Old 04-15-2016, 10:34 PM   #61
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Originally Posted by Stormalong View Post
I occasionally tune into this thread and continue to be amazed that people don't run their air cond on a single Honda 2000. We have a 2015, 25fc with a factory a/c. We turn off the converter so it doesn't pull power, verify hot water heater and refer are on propane, then fire up the single Honda 2000. Make sure it is not on ECO mode so it is able to make full power, then enjoy the cool air. No issues!
Be Happy that your 2000 will fire your air conditioner. Lots of folks air conditioner will growl and let the smoke out with out 30 amps starting power. I wouldn't promote others to try to fire their air conditioner without the proper power it wants unless you like to hear them complain you helped them let the smoke out and want you to help them put the smoke back in.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 04-16-2016, 05:03 AM   #62
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
We have a 300 amp-hour lithium iron phosphate battery attached to a Magnum MSH-3012 hybrid inverter that will draw the necessary power from the battery and invert it so the Honda 2000 watt generator can start the 13.5K BTU air conditioner in our 2015 23D. Once started the Honda can run the cooling just fine. Every time the thermostat cycles, the process is repeated. We also have 500 watts of solar panels on the roof to recharge the battery.
Continuous power from the Honda is 13.3 amps or 1600 watts with momentary power capability of 2000 watts 16.6 amps.
Old 09-23-2016, 02:01 PM   #63
2023 25' Globetrotter
Manheim , Pennsylvania
I finally got around to making a video about the Smarter Tools generator.
Jukeboxfun is offline   Reply With Quote
Old 09-23-2016, 02:24 PM   #64
2017 25' Flying Cloud
Gold Country , California
Thanks for the review Jukebox! We've had our Smarter Tools generator for a little over a year now and haven't had any issues. Fuel usage on it is great! Typically I would fill up the tank before we leave on a long weekend and rarely will it go below 1/2 tank. I used it primarily to charge the batteries.
Have you used them with your AC? I plan to get another one eventually with the parallel kit and would love to see them on a newer 15k AC.
NorCal Matt is offline   Reply With Quote
Old 09-23-2016, 06:38 PM   #65
Yes I had them hooked up parallel to test it and it worked great for the air. Haven't tried it camping yet though.
New Trailer Shopping List RoadKingMoe Our Community 59 05-26-2020 08:22 AM
Noob Owner shopping list..help?? 59ORLander 1960 - 1964 Overlander 21 05-14-2014 09:29 PM
Huggable Hangers (HSN Shopping) Foiled Again Off Topic Forum 4 02-08-2005 09:30 PM
Airstream Shopping Jayhawker Towing, Tow Vehicles & Hitches 8 02-02-2004 12:10 PM
Shopping-96 Excella 28-Need Input LabWagGun Our Community 6 04-30-2003 01:04 AM
