Old 12-13-2006, 03:54 AM   #1
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
Looking for a generator -
we want to purchase a generator to run small things in the AS, like TV, receiver, laptop, and load the battery.
So I'm looking for a 3000W, just to be comfy, and may be run it home in case of outage,
any advices....
thank you
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 12-13-2006, 04:39 AM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Good morning Dufferin- We ended up by just a 1000W because we just wanted enough for TV if needed and batteries. Something light and very portable since we have a Tahoe it needed to be in the back. We ended up with a Kipor which was a little less than the other two biggies, Honda & Yamaha. Use the search functiopn because I know there has been some extensive discussion on generators.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-13-2006, 04:57 AM   #3
1976 25' Caravanner
Campton , New Hampshire
Dufferin
Just hit the search tab and type in generator , then get a second cup of coffee , lots of good pros and cons . I opted for the Honda 2000 , jumping to the 3000 , tripled the weight if that is a factor . One of the big concerns is if you want to run the AC with it . On my '76 with an 11000 BTU it seems to do just fine without much else on . Others have reported that it will not run the AC . Happy reading and good luck
ticki2 is offline   Reply With Quote
Old 12-13-2006, 06:00 AM   #4
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Selecting Gen. can be an adventure
We may be able to save you some time.
After much wringing of the hands and reading every thread and post on this forum concerning generators; we ordered a Honda 2000 from Mayberry's in NJ.
Why? Primary reasons were 1. wattage vs. physical weight. 2. Honda reputation. 3. If we need more power for the home during ice storms we will add a 2nd unit and run in tandem. 4. I did not want to struggle with the 3000 weight. 5. The 2000 takes care of our non-summer boondocking.
We used ours during Thanksgiving's cooler weather. While running in the economy mode we could not hear the engine noise with the AS's windows closed. Only problem it had was with our old 1,200 watt microwave. It would jump up in high speed and tripped the breaker when trying to make coffee and microwave. I am watching the sales for a 400 to 600 watt microwave.
Hope this helps.
em.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 12-13-2006, 06:26 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Meijers has a 1000 watt Shop Force generator on sale for $99 that will run the TV and computer but an inverter will also do that for a short period of time with no noise. 1000 watts would run your furnace and refrigerator at home in case of power outage. It is powered by an integrated 2 hp two cycle engine and is pretty light.
Old 12-13-2006, 06:42 AM   #6
OpenHigher's Avatar
2006 Safari SE
Los Alamitos , California
Dufferin: I am going to go with Empresley. We have the Honda 2000 and it is a gem, solid, powerful, quiet, does everything it should, except run the AC. We will be out 6 days with no power, running the heater, TV, laptop, etc., and I expect to run the gen two hours a day and keep power nearly charged for those six days. I have been out for five days already, albiet during the summer, and had no power problems on that trip.
Best, Robert
OpenHigher is offline   Reply With Quote
Old 12-13-2006, 06:43 AM   #7
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Honda nothing but Honda.
I own two of them and wish I had another.
I have a 5000 Watt 120/240V for the house. Currently in Storage.
I have a 2000 Watt for the trailer. This one was ejected from the truck during the accident and still work. The case is scratched. I want another one.
You can parallel the EU2000i's.
THe EU3000i is too heavy to lift in and out of the Truck bed. You can lift the EU2000i.
Michelle TAC MT-0
Sarah, Snowball
Old 12-13-2006, 06:55 AM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I tend to agree with most of what's been said here. I too think the Honda's are great, but I would also suggest looking at the Yamaha brand as well. They are equal to Honda in every category.
I wound up going the 1000 watt Yamaha propane powered unit for a number of reasons.
I don't watch much TV when boondocking
I only really need it to top off the batteries after a week or so of heavy DC usage.
It would take me 2 2000s or maybe even more than a 3000 to power my 15k btu a/c unit
Space and size considerations having to have 2 units to run the big stuff like an a/c unit.
Finally, the fact that since I only have enclosed spaces to transport the generator, the Yamaha came pre-installed to run on propane only with the 1000 and if the Yamaha 2000 was desired, it would run on gas or LP if purchased. So far the Honda is a do it yourself type thing if you want it to run on propane.
Old 12-13-2006, 08:14 AM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
how do you guys know how long you need to run your generator to re-charge the battery(s)?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-13-2006, 08:15 AM   #10
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
You may want to check out the new Yamaha 2400is It claims to be able to run an ac unit up to 13,500 btus and you can link two together like the Honda's! This is my pick. I have not tried it yet but I have another 6500w Yamaha that I have had for 14 years and it has been rock solid. I think they have nailed it with this one size weight and performance. I see prices around 1200.00
Phil Gobie is offline   Reply With Quote
Old 12-13-2006, 08:36 AM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
Good points 'twink.
We have a 40# Honda eu2000i and frequently am without hookups at Nat'l Forest campgrounds. There often is nobody at our campsite when we're out fishing or hiking. I don't want to leave a thousand dollar bill just sitting out, so I do lift the Honda up and down from the truck bed usually once a day. Sure wouldn't want anything heavier!
Northern climates and more shaded campsites offer some options to avoid air conditioner use. The only time I used my air conditioner last summer was when we were headed out bicycling (plug-in at campsite). The noise and closed windows allowed us to leave our two dogs quietly inside the Airstream while we were away.
See this thread and my post 9 to understand that these gensets aren't always quiet: http://www.airforums.com/forum...ems-27060.html
5 meter Langford Nahanni
Old 12-13-2006, 08:48 AM   #12
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
Yamaha 2400iS works great
Originally Posted by Phil Gobie
You may want to check out the new Yamaha 2400is It claims to be able to run an ac unit up to 13,500 btus [...]
I can confirm that my 2006 Yamaha 2400iS, tri-fuel adapted and running on propane, barely hiccupped when I crank on my 13,500 AC unit. Perhaps the current line of AC units have a built-in soft start capacitor?
Portable, starts easy, runs quiet, essentially maintenance free. I'm very happy with this unit.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 12-13-2006, 08:58 AM   #13
DayStreamer
grizzy's Avatar
2001 19' Bambi
Mesa , Arizona
I have two of the Honda EU2000 generators and wouldn't trade them for anything to use with the Airstream. They are lite and quiet. However, if you are wanting to get something to also run your house, you need to make sure it can provide 240v -- the Honda EU2000 does not.
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
Mesa Arizona
AIR #5591
grizzy is offline   Reply With Quote
Old 12-13-2006, 09:24 AM   #14
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Hi Chuck,
To answer your question about how long to charge, I am not exactly sure, but I can tell you my procedure:
If I'm someplace where I can run a gen I ussually try to do it while inside watching a DVD or eating dinner. This means that I start up the gen around 7 or eight at night and will run it the lenghth of the movie, around 1 1/2 hours.
I know there are folks here that will go for days without charging, but I prefer to charge the batteries daily if I am able. However, we have gone a day or two with out much draw on the batteries without charging. We had a problem at two state parks in Wisconson (Door County). The web site said that they allow generator during non-quiet hours but when we got there and fired up the Honda, within seconds a ranger came around and told us No. No. No.
It is also my understanding that it is not good to let the batteries get below a certain point in power.
Bottom line for me is to feed the batteries each day for a couple of hours if we can. Along with people admiring the AS, they are amazed at how quiet the Honda is. We have the 2000.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Generator filters ViewRVs Mechanics Corner - Engines, Transmission & More... 7 04-05-2004 08:17 AM
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 05:31 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 08:51 AM
1998-1999-2000 Excella Generator fphil Airstream Motorhome Forums 0 07-01-2002 09:34 PM
