Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 09-22-2014, 11:48 PM   #1
Is my solar panel working? And other electrical problems.
I have a 2009 22 ft sport FB. If I run the furnace at night (no hook ups) the battery is dead by morning. I have a generator and always charge it up before bed. But I see no evidence that my solar panel is working. So I kind of have two issues here. Any thoughts? I'm a newbie, it was our first season!
as77 is offline   Reply With Quote
Old 09-23-2014, 04:10 AM   #2
SteveH's Avatar
Common Sense , Texas
The furnace fan is a big load on the battery, but it seems it should last thru the night. I would suspect you have a bad battery, and would have it tested.
Regards,
Steve
Old 09-23-2014, 06:27 AM   #3
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Depends on the temperature. A furnace does eat a lot of power, so if it's running most of the time, well, your battery, even at full charge, isn't going to last that long. But if it's just running a couple of times for a short time, then look for the cause.
And causes can range pretty far. Could be a rotten battery, of course. From your description, it's doubtful that it's the solar system UNLESS your solar controller is incorrectly allowing the system to run in reverse when it's dark. (Our cheapie does that. It'll not just run down a battery, but kill it dead-dead-dead if left unattended.)
Lynn
ACI Big Red Number 21043
Old 09-23-2014, 08:06 AM   #4
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
I am not sure at this point, you have 1 or 2 batteries. If your battery or batteries are fully charged by dark that there should be enough power to last thru the night. Depending on the sun, you should not need your generator. Your controller should tell you if they are fully charged. My controller says 14.05 volts at full charge. Make sure you test the condition of the battery or batteries first.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 09-23-2014, 08:18 AM   #5
1974 Argosy 20
Kooskia , Idaho
Sounds like your battery is toast. Especially if it is an original one. I think the sport only has one, right? It won't have a lot of capacity to begin with and if in week condition, may well behave as you see.
Just guessing of course, it is very hard to diagnose electrical issues over the net with only marginal information.
Old 09-23-2014, 02:53 PM   #6
I also suspect my battery is toast and yes I just have one. Is it easy to upgrade this model to 2 batteries?
Old 09-23-2014, 03:04 PM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
What does your solar charge display indicate as the charging rate?
Old 09-23-2014, 03:15 PM   #8
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
You can manage two batteries end to end with a little modification on the box ends, we've managed to find a NOCO box that allow us to install 3 batteries on the 16' & 22' Sport tongues. It's a NOCO model HM408 box.
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Solar panel, is it working? mgap Generators & Solar Power 7 05-17-2013 12:25 PM
Basic Electrical Solar Panel Questions BillWill Generators & Solar Power 11 12-16-2008 07:10 AM
Electrical Problems To The control Panel sbcoyle Batteries, Univolts, Converters & Inverters 6 09-26-2008 08:23 AM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
