Old 08-20-2017, 04:54 PM   #1
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Look what I built
Its 350 pounds of 50 amp, 7500 watt power.
Wired it so I can share power with a neighbor.
Not as quiet as a Honda but not Awful!
I'm happy as a clam!
Old 08-20-2017, 05:07 PM   #2
Byron Center , Michigan
Neat idea!. Might I suggest a small pole or something off of the front edge with a small cap on it like the fender corner markers on the big trucks to remind you it's out there... Keeps you from bumping into things when you forget about it since it's below the sight line. Could take a kid's fiberglass bike flag, cut it down (and remove the flag), cap it, done. Don't ask me why I suggest it. :-/
YippieKiYa is offline   Reply With Quote
Old 08-20-2017, 05:38 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
There is one, just cant be seen in the glare!
Thanks for looking out for me!
Old 08-20-2017, 05:58 PM   #4
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Nice job, Atomic! Do you have to use a 30 amp extension to reach the back of your 34'?
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-20-2017, 06:00 PM   #5
Yes there is - smart move! My apologies for not blowing up the photo and looking closer.
Larry
Old 08-20-2017, 06:38 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
No, I have a long Furrion cord that reaches perfectly!
Old 08-21-2017, 12:58 PM   #7
1973 31' Sovereign
Middletown , California
I like that idea! Maybe build a combination bumper and cover box over and around it to protect the gen-set from weather and curious hands. Probably add 50 pounds or so to provide the kind of protection I'd want but might add a tiny bit of quietness.
ijustlee is offline   Reply With Quote
Old 08-21-2017, 01:36 PM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I drive a 10 cylinder, 10000 pound hot... Not interested in quietness or thriftiness!
Great idea!
Old 08-21-2017, 01:58 PM   #9
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
Looks good do you have it plumbed into your gas tank? Also, is that a new model? I never saw a 7509 watt Onan emerald genset.
Streamracer is offline   Reply With Quote
Old 08-21-2017, 02:13 PM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I harvested it out of a wrecked motothome. Its from 1999.
Its one that can be wired 220, or 110 x2 fields.
The builders plaque clearly states 7500 watts... yippee!
Old 08-21-2017, 02:33 PM   #11
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Outstanding idea, and look's like a neat installation....did it change the handling of the truck?
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-21-2017, 02:45 PM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I should have mentioned this... as far as handling goes, I think the extra weight up front helps stop the pitch polling and smooths out the ride a bit.
The Onan green is my only complaint so far!
Old 08-21-2017, 03:41 PM   #13
1981 31' Excella II
New Market , Alabama
Interesting. Is that an Excursion? How did you mount it. With a standard receiver hitch? How is the hitch mounted to the Excursion?
Perry
Old 08-21-2017, 03:57 PM   #14
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
It is an Excursion. I mounted a Reese front hitch, and built a tray ontowhich the base of the Onan sits in and is bolted to.
Its removable but needs 2 people to lift. I have a small agm battery providing start power and a simple 5 gallon gas gan with a fitting on top. I still need to sew up a nylon cover for non use, and a rain guard so it can be used wet.
Im on the road now and used it for a full day in the rain, and it ran fine. Even the eclipse today didnt effect it much!
Looking forward to sharing power with a fellow Streamer parked close by.
# of Motorhomes built? ViewRVs General Motorhome Topics 7 10-16-2017 10:37 AM
LOOK !! Merry Christmas !! LOOK !! B4WEDI Fun & Games 3 12-07-2010 12:11 AM
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 05:20 PM
ARGOSY by Airstream LOOK LOOK, CLASSIC MOTORHOME eBay Watch Airstreams on eBay 0 06-05-2010 10:50 AM
Info on how many units of each Airstream built? bake315 Airstream Trailer Forums 3 04-21-2004 10:47 AM
