Posted this in the Classic thread but thought others considering solar might be more likely to find it here.
Just finished a solar install with Marvin Braun of Precision RV. I had met Marvin last year when I did an install for my FC25. It worked out that for him to be in the Denver area and I store my trailer in a neighbor’s hangar so he would have a place to do the install out of the weather which was a good thing since we had rain, rain and then some more rain for most of the time he was here.
I had gotten a blueprint drawing of the roof of the 2015 Classic from Airstream. Scanned that and brought it into the drawing program Visio. Checked the scale and was able to play with laying out a mix of 100w and 135w AMSolar panels.
Ended up with 4 – 135w and 2 – 100w panels for a total of 740w of panels.
Controller is a Blue Sky 3024il with a Magnum 3000w Hybrid charger/inverter. The Hybrid allows a mix of solar, battery and any type of shore power to be mixed together and is strong enough to power one of the AC units.
For batteries I went the lithium route. Marvin had experience with the folks at Elite Power Solutions and their GBC based batteries. GBC/Elite offer a 200ah 4 cell which had a form factor that would allow me to mount them under one of the dinette seats.
With 320ah usable with the Elite cells (80% of 400ah) I would have needed to put in 650ah of AGM’s to get the same amount of capacity. That amount of space for 6 Lifeline GPC-4CT’s would have been a challenge. I would have probably lost the under seat storage on both dinette seats and the cable runs would have been longer. And the weight of the AGM’s would have totaled 400# rather than 110#.
Two other factors played into my decision to use Elite rather than AMSolar for the batteries. One was simple. Elite can ship lithium’s while AMSolar is still working on setting up their shipping process since lithium’s are considered a hazardous material. The other is the battery monitoring system (BMS) that is important to have long cell life. Elite puts a BMS on each battery cell. In my case I have a total of 400ah of batteries. 2 – 200ah packs. Each pack has 4 – 200ah 3.2v cells. So a total of 8 BMS sensor boards. This allows each cell in the pack to be monitored and charged accurately. Based on my experience with lithium batteries for UAV’s (drones), each cell should be measured for best life of the battery. It is more expensive than only measuring a group of cells as a bundle. And the Elite BMS system also outputs data to an expensive video monitor with lots of data on the health and status of the battery system.
For mounting I followed a similar path to what BAB (Barry) did for his install. The batteries and Magnum went under the dinette seat under the TV (rear seat). The drawer was removed from the face and the face was screwed to the frame. So we lost that one storage drawer. The Blue Sky went on the wall under the forward dinette seat where the old WFCO inverter had been mounted. Subwoofer was also moved under that seat.
This kept all of the cable runs as short as possible and ended up being a compact installation.
The 50amp sub-panel fit into the compartment under the hall closet that has the heating vent. The original panel now only powers the rear AC and the electric heater for the water heater. Everything else in the coach is on the new sub-panel.
There was ample room in the wire chase from the roadside to curbside where the shorepower cables are installed to bring power to the main breaker panel and back for the new sub-panel and wiring to the Magnum.
Total install was over 4 ½ days. Marvin is meticulous. Wiring is neat, fully bundled and a work of art. He was able to pull all of the cables, both power and data to the Magnum and Blue Sky controllers without additional holes. No need to remove the refrigerator. Tip, in the space behind the TV on the roadside wall where the power and antenna plugs are located, that panel can be removed which helps with running cable up that roadside wall pretty neatly.
We pulled the trailer out on a semi cloudy day and were getting the full 40amps out of the Blue Sky with some shading going on the roadside panels from the A/C units.
Couple of items to note on Lithium’s. They can take the full output from your controller that you can throw at them on a charge cycle. They stay in bulk mode until they are in the high 90% range (usually about 98%) and then go into a slower absorption charge mode. AGM’s go from bulk to a slower absorption rate at a much lower percentage of being full. Thus Lithium’s will charge much quicker than the equivalent AGM/Lead Acids since they will take the full 40ah output from the Blue Sky controller for a longer period of time.
The other item of interest is turning on the A/C unit. Mine is a 15K. With my FC25 there was a definite sag in AC voltage when that type of load was put on the system. With lithium’s the AC voltage did not change. Didn’t even budge on the Elite BMS display.
