Old 09-09-2016, 01:22 PM   #1
Dobber's Avatar
2012 25' FB Flying Cloud
Queens , New York
Question How to connect portable panels ?
i just purchased a GP portable solar panel and am unsure how to connect it to my two batteries on our FC. + to - on the same battery or + on one battery and - on the other ?
thanks in advance.
Dobber is offline   Reply With Quote
Old 09-09-2016, 01:24 PM   #2
Dobber's Avatar
Queens , New York
the two positive terminals are linked together and the negatives also so i guess that is hooked up in parallel ?
"Common Sense is like Common Courtesy,
ain't neither one too common these days"
Old 09-09-2016, 02:17 PM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yes, they are connected in parallel so it does not matter as long as you do + to + and - to -. There are also adaptors tat allow you to plug it in to your 7 prong trailer cord.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-09-2016, 03:15 PM   #4
1979 23' Safari
Wayland , New York
thanks in advance.
Recommend same terminals that the ones going in and out of the trailer are connected to. Should be + on one battery, - on the other battery. This helps ensure they charge more evenly.
Old 09-09-2016, 04:55 PM   #5
Dobber's Avatar
Queens , New York
Thumbs up Thanks guys ...
Larry and Joe.
Old 09-10-2016, 11:16 AM   #6
CAV
CAV's Avatar
2004 25' International CCD
Dubuque , Iowa
Get the GP adaptor that plugs into your 7 pin plug. And get the 30' extension cord. Works slick!
CAV is offline   Reply With Quote
Old 09-10-2016, 03:37 PM   #7
Dobber's Avatar
Queens , New York
Thanks Cav, i will definitely check them out.
Old 09-10-2016, 05:05 PM   #8
2014 27' FB International
Clearwater , Florida
I made a positive / negative pigtail using 50amp Anderson connectors and eyelet ends attached to the pos/neg terminals of the battery. I attached said connector to the side of the battery box for easy access. I have made a complete kit using two Renogy suitcase 100w panels and a Renogy 30a charge controller. All connections are made with the Anderson connectors allowing one or both panels to be used. I soldered all connections to ensure low voltage loss.
ChuckFeldt is offline   Reply With Quote
Old 09-11-2016, 06:18 AM   #9
Dobber's Avatar
Queens , New York
damn. sounds like a sweet setup.
i wish i lived closer to Clearwater !
Old 09-11-2016, 09:46 AM   #10
Tincampers's Avatar
Sneedville , Tennessee
Our portable system came with soldered Anderson connectors. The stranded cable broke right at the end of the solder pretty quickly. I hope you have better luck. I replaced them all with MC4 crimped connections and haven't had any issues.
What cable are you using between the battery box and the solar panels?
Tincampers is offline   Reply With Quote
Security for Portable Solar Panels CAV Generators & Solar Power 11 09-01-2016 07:26 AM
Portable Solar Panels Fancypantsas Batteries, Univolts, Converters & Inverters 8 08-09-2016 10:43 AM
Solar panels vs portable generators ashe Electrical - Systems, Generators, Batteries & Solar 19 01-19-2015 07:18 AM
Portable Solar Panels migriffin Sprinter and B-van Forum 31 04-11-2014 06:56 AM
portable dish connect to satellite receiver? tsaxy Computers, Internet & Satellite 4 09-03-2008 09:59 PM
