstream Motorhome Forums 0 08-03-2002 09:06 AM
