Old 03-24-2009, 09:39 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Is this an OK solar panel for my trailer
My brother gave me a BP SOLAR BP250/2 solar panel.
Would this be a proper solar panel to use on my trailer?
Product sheet:
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 03-24-2009, 10:15 PM   #2
pbearsailor's Avatar
Port Hadlock , Washington
Glad you found those bulkhead feeds ok, Bruce.
That's a very good panel. Just depends on what you want or what you expect it to do. It'll give you a couple of amps per hour during that part of the day when the sun is pretty high, say 10 or 12 amps a day or so.
If you've got room, more would be better. I'm early on in the restoration of my Caravanner, but we've had solar on the boat for a long time and most of that system will move to the trailer at some point. We've got 250 watts spread over 5 panels and it lets us pretty well run whatever we want. I know I won't have room for all those panels on the Airstream, but I'll try to mount as much as I can.
Best thing is to try to develop a budget for how many amps you use on an average day. Add up each 12 volt device you use and multiply its amp draw by the hours a day you use it and get a total for everything. Then you'll get a pretty good idea of how much solar you'd like to have.
pbearsailor is offline   Reply With Quote
Old 02-16-2010, 03:44 PM   #3
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Can anyone tell me what size solar panel controller I need for the above mentioned solar panel.
Also how do I hook the controller into my existing wiring.
I have done my wiring similar to this
Name:	fuze block.jpg
Bruce,
Solar panel, getting wires into trailer bmklawt Generators & Solar Power 3 03-30-2009 08:48 PM
Solar Panel Questions timmy67 Generators & Solar Power 29 09-30-2008 07:56 PM
Solar Panel gilmorris Generators & Solar Power 14 12-05-2005 05:33 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