I like boondocking, lots of BLM and USFS places here in the west. And solar opens up lots of camping sites in general that don’t have power without giving up your power hungry lifestyle. I work from the road, so need internet access. Solar keeps it quite, though I do also carry a 2K Honda as a backup. But I don’t need a 3K unit or a pair of Honda’s to run the A/C when needed.
I’ll post a follow up to see that the affect of the changes had on weight. Removed 102# from the front battery compartment. Added lithium (110#), Magum (60#) and panels (111#) mostly just in front of the axels. So I think tongue weight will go down. Not sure how much. Scales will tell the tale.
As for cost, yes at the front end lithium is more expensive. Comparing this install to my last install the overall price was the same with a delta for the difference in the lithium batteries compared to 4 AGM’s. Long term the jury still seems to be a bit cloudy but even some of the more pessimistic predictions show that properly maintained lithium’s will in the end be the same cost as AGM’s since they should get more charge cycles.
And I highly recommend a pro do the work. Marvin has a wealth of knowledge on how to wire all of the pieces together to give you solid solution. Lots of experience installing solar on Airstreams. He did all of the roof work without walking on roof. Sincere kudos for that. All of the components are the same price but Marvin has the tools to build the cables and all of the other bits and pieces that most of us would have to chase down, borrow or buy. He is very thorough in explaining the system, will help you really understand how to make it work and keep it running.
And for me the plus, besides having Marvin do the install, was that I didn’t have to travel to get the work done. Made it very convenient for me since I am about a 100 yards away from my storage location and I didn’t spend time traveling to get the install completed.
Photo 1 - Batteries, Magnum, main fuse, Elite Power BMS CPU on top of the Magnum
Photo 2 - Side wall, shunt at the bottom and breaker for the input from the Blue Sky
Photo 3 - Blue Sky, Solar disconnect, sub-woofer and cables to the DC Pos/Neg Bus and battery disconnect at the front of the trailer behind the couch
Gary, FYI, I've had that same Blue Sky charge controller in an off-the-grid cabin, seven years now. It has performed flawlessly and treated my (lead-acid) batteries very well.
Blue Sky makes a great product. Only thing I would suggest to them would be to have a larger output model to take more advantage of large mobile solar arrays. With lithiums being able to take up to a 3C charge rate (1200 amps in my case), not that you would ever have enough panels to do that, if you had a spectacular day, no shade, full sun and your panels could put out 50+ amps it would be great to grab all of that energy during the recharge cycle. I've seen some motor homes that have 1400w on the roof. They address the limitation with installing a couple of Blue Sky's. But then they have the basement room to put in a lot more bits and pieces.
Photo 1 - Batteries, Magnum, main fuse, Elite Power BMS CPU on top of the Magnum Attachment 239502
Photo 2 - Side wall, shunt at the bottom and breaker for the input from the Blue Sky Attachment 239503
Photo 3 - Blue Sky, Solar disconnect, sub-woofer and cables to the DC Pos/Neg Bus and battery disconnect at the front of the trailer behind the couch Attachment 239504
I enjoyed your informative post - soon to get a 2016 Classic - very new to solar.
Do I understand correctly that you have: a) 740w of panels; and b) a total of 400ah of lithium batteries? If 'yes', is your battery total somewhat underpowered given the 740w of panels? If it is underpowered, is there a risk?
Regarding your boondocking ability with your panels and batteries, how many of your Classic's electrical components can you simultaneously use? Can you use one of your air conditioners without dependency on your 2k Honda?
Panels on a full sunny day are putting out 40+ amps. So easily I can put in 200ah per day. So sizing is about right, at least for me.
The Magnum hybrid will run the AC unit. It is wired to the front 15k AC unit. It pulls about 150 amps when running. So about 2 hours of run time. Full solar drops it to about 110 amps from the batteries.
I can run the TV/Radio, sat RX and my laptop/Weboost cellular amp with the AC running. Honda will throw about 100amps so get close to a net zero situation with the Honda.
Reality I have used the AC to kill the heat above 90 degrees and have seldom used the Honda. To many great sunny days in the west.
