09-06-2018, 06:24 PM
2008 19' International
Lincoln
, Nebraska
How to remove OEM solar panel mounting brackets?
Hello,
We have a 2008 19' International with a 50w factory solar panel on the roof. I'd like to remove that panel and brackets and add a couple 100w panels using VHB tape and Sikaflex.
My question is how to remove the existing factory mounted brackets. They appear to be bolted on and then covered with a white caulking compound, maybe just really old Sikaflex.
Has anyone removed these brackets? What was your process?
Thanks in advance,
Mike
Mike (W9LG) and Jennifer
2008 International 19' Ocean Breeze, Equal-i-zer WDH
2015 Ford F150 4x4 Lariat SuperCrew EcoBoost, 3.55, Max Tow
09-13-2018, 12:09 PM
2016 27' Eddie Bauer
Billings
, Montana
Mike,
I just removed my factory (I think, I am the second owner) solar panel mounting brackets from a '16 27 EB. I was shocked at what I found. Three out of the four brackets that attach one solar panel (installed with self tapping 1/4-inch screws) were (it appears to me) attached only to the skin of the roof missing the structural rib underneath. This was the case for the other one of the 2 panels as well. I plan on fabricating new brackets with a bigger footprint (from 3/8" 2.5 x 2.5 AL angle stock) and using VHB tape + Sikaflex 221 as well to re-attach.
To remove the factory brackets, I removed most of the caulk on the screw head, then simply backed out the screws on each bracket.
Have you done this yet? If so, I am curious what you may have found.
Couple pics of the bracket I have.
https://www.dropbox.com/s/no9rmuhxml..._0805.JPG?dl=0
https://www.dropbox.com/s/ffr2jenol8..._0822.JPG?dl=0
09-13-2018, 12:53 PM
Billings
, Montana
Try these instead of dropbox links.
09-13-2018, 12:59 PM
Billings
, Montana
09-13-2018, 01:59 PM
Lincoln
, Nebraska
Egan,
Thanks for the response. No I haven't tried removal yet. I'm surprised it was so easy for you to remove the brackets. Kinda scary, surprised they're not flying off at speed. Interesting.
Thanks again,
Mike
09-13-2018, 08:04 PM
Billings
, Montana
Do your brackets look like the posted pic? Just wondering if this was a factory install on my EB. If so, really disappointing.
09-13-2018, 08:33 PM
Lincoln
, Nebraska
Sure looks like the same bracket. I'll be removing mine soon, and I'll let you know what I find.
Mike
09-13-2018, 10:39 PM
Billings
, Montana
Thanks for the pics. Yep, look the same.
10-20-2018, 08:14 PM
Billings
, Montana
Solar Panel Brackets
Finished fabricating and installing one set of panel brackets. Used 3/16" 2x2 Al angle cut to 3" lengths. Brackets mounted with 3M VHB tape and sealed with Alpha 1021.
10-21-2018, 08:59 AM
2018 25' Flying Cloud
Portland
, Oregon
If what you have on your roof is Silkaflex, alcohol works as a solvent. If the roof is painted be careful as strong denatured alcohol will also soften the paint.
