Old 05-30-2008, 12:29 PM   #15
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
exactly the info i was looking for... thanks all!
now to research LP compatible gensets...
boondockdad is offline   Reply With Quote
Old 06-01-2008, 09:15 PM   #16
2000 34' Limited S/O
Jamestown , North Carolina
Solar
Just traded my 87 34' for a 98 34' with has solar. Someone has suggested gel batteries which are expensive. What is the recommendation on the best batteries to hold the solar charge?
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 06-01-2008, 09:39 PM   #17
lewster's Avatar
Naples, FL , Hood River, OR
You'll get as many opinions as on what oil to use, but I (and many others here) have had great success with Lifeline AGM batteries. These are sealed, absorbed gless mat batteries, also called 'starved electrolyte' because the acid is contained in glass mat 'sponges' between the plates that are 99% saturated with the electrolyte, resulting in no free liquid.
As such, they can be safely shipped by UPS and even by air. These are not to be confused with 'gel' batteries, where the electrolyte is in gel form. These are very voltage sensitive and improper charging will cause 'scabs' on the plates where the gel will no longer adhere...resulting in lower performance.
The Lifelines are probably the most expensive batteries out there, but carry a 5 year warranty and typically last 8-10 years when properly charged and maintained.
Old 06-01-2008, 10:37 PM   #18
1975 29' Ambassador
Reno , Nevada
Gel Cells have had their day. They are too picky about charging and use compared to other options.
Lew is a bit optimistic, I think, about the life expectancy for AGM's. Az Wind Sun, for example cites 4 - 7 years. (it is an interesting chart, wish I could see the raw data. it tends to refute several common battery myths)
AGM batteries are nice if you can't store them properly or have a need for large discharge rates (e.g. inverters) if cost isn't an issue. They really don't gain you that much for typical RV solar service from anything I can see or the experience I have had with them.
The biggest battery problem I see with RV solar systems is either with underpowered panels that have trouble keeping the batteries charged or over potent panels that tend to float the batteries. Lead acid batteries need appropriate exercise and full charges to maintain good health.
The Answer for What is Wally Doing? PeeWee Airstream History 2 04-16-2008 05:39 AM
Condensation-Is This The Answer 7xp Winter Living 14 05-29-2007 12:26 PM
AM Solar doesn't answer the phone wingfoot321 Generators & Solar Power 3 05-26-2007 07:20 AM
Please! an honest answer? William Ales Fresh Water Systems 11 11-06-2006 08:01 PM
New Thermocouple not the answer Becky B. Refrigerators 3 07-21-2006 12:44 PM
