Old 04-18-2007, 09:38 AM   #15
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by HiHoAgRV
Several years ago a co worker showed me his in-laws tow rig that had the genset mounted in the bed of the TV and the exhaust plumbed through through the floor. The remote start was mounted in the TRUCK and he towed with the Shore power hooked to the genset. 1/2 an hour before arrival at a camp, he would start the genset and the air in the camper would start the cooldown.
The thought occurred to me. My plan is to have the control panel moveable. The panel has the hour meter in it and I want to keep track of use. I will have the panel setup to be directly on the genset for use at my home or to operate radio gear for field day. I will also have a mount in the trailer with a pigtail to the exterior with a plug in extension from the trailer exterior to the genset to setup the panel for remote start from the trailer interior. The start sequence of the ONAN is that you press down the start side of the toggle switch, all the safeties are overridden, when the generator is up to speed a light on the center of the switch comes on and the unit is good to go with the safeties engaged.
Thanks Jim
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 04-18-2007, 02:44 PM   #16
Central , Mississippi
Gen operation
Yup, the startup is exactly like the one in a SOB class A I owned. If you do decide to remote start with any kind of load, I'd recommend a transfer switch like a class A RV's that has a timer. It will let the generator run for about 60 seconds prior to engaging the load. Available at most RV dealers
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-18-2007, 04:04 PM   #17
Jim Clark's Avatar
Thanks for the heads up, I will look for one.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 04-18-2007, 06:28 PM   #18
2006 30' Classic
Farmington , New Mexico
Images: 14
my suggestion for somthing that heavy---Rent a boat -- have friends help load into boat...row to deepest part of lake-----punch hole in center of boat---swim to shore-----pieman
Mike Lewis is offline   Reply With Quote
Old 04-18-2007, 08:38 PM   #19
Jim Clark's Avatar
Mike, I like heavy and quality. I already have a boat; it is one of the few that survived Katrina because she is heavy. I have a collection of Ham Radio Gear known as boat anchors which I canít get enough of. I know I am not right it is a sickness.
Thanks Jim
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Airstreams in the Movies... InsideOut Our Community 406 12-14-2017 04:23 PM
First Big job.updating toilet from chemi to real rheadhuntress Sinks, Showers & Toilets 2 04-19-2004 06:08 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Come visit Idaho the harvest started FrankR Off Topic Forum 5 07-28-2002 09:17 AM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