With all of the roof space available on most motor homes, one can really max out their solar. Here are a couple of shots of a 12 panel, 1920 watt solar charging system routed to the batteries thru 3 parallel Blue Sky 3024 controllers using a single iPN-PRO remote. The remote shows 100+ amps going to the battery bank solely from the solar array. IMPRESSIVE!!
lewster
Lew now that's the ticket. With a single BlueSky it is easy to leave amps on the roof on a really bright sunny day. I put in a vote for BlueSky to release a 50-75amp unit. AMSolar has the Victron which is larger but haven't seen anyone post anything about them.
Victrons are larger units, but there have been some 'issues' with their monitor and programming capabilities. Greg is still working on that one.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
I've been thinking a lot about this, even pestering Lew. And I know a guy who's having these installed by Marvin from Precision RV in another week.
Elites seem priced well in comparison to AMSolar's and I don't understand why AM solar is building batteries which monitor at the 4pack cell level, not each individual cell which seems silly to me given the benefits of doing so.
So I've made plans myself to go this route during Thanksgiving.
__________________ Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow. OUR BLOG | INSTAGRAM
Bold, mind if I ask how much your 400 AH system will cost?
I'm doing self-install, so I could only tell you the price of the batteries today. When we head to Yuma Thanksgiving week and I gather all the supplies I'll have a better idea, and like I usually do I'll post that up.
But right now looking at $2960.00 for comparison AMSolar is charging $3,299.00 for a 400 AH system.
Yes but I don't want to go all the way down to assembling the batteries myself. I looked at LiFePO4's briefly.
I was considering buying the 100AH cell packs, they come in at $620 and 4 would be $2480.00 - This would take up a little more room, but it'd be alittle cheaper. That route, depending on where I stick these is tempting to build something big like 600ah.
Consider if you assembled a 300 AH battery the components would cost about $2K so $3K for a 400 AH system seems reasonable. My guess is that you're paying perhaps only 20% more than a DIY system yet you are getting all the benefits that it entails! Looking forward to seeing your installation.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
Patton, it was a typo. It is an 'inexpensive' monitor. $50 Here's the link to the Elite site with the LCD monitor. Elite Power Solutions
I'll shoot a photo of the screen and how I have it mounted (simply used 3M picture hanging strips) tomorrow.
Alano the price as you point out is higher. But the weight and size savings are also another factor. Other than the Bluesky controller (mounted where we took out the old 600w Inverter) my 400ah system all fits under one of the dining couches. No way I could have found a home for an equivalent AGM system (600ah of batteries).
This week I was camping in Las Vegas NM and Raton NM. I did hook up to power just to run the TV and computers. But all 12v systems were run from the batteries and all charging was from my solar panels. Lots of furnace time at night. Morning I was at 60-65% capacity. By 1-2pm I was fully recharged with daylight to spare. Panels were not tilted. One location I oriented E-W and the other I was N-S. Seemed to get the same results in the early winter sun angles. 25-26 amps output through the BlueSky. Very happy with the results.
If I could replace my lead acid cells with lithium cells in the outside box I'd probably do it in a heartbeat. Unfortunately these cells can't be charged at subfreezing temperatures so folks are placing them inside where the temperatures are milder. I'm also not terribly comfortable with all that energy inside the caravan without a protective barrier in the rare case of a failure. It's one of those things where the probability of failure is low but the consequence is high. This stuff is cutting edge for sure.
Like Tesla, perhaps someone will integrate a heater in the lithium battery pack that keeps the cells above freezing when there's any attempt to charge the battery pack. If that system would drop into my outside box and replace the two type 27 batteries that are currently in there with a 300 AH lithium solution, I think they would sell like hotcakes.
Al, K6IV
Here's photos. The display has two views. The standard is where I leave it most of the time. There is a momentary switch that changes to the individual cell information. Simply used 3M picture frame velcro to the wall.
2011 27 FB International
Vancouver
, British Columbia
Originally Posted by RVDreamer
Where did you hear that you shouldn't charge a lithium battery below freezing?
All literature on current lithium batteries such as the GBS state this. You can damage the batteries if you charge below freezing, but using them is just fine.
I installed 300AH sometime around March, placed them under the bed where they would be kept warmer.
