Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 04-17-2007, 07:55 PM   #1
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Jim's Big A## Generator Project
Like a lot of members on the forum I have more tools and surplus equipment lying around the house than most normal humans. I am a fan of all the goof shows which show some one picking through the trash and building a useful item. It is in this spirit I will attempt this project. I welcome suggestions and idea from forum members.
I have inherited a 4kw Onan Emerald Plus Generator with only 41 hours on it. This model Onan is a beast 216 lbs. 2 cly 1800 RPM. Meets National Park Standards and can be run 24/7 if necessary. This unit was and may still be the standard used in many mobile homes and is normally mounted on a slide out rack. One nice feature is it has a remote start and shutdown, I will mount a panel in the trailer.
I will have to rig a system to load this rig in my truck so suggestion on how to rig a 12 volt winch in the bed of the truck would be appreciated.
Thanks Jim
Name:	Onan Emerld Plus.jpg
The Beast, this is no Honda. I wish it were. Cost: Free Donation
Garden Cart. Cost $70.00 Lowes Rated for 1200 Lbs."Right"
Name:	Water Proof Case.jpg
Water Proof Case. Cost $10.00 Surplus after Katrina
Broken Gen Set, Will use Distribution Panel. Engine Good Gen End bad.
Cost; $50.00 to brother-in-law.
Name:	Gen On Cart.jpg
Generator on cart. Notice gray primer I had to weld a section of angle iron to strengthen the 1200 lb capacity cart.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 04-17-2007, 08:10 PM   #2
zamboni
zamboni's Avatar
Profile:
I suppose a used "Tommy gate" would work great, or you could use an electric winch (run off the generator) to pull itself up ramps and into the back of your truck. I'd make sure to cover the flywheel though.
I removed the 4k Onan from our MH last week, (I never use it), and am considering putting it on a cart with 30amp plug...I could use it for power outages at home or put it back into the MH if going somewhere w/out power.
zamboni is offline   Reply With Quote
Old 04-17-2007, 08:19 PM   #3
Jim Clark
Jim Clark's Avatar
I will reinstall the flywheel cover, I had to have it off to setup the exhaust. The unit will be in the weather proof case when it is all together. I will cut the case down to the proper size.
Good tip on letting the Genset power the winch.
Thanks Jim
Thanks Jim, N5TJZ
Picture Gallery
Old 04-17-2007, 08:51 PM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
How about one of those 12v mini cranes like they use for the (heavy) electric wheelchairs?
Mounts on the rear corner of the bumper, lifts 500 pounds.
Change is inevitable, except from a vending machine
AIR#2611
Old 04-17-2007, 08:58 PM   #5
Jim Clark
Jim Clark's Avatar
That also sounds like a good option. I do carry ramps in my truck bed tool box so may go with the winch. I carry a set of folding ramps for a couple of reasons, one to run one tire up on to fix a flat, and the second to get a the trailer out of a frame dragging situation.
Thanks Jim
Thanks Jim, N5TJZ
Picture Gallery
Old 04-17-2007, 09:03 PM   #6
mistral blue
Certifiable
mistral blue's Avatar
Profile:  1977 Argosy 24
Beautiful , New England
What kind of ramps do you use for your genwagon?
mistral blue is offline   Reply With Quote
Old 04-17-2007, 09:11 PM   #7
Jim Clark
Jim Clark's Avatar
I purchased a set of cheap ramps at Sam’s. Made in China, fold up and can be set at varying heights. They work very well and can be set to run the front of the truck up on to change the oil and such. I have seen the ramps at Walmart also.
Thanks Jim
PS I have not ran the cart up them yet as I have not finished the cart yet.
Thanks Jim, N5TJZ
Picture Gallery
Old 04-17-2007, 09:30 PM   #8
overlander63
Images: 58
Looks like Lowes uses the same mathmatics to figure weight capacity as truck manufaturers do for tow ratings...
The front axle on our 1200 pound cart started bowing out after using it for a few days with an 800 pound load on it. I hope you don't have the same problem.
AIR#2611
Old 04-17-2007, 09:49 PM   #9
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Chopper one to Jimbo: ready the cargo sling, pop a smoke for ident, your smoke color is..
The 2 worst things that can happen to an old aviator:
(1) One day you will walk out to your aircraft,
knowing that it will be your last flight.
(2) One day you will walk out to your aircraft,
not knowing it will be your last flight.
Proud Appellation American
doorgunner is offline   Reply With Quote
Old 04-18-2007, 07:21 AM   #10
mistral blue
Certifiable
As you might be guessing, I am interested in this project of yours. Please keep the pics coming.
Are you going to be using something to dampen the vibration between the gen and the cart?
Thanks.
Old 04-18-2007, 07:29 AM   #11
overlander63
Images: 58
Thanks.
From his photos, looks like he has rubber mounts on his damaged genset that he can use, if he wants to.
AIR#2611
Old 04-18-2007, 08:20 AM   #12
Jim Clark
Jim Clark's Avatar
I think I will come it at 300 Lbs. The genset is 213 lbs, I also have a welding machine and material to fabricate reinforcements. The cart was bought as a base, I felt by the time I fabricated a new cart with wheels it would of cost me more than starting with something cheap.
Thanks Jim
Thanks Jim, N5TJZ
Picture Gallery
Old 04-18-2007, 08:32 AM   #13
Jim Clark
Jim Clark's Avatar
Thanks.
As I do work I will bump up the pictures. I am not in a hurry and working as I have time, I do have a real job. I also have a couple of other gensets if needed, which are not as nice which means very loud, but can be used if needed.
The ONAN has a 3-point rubber mount it is sitting on. One reason I used the cart with the wire mesh is the ONAN is designed to pull air across the engine using the vanes on the flywheel. I have the shroud off of the flywheel at this point so I can work with the exhaust which is on the other side of the unit. The weatherproof box will sit over the genset when completed, which is the plan at this time. I have a concept in my head and did rough measurements but no detailed drawing. I like to do fit and cut much like you see on American Chopper, Gorilla fabrication.
Thanks Jim
Thanks Jim, N5TJZ
Picture Gallery
Old 04-18-2007, 08:58 AM   #14
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Genset mounting
Several years ago a co worker showed me his in-laws tow rig that had the genset mounted in the bed of the TV and the exhaust plumbed through through the floor. The remote start was mounted in the TRUCK and he towed with the Shore power hooked to the genset. 1/2 an hour before arrival at a camp, he would start the genset and the air in the camper would start the cooldown.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Airstreams in the Movies... InsideOut Our Community 320 03-10-2008 04:44 AM
First Big job.updating toilet from chemi to real rheadhuntress Interior Restoration Forum 2 04-19-2004 06:08 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Come visit Idaho the harvest started FrankR Off Topic Forum 5 07-28-2002 09:17 AM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
