Old 11-07-2018, 03:38 PM   #1
2016 19' Flying Cloud
Clearwater , Florida
Just installed custom generator rack on Bambi
After seeing several different strategies for carrying small Honda generators on an airstream, I worked with a local metal fabricator to build an aluminum rack to bolt over the battery box. It uses the “puck lock and plate” configuration on either end to secure the generators (also made of aluminum) and we put a mount in the middle to secure a crush proof Jerry-can to carry fuel. The center plate on the rack is removable so you can access the batter department without removing the rack. However, removing the batteries would likely require unbolting the rack. I can still use the anti-sway hitch and can still access the spare tire rack underneath the trailer.
Mwgautreau is offline   Reply With Quote
Old 11-07-2018, 04:45 PM   #2
2007 27' International CCD FB
San Diego , California
Looks like it's solidly built.
Is there a particular reason you're opting to carry 2x gennies? I would think a Bambi has the smaller 13.5k A/C which could be handled by a single genny with easystart?
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
pteck is online now   Reply With Quote
Old 11-07-2018, 05:11 PM   #3
2012 Avenue Coach
Corpus Christi , Texas
Originally Posted by Mwgautreau View Post
. . I worked with a local metal fabricator to build an aluminum rack to bolt over the battery box. It uses the “puck lock and plate” configuration on either end to secure the generators (also made of aluminum) and we put a mount in the middle to secure a crush proof Jerry-can to carry fuel.
Welcome to the forum Mwgautreau!
Well designed and executed. But what about rain and weather protection?
rowiebowie is offline   Reply With Quote
Old 11-07-2018, 07:15 PM   #4
2017 23' International
hendersonville , North Carolina
Custom Gen Rack
How much does all of that weigh including full Fuel Container?
uraljohn is offline   Reply With Quote
Old 11-08-2018, 03:39 AM   #5
Airstream dealer recommended the two small generators for boondocking the 19 Bambi Flying Cloud. I’ve read posts from people who have been successful with just one. Each generator weighs 47 pounds. I haven’t put the rack on a scale yet but it’s aluminum and is lighter than a generator. A gallon of gas weighs about 6 pounds. I can carry 5 in the can. I purchased the covers in the picture below for weather/travel protection.
ID:	327333   Click image for larger version
Old 11-08-2018, 05:24 AM   #6
Mount Dora , Florida
That’s very cool! If I didn’t have a front bedroom and the associated front storage door I would do something similar.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 11-08-2018, 05:34 AM   #7
Gainesville , Florida
Are you going to remove them for operation?.
Old 11-08-2018, 07:23 AM   #8
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Attachment 327298
Attachment 327299
Attachment 327300
Welcome to the Forum,
This is what the 23D Club would call a quality item. Well Done! This looks like it will meet your needs well.
Looks like it is built very well.
180lbs of tongue weigh is nothing to sneeze at but well within a manageable limit. (better than 180lbs on the rear)”my opinion“
Keep us posted on how it’s working out.
Also if you have any more detailed pics that would be nice. I always enjoy studying others design work.
Old 11-08-2018, 07:50 AM   #9
The rack is designed to run the generators in place. The exhaust faces outward while the controls and ports for linking the generators face inward. Here are some more “technical” pictures;
ID:	327339   Click image for larger version
ID:	327341   Click image for larger version
Old 11-08-2018, 09:29 AM   #10
2016 26' Flying Cloud
Southlake , Texas
Looks nice. It looks like two guys could remove the nuts from the u-bolts and haul the whole thing off. I would somehow secure those nuts.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 11-08-2018, 10:19 AM   #11
GMFL's Avatar
Dadeville , Alabama
Maybe turn the U-bolts over and drill some holes through the top to access the nuts. The holes to remove the nuts would be under the generator when locked in place and would not have access. You would also need to weld a “guard” in place to prevent accessing the outside bolts from the underside.
Just an idea?
Old 11-08-2018, 11:08 AM   #12
2013 25' FB Flying Cloud
2017 28' Tommy Bahama
Penticton , British Columbia
Thumbs up Just Installed Custom Generator Rack On Bambi
Nicely Done!
Did you/fabricator make sketches with dimensions that you/they maybe willing to share?
Tx's
TorchRozee is offline   Reply With Quote
Old 11-08-2018, 11:14 AM   #13
greenflag's Avatar
2016 30' International
Quartz Hill , California
Have you tried running them in place yet. I wonder about the vibration transferring to the frame and felt inside the trailer specifically the floor.
Great installation though. A good idea if you have limited space available in ones tow vehicle.
greenflag is offline   Reply With Quote
Old 11-08-2018, 11:19 AM   #14
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
There is one issue that I see, clearance during tight turning.
Please check
"Chip Tank" is in Paso Robles Ca.
CDONA is offline   Reply With Quote
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 10:23 AM
Experience with Rhino Rack track mounted rack? wecoyote Tow Vehicles 2 11-12-2015 03:25 PM
Has anyone installed a Reese hitch bike rack? RachelLynn 2006 Safari 10 09-09-2013 11:26 AM
Has anyone installed a bike rack? coffeydelsol General Repair Forum 30 03-18-2009 10:56 AM
