Old 01-11-2016, 04:01 PM   #1
Manheim , Pennsylvania
I need help shopping for a generator
I would like to buy a pair of the Honda 2000 generators with parallel connection. I have a single 15,000 btu AC so I need enough juice for that. The Hondas would do a great job but are so very expensive! I am considering a single Champion 3100 from Costco instead. Opinions?
Champion 2,800W Running / 3,100W Peak Digital Inverter Gas Generator (CARB-50 State compliant)
Jukeboxfun is offline   Reply With Quote
Old 01-11-2016, 04:11 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I don't think it has enough watts, especially on a hot day...
Old 01-11-2016, 06:23 PM   #3
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
A few Airstream owners say that a Yamaha EF2400ISCH can start and run a late model 15,000 BTU AC.
kscherzi is offline   Reply With Quote
Old 01-11-2016, 07:34 PM   #4
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
The description says it's powerful enough to start a 15,000 btu AC, wonder about higher altitudes though. My question is with the decibel rating of 58. Generally that rating is specified as a range based on load or whether it's running in eco-mode or not. For the Honda 2000i that range is 53 to 59 decibels measured a 9 feet from the control panel side of the Generator. So is the Champion Db rating of 58 (at 23 feet) at load or running in eco-mode?
At that price, I think I would be tempted to buy it and try it. Costco has a good return policy if it doesn't work out.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 01-11-2016, 07:51 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
2 Honda 2000s will run a 13.5 AC but a 15k may be pushing it.
Old 01-11-2016, 07:56 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Check out the decibels and the weight and compare them to the Hondas.
The Honda "companion" generator may be more useful than the non companion because it has a 30 amp plug. When I just need one benny that is the one I bring.
Old 01-11-2016, 08:26 PM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
I plan to buy one of those Champion inverters this year. I recently saw a man using one with his RV. He was running his 15k btu air with no problem. It was plenty quiet for my needs.
As far as Champion goes. I have a 4000 watt at my house. It starts first pull. I have used it during power outtages. I have a 1800 at another piece of property that I use 2-4 times a month for 4-7 hours at a time to run lights. I have had it right at 3 years. I have had zero troubles.
CRH is online now   Reply With Quote
Old 01-11-2016, 08:45 PM   #8
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Woooow here! 4000 KW parellel will definitely run a 15 AC unit!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 01-11-2016, 08:52 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have two 2,000 watt Yamaha generators. I chose the Yamaha over Honda because the parallel cable has a 30 amp RV female connection. Just plug in your Shore Power cord. No twist lock to RV adaptor required.
Old 01-11-2016, 11:23 PM   #10
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
I have the champion 3100w remote start. Runs 15k AC fine. Worked at ~6500ft no problem, even started from inside the trailer with the remote on a cold 20f morning without the choke!
I am very happy with it. Got about 20 hours on mine in 12 months and it is barely broken in!!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 01-12-2016, 09:39 AM   #11
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I don't think I could lift a 3100watt generator into my Ram 2500. That would be the only issue I have with this size. The remote start model of the Champion 3100 is about 13lbs heavier than the non remote start model. This model is probably around 100lbs when fueled up.
I would like to take the generator to my Airstream storage occasionally but I can't keep the generator in the truck all the time.
While I don't think I would like to dry camp where its so hot you need to run a generator all day it would be nice not to have to mess with two small generators in parallel.
Kelvin
Old 01-12-2016, 10:21 AM   #12
Hampton , Virginia
If you go with the pair of Hondas, look up Mayberrys online. Their package deal for the two includes the parallel cables and is about $100+ cheaper than on Amazon.
Getaways is offline   Reply With Quote
Old 01-12-2016, 10:26 AM   #13
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
As usual you get what you pay for, I've a couple of honda generators, one 200o watt is7 year sold, still operates like new. There is a reason Honda's are the ones others are always compared to.
jtwind is offline   Reply With Quote
Old 01-12-2016, 10:32 AM   #14
1968 26' Overlander
Portland , Oregon
Harbor Freight has their 2500/2200 genny on sail right now with coupon for $399. It is what it is.
Inverter Generator - 4.7HP, 2500W Inverter Generator
Ok. Begin Sinophobia now...
AirstreamPDX is offline   Reply With Quote
New Trailer Shopping List RoadKingMoe Our Community 44 08-19-2017 09:56 PM
Noob Owner shopping list..help?? 59ORLander 1960 - 1964 Overlander 21 05-14-2014 09:29 PM
Huggable Hangers (HSN Shopping) Foiled Again Off Topic Forum 4 02-08-2005 09:30 PM
Airstream Shopping Jayhawker Towing, Tow Vehicles & Hitches 8 02-02-2004 12:10 PM
Shopping-96 Excella 28-Need Input LabWagGun Our Community 6 04-30-2003 01:04 AM
