Old 11-17-2015, 12:17 PM   #29
Lew,
What exactly did you mean by "our monitor"?
pattonsr is offline   Reply With Quote
Old 11-17-2015, 01:09 PM   #30
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I just don't understand why AM Solar is monitoring at the pack level and not the individual cell level.
Elite sells a complete system too. But also offers the GBS batteries separately, the boards, and choices of controllers, etc to build a DYI system. Could be various applications beyond just RV use.
AM Solar is only selling complete systems with perhaps more emphasis on RVers.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-17-2015, 02:14 PM   #31
lewster's Avatar
Naples, FL , Hood River, OR
AM Solar decided on their present lithium system after extensive real-world testing (18 months) of many varieties of lithium batteries from a wide variety of sources.
They are focused on the RV solar business and build and sell what works best for that specific environment.
Beyond that, only Greg Holder, pres. of AM Solar would have any more details.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster is online now   Reply With Quote
Old 11-17-2015, 10:28 PM   #32
2011 27 FB International
Vancouver , British Columbia
ghaynes755
What did you use for the relay? Seems like it's only connected to the undervoltage control. How much amperage does it draw?
lewster:
The relay in the photos on the amsolar website look roughly the same as what I have, but the images are not detailed enough to zoom in on, any chance to find out what brand the relay is?
mixedpuppy is offline   Reply With Quote
Old 11-18-2015, 05:44 AM   #33
lewster's Avatar
Originally Posted by mixedpuppy View Post
ghaynes755
lewster:
I'll check it out when I get my next BMS unit…..which should be in a few days and let you know.
Old 11-20-2015, 12:42 PM   #34
Nomadic , USA
Lew, do you know if AMSolar is top or bottom balanced? Seems like bottom is better from my research, but top makes me feel safer about putting them in my airstream. Although a lot of EVers use bottom.
Old 11-20-2015, 01:11 PM   #35
lewster's Avatar
I believe it's top balance. I'll check for sure on Monday.
Old 11-26-2015, 10:58 AM   #36
Lew,
Do you know if the Magnum BMK works ok with Lithium batteries? Over a year ago, Magnum told me not to use the BMK since they had never tested with Lithium and did not think the BMK would give an accurate SOC.
Also what does AMSolar provide to show cell voltages similar to the display from Elite mentioned in an earlier post that showed cell voltages?
Old 11-26-2015, 11:24 AM   #37
Nomadic , USA
AMSolar monitors at the 4 cell level, which is kind of a shame. And I can't tell from their pictures if their EMS(CPU) actually has a video out port. Doesn't look like it.
Old 11-27-2015, 01:02 PM   #38
I was reading the Elite operations manual and realized that a shunt is involved. The results from the EMS CPU can be displayed on a LCD screen (ghaynes555 provided a picture earlier). Of interest is the current in and out of the batteries and a battery pack capacity.
So battery monitoring is there and there should be no need for Victron or Magnum battery monitoring.
Does the AMSolar system have a shunt? As BoldAdventure pointed out, their CPU may not have a video out port. Is a Victron or Magnum battery monitor needed with the approach that AMSolor took?
Old 11-27-2015, 01:52 PM   #39
ghaynes755,
At post 18 your said there is a momentary switch that changes to the individual cell information.
I believe the switch is wired back to the CPU.
Your picture shows a TFT color monitor with buttons at the bottom. Is this what you received from Elite? The Elite website shows just the LCD monitor for $50.
Where exactly is the momentary switch in your pictures?
Old 11-27-2015, 02:24 PM   #40
Nomadic , USA
Originally Posted by pattonsr View Post
ghaynes755,
You can get the LCD for $24 on Amazon FYI
The rest of my supplies are showing up during next week. Started on my battery mounting today.
From what I can tell, AMSolar's kit is pretty basic. Including their CPU. You'll notice from Switz picture that you are getting 4 pack monitoring. I also see a lack of LVC and OVC.
You are not going to get individual cell monitoring from the Victron or the Magnum, but you will get overall battery bank monitoring.
Old 11-27-2015, 09:24 PM   #41
2016 30' Classic
Erie , Colorado
Patton
Since I have a Magnum Hybrid I use the ME-RC control head which includes battery monitoring and lots of other functions.
The momentary push switch is mounted up next to my BluRay player. I seldom use it.
Monitor is from Elite ($50) and includes cabling and power connection in one cable from the monitor until it splits. Makes it pretty clean to install.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 11-27-2015, 11:23 PM   #42
ghaynes755,
My confusion was that your picture looks like the TFT LCD monitor that BoldAdventure provided a link for. The Elite web site shows a plain LCD monitor with a cable only for power. Elite probably hasn't bothered to update their web site.
Also since you said you used the Magnum BMK, did the BMK and Elite both use the same shunt? Did you find the state of charge calculated by the BMK to roughly match the state of charge from the Elite monitor? If not, which one was more accurate.
The BMK is an option for Magnum inverter/chargers and only uses the ME-RC as a display device. Unless the Elite state of charge is not very accurate, then I do not see the need for a BMK. I must be missing something.
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 09:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 06:44 PM
fantastic fan install for '63 city/batt system. my1ststream Roof Vents, Skylights & Fans 3 06-04-2010 10:39 PM
Spray Lithium Grease (Wal-Mart) Old_Town Hitches, Couplers & Balls 3 11-16-2007 12:48 PM
