Old 03-03-2010, 04:56 PM   #1
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Is this Overkill? Solar
SolarWorld SW175, 175 Watt 24V Solar Panel :: SolarWorld Solar Panels :: SolarWorld :: Alter Systems On-line Shop | Solar Panels | Solar Inverters | Residential Solar ::
Have a guy whos selling these for almost half the price listed. Is it too much power? Could it work on my airstream?
Just asking, I'm clueless to the Solar thing.
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 03-03-2010, 05:01 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Shane
Shane,
No opinion on the value, but always make sure that you have enough available real estate on the roof for any solar panel(s) you pick.
Bill
Just my personal opinion
Old 03-03-2010, 05:14 PM   #3
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
One problem is that the solar panel is a nominal 24 volt and you've a 12 volt system. You could use it with a charge controler, but you'd only get about half the rated charging wattage.
Cheap ain't always good value.
snake is offline   Reply With Quote
Old 03-03-2010, 06:03 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I think that 24V is the usual output for all solar panels, hence the need for a controller with any panel.
Bill
Old 03-03-2010, 06:16 PM   #5
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
Bill
Solar panels come in a variety of output voltages. A 12 volt nominal panel will have an open circuit voltage in the 17-22 volt range, the 175 watt panel in question is listed at 44.4 OC voltage.
Old 03-03-2010, 06:24 PM   #6
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
When it comes to power there is no such thing as "overkill"!
(And you can take that to the bank!)
Symbolic speaking ...
Xbob2 is offline   Reply With Quote
Old 03-09-2010, 01:15 AM   #7
nomader's Avatar
Nashville , Tennessee
I heard panels would be dropping in price 40-60% by the end of 2010'.
Even if the volts were that high, wouldn't a mppt put it to good use?
Don't listen to me, I don't know what I'm talking about. I'm trying to figure the same thing.
nomader is offline   Reply With Quote
Old 03-09-2010, 01:30 AM   #8
nomader's Avatar
I think the whole solar tax credit thing is going to cut the prices down, it should help the RV industry. Yet again, one more thing to research.
Old 03-09-2010, 06:07 AM   #9
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
If you do enough "Boondocking" to warrant solar, go for it. My advice would be to get someone who REALLY knows their stuff to install everything for you. There's a lot to consider regarding control panel(s), batteries and all the necessary hardware to do it correctly the first time. Good luck.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 03-09-2010, 07:16 AM   #10
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I have those
My 94 Sovereign 21' had four of those on the roof when I got it. I feel like I can man a Lazer light show.
Is Towing 6000 lbs with a diesel overkill? AnnieD Tow Vehicles 81 03-01-2010 10:06 AM
Is Straight-Line Overkill? boutdoors Hitches, Couplers & Balls 19 02-27-2010 05:41 AM
Solar Help takeachance Generators & Solar Power 15 05-26-2007 07:26 AM
solar 4 our AS lee Generators & Solar Power 10 07-05-2003 06:19 AM
Is a Hensley overkill for a 22' trailer? Charcigar On The Road... 11 08-07-2002 08:59 AM
