Old 06-15-2011, 08:24 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
I'm confused, where do I wire in solar controller
I am confused, where do I connect the battery and load from the solar controller into my existing system?
Your help is greatly appreciated,
ID:	132570   Click image for larger version
Name:	fuze block.jpg
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 06-15-2011, 08:34 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You can connect the + and - output from your solar controller directly to the + and - on your battery, or to the + and - on the fuse panel where the battery connects.
Same result.
Mine goes directly to the battery. If you have two batteries connected in parallel, connect to either one, they will both charge.
Yes, it's that simple.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 06-15-2011, 08:45 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Jim is absolutely correct. That's exactly how I wired mine. The controller output is wired to one of my two batteries.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-15-2011, 10:21 PM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
I would tie the solar system ground to the "black" wire on the shunt (the copper plate) so that the ammeter will "see" the solar charging current.
If you use a battery monitoring system such as a Trimetric, this is required for them to function normally.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-15-2011, 11:31 PM   #5
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
There will proably be directions to connect the black on the battery first, red on the solar last. Important, whichever the directions want. Little electrical gizmos don't like to be woke up and fried backwards. Might check the polarity on your solar panel wires before you connect them, I had mine perfectly...except the inside of a supplied connector was switched, so it was reversed polarity.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 06-15-2011, 11:56 PM   #6
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Is this how it should be connected
Bruce,
Old 06-18-2011, 11:09 AM   #7
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Bump
I am ready to connect this now and really need to know where the LOAD lines form the solar controller should go, or can I omit them.
I have the battery part figured out but the load side is confusing me.
Bruce,
Old 06-19-2011, 11:22 PM   #8
NevadaGeo's Avatar
Genoa , Nevada
They're #5 in your diagram, they go into your controller.
NevadaGeo
Where does this heavy black wire go? malconium Electrical - Systems, Generators, Batteries & Solar 3 05-31-2011 01:07 PM
How much solar do I really need sgoetz Generators & Solar Power 12 05-19-2011 08:28 AM
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 08:21 PM
Burnt wire on my univolt MonaxLisa Batteries, Univolts, Converters & Inverters 11 03-23-2011 12:31 PM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
