Old 01-17-2016, 09:08 AM   #43
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Our Yamaha generator turns ten years old this year. Over seven first years I ran regular gas in it. Over two years ago I started running only ethanol-free in it, same for my chain saw. No longer a concern about running it dry before putting it away. Too, we always run it under load once a month for at least 1/2 hour.
We decided ten years ago not to buy genset for generator or microwave capacity. Many many boon docking days since then, and over 2,500 nights camping. We have never wished we had power for the a/c. Our windows open wide on all sides of the trailer, we have two large roof vents (the Fantastic fans), and sometimes it's just cooler outside.
We don't have to boondock in hot places. Happens occasionally, but not enough to require equipment purchases. Makes me consider, maybe we could start logging hi and lo temps with our camping spots record. Nah, doesn't matter.
250 watts tillable solar on the roof, 460 amp hours battery capacity. We haven't needed the generator so much in the summers as winters. Found we sometimes get more and more behind with winter sun if we're in cool climate. One of major benefits of genset, to me, was for 110vac air compressor and drill motor if needed field repairs on driving days.
The 1,000 watt Yamaha sits small in our truck's busy bed, is easy to lift out for use, sips gas, is quiet. We'd do the same again. Hopefully we'd get as good service life as this one is providing too.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 02-14-2016, 11:08 PM   #44
solar powered full-timer
1970 27' Overlander
Helena , Montana
Hi there, this thread is good timing for me. I just today bought a 1970 Overlander and am shopping for generators. I found this place, PPL, that is running a special on a pair of Yamaha EF2000is and the parallel cord for $1827.53 and free ground shipping to me here in Montana. -Caleb
calebofey is offline   Reply With Quote
Old 02-15-2016, 09:35 AM   #45
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Good find. I see they have a single generator for $899 as well. As I'm in the market I might pull the trigger.
I did notice that Yamaha now has a 2nd generation version out. I can't imagine the first generation is suddenly obsolete, but for $100 is it worth getting the new one?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 02-15-2016, 09:51 AM   #46
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Yamaha says the new version has an upgraded controller that can power a much wider range of applications. .... whatever that means. Be nice if they were more specific.
kscherzi is offline   Reply With Quote
Old 02-15-2016, 10:04 AM   #47
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Exactly. Begs the question, what applications can it power now that it couldn't before?
I have an email out to Yamaha customer service. Will see the response.
Old 02-15-2016, 11:06 AM   #48
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Yamaha's corporate site is *slightly* more informative. They say it has "improved output characteristics between 1600w-2000w" so perhaps it's got quicker response to putting a load on it.
David
Old 02-15-2016, 03:34 PM   #49
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I got a reply email saying it is "more efficient." Whatever that means. Sips less gas?
Old 02-15-2016, 07:32 PM   #50
kscherzi's Avatar
Images: 24
For the $100 premium you deserve a better answer.
Old 02-15-2016, 07:36 PM   #51
LAWBC's Avatar
2012 23' Flying Cloud
Victoria , British Columbia
Yamaha EF2400ISCH
A few Airstream owners say that a Yamaha EF2400ISCH can start and run a late model 15,000 BTU AC.
I have and it runs my heat pump .
Laurence
LAWBC is offline   Reply With Quote
Old 03-09-2016, 11:48 AM   #52
huntington beach , California
Generator advice needed
I am totally in learning curve mode with my 23 International and everything related. We are currently looking at generators that will allow us to boondock for longer periods of time. Would two of these be a good choice so that we can power the AC when needed (not big fans of an AC but sometimes...)? Thanks AS community!
Honda EU2000i Portable Generator, 2000 W $999
bshoun is offline   Reply With Quote
Old 03-09-2016, 05:10 PM   #53
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I bought 2 Yamaha 2,000 watt generators from PPL for less than $900 each. I like the fact that both generators are identical. The parallel cord has a 30 amp RV plug as well. No need to adapt to a twist lock like on a Honda setup. Just plug the coach in.
Old 03-09-2016, 05:44 PM   #54
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I bought one Yamaha 2300 it runs everything and weighs in at about 73 pounds...
Talis gentium ceciderunt.
Old 03-09-2016, 05:54 PM   #55
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We have converted our pair of Honda 2,000 watt generators using the GenXDirect propane conversion kits. Can power one off the grill port on the front of the Airstream. No gasoline to carry anymore or worry about it fouling the carburetor.
switz is online now   Reply With Quote
Old 03-09-2016, 06:28 PM   #56
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I have a Yamaha 2000. Like it.
Ron
Ron A is offline   Reply With Quote
New Trailer Shopping List RoadKingMoe Our Community 44 08-19-2017 09:56 PM
Noob Owner shopping list..help?? 59ORLander 1960 - 1964 Overlander 21 05-14-2014 09:29 PM
Huggable Hangers (HSN Shopping) Foiled Again Off Topic Forum 4 02-08-2005 09:30 PM
Airstream Shopping Jayhawker Towing, Tow Vehicles & Hitches 8 02-02-2004 12:10 PM
Shopping-96 Excella 28-Need Input LabWagGun Our Community 6 04-30-2003 01:04 AM
