Old 11-28-2015, 02:02 AM   #43
2016 30' Classic
Erie , Colorado
Single shunt but I've never said I am using a BMK. Haven't had one on either of the solar setups. I use the Elite screen and the IPN readouts.
No idea where Elite sources their monitors and just looked at the link from Bold. Looks like it might be the same. Not worth chasing down for saving $25 on a multi thousand lithium setup. One stop shopping with Elite.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 11-28-2015, 09:19 AM   #44
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Doesn't have to cost multi-thousand dollar. But oh yeah, you will pay for this project.
I just started working on disassembly of the packs into their individual cells yesterday. I'll start my own thread though.
Originally Posted by mixedpuppy View Post
ghaynes755, the EMS you have from Elite Power Solutions has over and under voltage protection circuits that can drive a contactor relay (similar but not the same to the battery disconnect, one each for over[OV] and under[UV]). If you don't have the battery isolated by those circuits and you over or under charge the batter, you're warranty wont be valid. Elite warned me of this more than once while I was working out the electrical. The solution I came up with unfortunately also takes 0.4amp continuous power for each contactor.
I plan on having a 350A/12V continuous duty solenoid, UV control. Opens if any cell falls below 2.8 volts. On the negative side after the shunt. On the positive side I'll have another one with OV control. It will before PV and the Inverter positive but after all 12v positive loads. And that will isolate the battery in both directions.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-28-2015, 09:24 AM   #45
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Just like Christmas Eve - some assembly required.
Old 11-28-2015, 09:36 AM   #46
Nomadic , USA
I like the AM Solar install method (your pictures) over the Precision job personally. Looks cleaner.
So I plan on arranging my cells myself and then securing them in a box similar so I can maximize my space.
Old 11-28-2015, 10:22 AM   #47
ghaynes755,
You said previously "Since I have a Magnum Hybrid I use the ME-RC control head which includes battery monitoring and lots of other functions".
Battery monitoring is shown on the ME-RC only if the BMK is installed. Are you trying to say that you have an SOC shown on the ME-RC without the BMK?
pattonsr is offline   Reply With Quote
Old 11-28-2015, 11:27 AM   #48
switz's Avatar
2014 31' Classic
Images: 8
The 600 amp-hour battery in the Classic beside the Magnum and under the front sofa of the Classic.
The 300 amp-hour battery before the plexiglas cover in the 23D between the street side wheel well and the furnace.
ID:	252982   Click image for larger version
Old 11-28-2015, 12:00 PM   #49
lewster's Avatar
Naples, FL , Hood River, OR
One of the reasons AM Solar uses the SinoPoly cells is the solid copper interconnects between the cells that use heavy bolts over the much smaller hex screws found on the Elite cells.
These cells also allow for direct connection of heavy cable eyelets to the battery terminals directly, without the use of adapters.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 11-28-2015, 12:30 PM   #50
Nomadic , USA
All of the prismatic batteries use those terminals, except for the GBS.
Anyone curious in the color coding:
Fluxpower/Voltronix cells come in Green and Yellow.
CALB cells come in either Blue or Gray.
Winston Battery cells come in Yellow.
Sinopoly cells come in either Yellow, Green or Black.
Realforce cells come in either Black or White.
GBS cells can be found in either Yellow or a Blue-ish hue.
Hipower cells come in White.
GBS seems to be the only one with the 4 hex screws, they claim it's a more secure connection with no stress on the connector. Take that as marketing.
I am bolting a copper bar straight to them.
PS: Naturally I found this after I purchased the GBS Cells: http://www.canev.com/batteries.php
Old 11-30-2015, 09:41 AM   #51
Nomadic , USA
Correction here, the GBS batteries do feature the same screw holes, but only on the 3rd generation 200Ah cells. Also should be noted that uses the 200Ah cells takes up less space than AMSolar's 400Ah setup which uses 16 100Ah cells.
That being said, I chose the 100Ah cells because of the $500 cost difference at the end of the day.
Old 11-30-2015, 04:58 PM   #52
2016 30' Classic
Erie , Colorado
Originally Posted by pattonsr View Post
ghaynes755,
See post 42.
Gary
2015 Classic
ProPride
NØVPN
Old 11-30-2015, 09:42 PM   #53
Nomadic , USA
Phase 1, battery layout and compartment building
Eventually, this space will be fully enclosed.
Old 12-14-2015, 10:33 AM   #54
Nomadic , USA
Question
This question is for the OP and anyone else with Lithiums combined with a Blue Sky Solar Controller and IPN Pro remote
I'm curious about your settings for these inside the advanced menu settings:
SET MAX BAT VOLTS
then inside charge settings
SET ACCEPT CHG
SET FLOAT CHG
SET EQUALIZE CHG
SET T-COMP (no clue what this even is for)
Mine is 05.00mV/C/C
SET FLOAT CURRENT
SET ACCEPT TIME
Old 12-14-2015, 12:42 PM   #55
kenen42's Avatar
2011 27' FB Flying Cloud
Delmar , New York
Attached is the setup guide AM Solar sent me for the Blue Sky systems. I only have AGM's but the chart also has all the values they recommend for lithium.
If I remember right T-Comp is the slope of the temperature compensation curve.
kenen42 is offline   Reply With Quote
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 09:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 06:44 PM
fantastic fan install for '63 city/batt system. my1ststream Roof Vents, Skylights & Fans 3 06-04-2010 10:39 PM
Spray Lithium Grease (Wal-Mart) Old_Town Hitches, Couplers & Balls 3 11-16-2007 12:48 PM
