Old 05-27-2015, 01:49 PM   #1
1987 31' Excella
Erin , Ontario
How many watts/panels/batteries do we need?
Hello, we have a 31' Excella on some acreage near Owen Sound, Ontario. I have a Sunforce 4 panel , 80 watt solar package that I bought from Costco, hooked up to (2) 12 volt deep cell batteries ( parallel wired) . We would like to be able to run lights as required @ night and the Propane fridge electronics for 2-3 days max. We always run out of juice into day 2 @ best. How much more do we need & of what ? Thanks for any help.
RJB54 is offline   Reply With Quote
Old 05-27-2015, 01:55 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Depends on your solar exposure. Here in the Deep South I can get away with ~200 watts and live pretty large unless we have a run of cloudy weather. Typically I can recharge in 4-5 hours in the winter what I use overnight running the furnace and lights. That is with a 100 watt portable panel, that I can move for optimum gain.
Given how far north you are and the probability of cloud cover you may need more battery and a whole lot more solar. Eighty watts is obviously not enough. I would expect you are going to need in the 240 watt range just to break even.
Aaron
WBCCI #XXXX AIR #2495
Old 05-27-2015, 02:11 PM   #3
SteveH's Avatar
Common Sense , Texas
Don't know if you've done this or not, but you can reduce the amount of power you use for lighting by about 75-80% by switching to all LED bulbs.
Regards,
Steve
Old 05-27-2015, 02:31 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
I forgot about LED... I have switched my house, RV's and barns over. I don't even think about non-LED stuff anymore.
LED's will definitely help reduce current draw if you use the lights much at all. On my RV's I have found the furnace, fridge control board and the smoke/CO and LP detectors to be the biggest draws. We use lights pretty sparingly and seldom watch television. I much prefer a good book.
Aaron
Old 05-27-2015, 04:15 PM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Is your solar package 80 Watts total? 80 watts into the batteries is going to give you on the order of 26 amp-hours a day - or roughly 4 hours of running your furnace.
I'm saying you need more than 80 watts of panels, but Lewster would be The Man to pitch in here.
Old 05-28-2015, 12:25 PM   #6
2007 25' Safari FB SE
Los Angeles , California
Have you considered using tow six volt batteries and running them in series? That is what I have and can do pretty well. I guess running the batteries in series gives you more amp hours.
RMichler is offline   Reply With Quote
Old 05-28-2015, 12:56 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
You have to connect 6 VDC batteries in series to get to the required 12 VDC. The amp/hour rating stays the same. Series connections increase voltage. Parallel connections increase amperage.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 05-28-2015, 02:31 PM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Looks to like it would be easier to start the 2000 watt honda generator......
Old 05-28-2015, 03:43 PM   #9
2013 16' Sport
Boulder , Colorado
nice little calculator here:
Solar Sizing Calculator
Seecue is offline   Reply With Quote
Old 05-28-2015, 04:22 PM   #10
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
You must be using incandescent lights. First, get LED replacements. If I run every light in my AS except inside cabinets I use 29.2 watts. Your fridge electronics should not be too much a draw. Two nights would be 10 hours as I run the lights for about 5 hours each night. One of those OEM light bulbs is I believe 14-28 watts depending on type, I had two types in mine - a 1141 and another one. That is a huge difference. My 48 hour light use at max would be 292 watt-hours DC. Your 80 watt panel should be able to add around 64 watts per hour avg. into the system for around five hours, then less as daylight weakens. That is 320+ watts DC. This example is how they figure it and tell you how much you need. They told me that I would need a 300 watt system to boon dock indefinitely as I used 226 watt-hours each day and needed the other wattage to charge the battery plus the low draw times, etc. I plan more off and on use like you so I am looking at 150-200 watts. I use two group 24 batts with a total of 184 amp hours or 1764 watts that needs charged to keep topped. The simplified calculation is 1 watt for every amp hour.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-28-2015, 11:32 PM   #11
lewster's Avatar
To start, you should have LED lighting as mentioned above as incandescent lights are real power hogs. Next, you have to determine your approx. amperage use for each day you wish to be off grid. This is done by listing every appliance you desire to operate, the estimated amount of time for each and their amp draw. The total will give you the amount of amperage (or wattage, depending on which measure you use) you can reasonable expect to draw from your batteries each day.
Next, multiply this amount by a factor of 4. Say you calculate a 38 amp draw each day. This would be a total of 152 amps per day. I would then suggest a battery bank with a capacity of 300 amp/hours minimum which would allow your batteries to be discharged to the 50% level each day.
Next, depending on your latitude, the type of batteries you have and seasons that you will be using the trailer off-grid, you then plan the size of your solar array. Liquid cell batteries take more amperage and more time to re-charge due to their higher rate of internal resistance. AGM batteries are far better and quicker to re-charge, and lithiums are lightning fast for recharging.
Based on where you are and starting with liquid cells, I would use a 600 watt array, AGMs; 400-500 watt array and lithiums; 300-400 watt array, all with an MPPT charge controller of sufficient capacity to handle the array.
Over capacity will allow you to have full batteries each day, even in overcast conditions and as I have been told by clients, battery charging from their solar array even in the rain!
Any of these configurations will allow you to stay off-grid far beyond the 2-3 days you are experiencing now.....but be forwarned! You don't get systems like these for Costco prices!!!
Old 05-29-2015, 09:59 AM   #12
1987 31' Excella
Erin , Ontario
Thanks, we are already switching our house over, makes good sense to do the same with the trailer.
Old 05-29-2015, 10:24 AM   #13
1974 Argosy 20
Kooskia , Idaho
And you can even consider using 120 volt LED bulbs powered by a small inverter in your Airstream as an inexpensive way to do the conversion.
See my post on the subject:
http://www.airforums.com/forums/f447...am-126542.html
Old 05-29-2015, 10:52 AM   #14
2012 28' International
Prince Edward County , Ontario
We have a basic system installed by Can-Am when we picked up our trailer two years ago. We have a 160 watt GO Power panel mounted on the roof (with no inverter) used to the power the lights, fridge electronics, furnace, etc. We upgraded the batteries to Lifeline AGM Group 24 six months later. We have no problem in the U.S. south west running lights, furnace (at night), etc. when we have a reliable source of sunlight. With cloudy, cold weather (i.e. Grand Canyon this past April), we can last at most two days being careful. During a one month period (April to May) from Grand Canyon to Moab, we dry camped about 15 days with no problems keeping the batteries at full charge. In Newfoundland last summer, we were OK after two days of cloudy weather in Terra Nova National Park; then again we didn't require the furnace in summer.
That said, we are considering a generator for periods of cool, cloudy weather which we may encounter on Vancouver Island this fall.
Cyclist is offline   Reply With Quote
Max. watts solar roof panels 25ft. Safari? HCR Generators & Solar Power 12 09-04-2014 08:24 AM
How many watts needed for a 31ft Land Yacht bobbett750 Electrical - Systems, Generators, Batteries & Solar 9 12-03-2013 09:20 AM
I need her to power 6500 watts.. rocknhair Generators & Solar Power 8 07-13-2013 06:12 AM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
Anybody know how many watts an old Univolt would draw (circa 1979 31' International?) wacnstac Batteries, Univolts, Converters & Inverters 10 04-22-2007 06:10 PM
