Old 09-07-2010, 08:44 AM   #1
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
How much power do you get off your solar system
This weekend Tamara and I were at Heron Lake State Park in NM. On Saturday I showed the My sisters kids a movie on our projector. On sunday the panel produced 1KW of power to replace what we used that evening and what we were using at the time. I have two 130 watt Sun panels and a Rogue MPPT controller. It has data for the last 31 days of production. It had only produced 500 watts max before.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 09-07-2010, 09:30 AM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
What is your house battery setup? and was that 1kw at 12 or 120 volts?
Old 09-07-2010, 05:54 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Kw!
KW is Kilowatts. It is a power measurement. The voltage does not matter.
100 amps x 10 volts = 1000 watts = 1 Kilowatt
10 amps x 100 volts = 1000 watts = 1 Kilowatt
It takes a lot bigger wire to handle 100 amps than it does to handle 100 volts and have the same power available.
Old 09-13-2010, 10:17 AM   #4
1969 25' Tradewind
1983 34' Limited
Images: 85
The amps coming in ranged from 17 amps to 3amps. I was outside and could see the output from the controller. It was a cloudy day and the sun would be covered by clouds off and on.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
Old 09-13-2010, 11:13 AM   #5
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I am having trouble understanding what you are saying.
If the peak reading of the current was 17 amps at 12 volts, the power being produced at that instant was nominally 204 watts or .204 kilowatts. If you want to talk about how much energy was generated for the day, then that is measured in kilowatt hours. So, are you actually saying that 1 kilowatt hour was generated during the day? Assumming 13 1/2 hours of daylight, that would be an average of approx. 6.2 amps thought the day. I am guessing that is what you are saying. Correct?
Regards,
Ken
Old 09-13-2010, 12:43 PM   #6
1969 25' Tradewind
1983 34' Limited
Images: 85
That is what I am saying. Which was approx. 83 amp hrs
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
Old 09-13-2010, 01:42 PM   #7
Solar panels
Solar panels are great, but.....
They all have the same problem.
The maximum output depends on the position of the sun, with respect to the panels.
The maximum output will always be when the sun is 90 degrees above the panel.
As that angle changes, the maximum power output will drop.
Therefore, seldom will the panels put out absolute maximum.
Having a "sun chaser" that tilts the panels to keep the 90 degrees, is the way to go, but not for an RV. That only works great for a fixed installation.
Bottom line, is that it's very difficult to determine the total wattage output for a period of hours, as it's constantly changing.
Some owners use 2 or 3 panels, side by side on the roof of their Airstream, mounted facing fore and aft, to better average out the panel outputs.
Then you must make sure that the sun will move from side to side on the trailer, instead of from front to back.
But still, solar panels are the way to go, but like many things in our lives, you have to learn how to use them for optimum performance or rewards, as well as the limitations.
Old 09-13-2010, 01:45 PM   #8
Ag&Au's Avatar
Are your panels on the roof of the trailer or portable. If they are portable, I'd be interested in a picture of how you support them.
Regards,
Ken
Old 09-21-2010, 12:20 PM   #9
1969 25' Tradewind
1983 34' Limited
Images: 85
My panels are on top of my AS
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
Removing Batteries with Solar System Airstream 65 Generators & Solar Power 2 11-08-2009 05:39 PM
Need help with my solar system... cclarkego Generators & Solar Power 39 08-09-2009 12:48 PM
Help us learn to operate the solar system. ClayandPerry Generators & Solar Power 15 01-31-2008 10:37 PM
Solar Charging System Question Mod-Streamer Generators & Solar Power 1 01-16-2006 10:33 PM
