Old 09-21-2008, 07:03 AM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by mustang View Post
Shut you main breaker off!!!
If you are connecting to your house, and plugging in to a recepticle. If not you will blow your Gen Set when the power comes on, unless you have, and Isolator set up. You also dont want to waste energy by bleeding it back into the lines
It's also dangerous for the lineman that thinks the power is off, and electrocutes himself with the electricity you are providing.
Old 09-22-2008, 10:04 AM   #16
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Power Coming
Thanks again for all yall's help you guys are great as always. Yes we shut the main breakers off. The linemen are working on our power this morning it should be back on this evening. We have been sleeping in the AS with the ac which has been nice. Luckily it really has not been that hot overall. We were really fortunate that things were not much worse for us, we have seen a lot of great people helping one another.
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 09-22-2008, 12:20 PM   #17
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
We're still off here since 2PM EDT Sunday a week ago. You had a 36 hour head start on us, so maybe if you get yours on today, we'll have ours on Tuesday or Wednesday! LOL!
Glad to hear you're close and things were not worse for you!
Maurice
Old 09-22-2008, 01:57 PM   #18
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I had one of those 5000 watt construction type generators, a Campbell Hausfield. It would NOT run the Coleman A/C on my coach. The voltage would drop down to 98 volts and trip the breaker in the A/S. I now have a Generac 7500 watt genset with the 30 amp 120 outlet and it works great.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 09-27-2008, 10:44 PM   #19
1972 23' Safari
Tallassee , Alabama
You may be able to rewire the generator so that it has both circuits in parallel. DON'T DO IT AT THE OUTLETS - LOTS OF FIRE AND SMOKE.
Basically a generator is a motor being run backwards. Many motors will run on either 120V or 240V depending on how they are wired. Generators are the same thing.
First, look in the manual. Next, try contacting Husky Technical support.
A quick look at the schematic will tell you if the unit can be rewired.
Tom Bray
Tom Bray is offline   Reply With Quote
Siberian Husky Heaven Ganglin Off Topic Forum 1 03-08-2008 11:13 AM
Husky vs Robin vs Reese / Drawtite Hitches flyfishfred Hitches, Couplers & Balls 4 01-10-2008 04:17 PM
Husky brand WD hitch? gparker Hitches, Couplers & Balls 1 06-11-2007 11:23 PM
10 watt halogen bulbs Foiled Again Off Topic Forum 13 01-12-2006 06:54 AM
Kill A WATT™ 53flyingcloud Our Community 6 06-20-2003 12:08 PM
