Old 10-29-2015, 03:17 AM   #15
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I have more generators than I care to admit, all for different applications.
We rarely need A/C so when we do we just get a site with electric.
I carry a Honda 1000 just to charge batteries and it fits in the rear storage compartment. I run it dry for storage.
2012 Dodge Durango Hemi/AWD
Old 10-29-2015, 04:26 AM   #16
martian's Avatar
2012 31' Classic
Naples , Florida
Rust, I carry two Honda 2000i generators for use when shore power is unavailable. The generators can run in parallel providing sufficient to power the microwave and AC units simultaneously. Got the generators for full-timing use because the trailer was my home and I wanted my creature comforts. I store them in a large Pelican case locked away under cover in the pickup bed. A second box holds the gas can that supplies fuel to the generators similar to the setup in an outboard motor boat.
The trailer also has two solar panels to assist in keeping the batteries charged. That is their sole purpose.
Whatever generator you end up buying, please get a quiet one. I will be most appreciative when parked near you.
martian is offline   Reply With Quote
Old 10-29-2015, 04:46 AM   #17
ottawa (greely) , Ontario
Originally Posted by idroba View Post
I own a Honda 3000 and a Honda 1000 inverter generators. I have had them both apart and have done service work on a friends Honda 2000 inverter generator. None of them are belt driven. All are direct coupled. I don't know where the idea got started they are belt driven.
As for use when camping, I have a solar system on both my Airstream and Argosy and boondock almost exclusively. I virtually never camp where AC is needed. I have stopped even loading my Honda 1000 in the Jeep when I go camping as solar is all I need.
The honda 1000 and 2000 ,3000?watt inverter generators have a rubber type timing belt this is were people are getting the idea about a belt ,this is from the arguments on honda 2000 or Yamaha 2400? Brand comparisons, the Yamaha uses gear to gear for timing ,it will last longer ,cost more to fix,it will weigh more,be noisier,the honda uses a rubber type belt not sure on material breakdown as it could have Kevlar in its composition, it cost less to replace, it's quieter,lighter, but doesn't last as long as gears used on the Yamahas mind you a timing belt on a car should be replaced at approx 90000.0 miles depends on make of car, that's a lot of generator hours , and for those people that don't follow maintenance and like to push things my friends Volkswagen diesel ,replaced his timing belt at 200000.0 miles ! That's pushing it . If the timing belt breaks it (could )cause internal engine damage. The honda generator has no maintenance on replacement of this timing belt! Hope this sets the story straight on the rubber belt story! Oh I don't carry (my honda )generator unless I'm going to use a.c. ( that's like never)
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 10-29-2015, 04:47 AM   #18
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Idroba, the belt is listed as a part to replace. Also:
The belt is clearly shown and the plastic oil slinger. It is an overhead cam design versus the yamaha Pushrod with no belt. Also, see this video at 2:58. They compare the two brands on smaller generators. Note too the engine life rating. The belt works well in the Honda but it is one more thing to service and potentially something to go wrong. I shop in depth and scrutinize things, some may not matter to others. It's just my findings and opinion.
Both brands are good; however there are differences. If you watch the second youtube video, the differences are clear.
Richw46, yeah the closest dealer/service center to you in Lexington, KY is Somerset, KY or Mount Sterling, KY- not too far but a drive. I used to live in Carroll County. Both Honda and Yamaha have lots of service centers though I am not sure you should need service that often.
Scamp, the engine life the Honda is half of the Yamaha. The 2000 engine is half the size of the 2400 at 98cc versus 171cc (123cc on the 2000 Yamaha) and there are several other differences though each model would have to be compared.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 10-29-2015, 04:58 AM   #19
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My honda 2000 is a direct drive,it does have belt to run the overhead camshaft like the ohv automotive engines, I have had no problems with it in 10 years of ownership......
Old 10-29-2015, 05:11 AM   #20
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
Originally Posted by Rust View Post
Hello again
Still looking for a generator and still not sure which one to get and I know Honda and Yamaha are the best but still looking at options. Leads me to question as to how many carry a generator while they are traveling for emergencies or just to have for convenience.
George
George,
I carry for convenience....and use a belt to keep my knickers up. :roll eyes:
Red, Blue....both very good.
ID:	251264   Click image for larger version
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-29-2015, 05:24 AM   #21
2006 25' Safari
Images: 8
Nice Case Robert.
Old 10-29-2015, 05:43 AM   #22
Thumbs up
Rod,
24gal ActionPacker.
I improved the lid seal with 1/2" foam tape, and carry the LPG stuff in a separate bag, no fumes, carried in the AS.
Name:	HONDA CONVERSION add vid pix2-3 007.jpg
PFC
"Tahawus"
RLC
John Prine
Old 10-29-2015, 08:41 AM   #23
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Originally Posted by rodsterinfl View Post
I ordered mine with the tri-fuel option so the modification was under warranty.
Yamaha EF2400iSHC Generator
Is the propane regulator mounted on the side of the casing. The website doesn't really show any details of the tri fuel mod.
Have you run your 13.5k AC with this unit on propane successfully.
I've accidently run my 13.5K AC with my Airstream connected to my house 20amp circuit via the trailer's 30 am cord plus a 30 amp extension with 15amp adapter so I would think it would run off this generator.
If the tri fuel is an addon by this company is the warranty only through their company or is it honored by any Yamaha dealer?
Kelvin
Old 10-29-2015, 09:10 AM   #24
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
We bought the pair of Honda 2000's and have not taken them with us on the road yet. We mainly stay at full hookup sites and have these in case of power outages at our house. If the main house power goes out we can live in the AS with our own power. I can also use them for maintenance power for the areas of our property where we don't have access to power but need to run tools on electricity. They have worked great so far and are very quiet.
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 10-29-2015, 09:59 AM   #25
1974 Argosy 20
Kooskia , Idaho
The implication in post # 2 and #5 was that the generator section was belt driven from the engine. That is what I was disputing.
Yes, there is a very small belt which runs the over head cam on the Honda. There is no listed replacement interval, and a huge number of engines these days use belt driven over head cams. In my opinion it is a total non issue.
Both Honda's and Yamaha's are great generators.
Old 10-29-2015, 10:12 AM   #26
Minipad's Avatar
2013 23' FB International
2013 25' Flying Cloud
In the Rockies, 6700' , Colorado
2 Yamaha 2000s
We carry two Yamaha 2000 gens and 300W of solar, everywhere, everyday.
150W of the solar is on the roof of the trailer and the other 150W is on a rack (tilts as needed) that sits over the bed of the pickup truck tow vehicle. The 150W panel on the truck can either be controlled by the solar controller on the Airstream or a separate solar controller that charges a bank of additional batteries in the back of the truck.
Minipad is offline   Reply With Quote
Old 10-29-2015, 10:12 AM   #27
Safari Streamer's Avatar
2015 28' Flying Cloud
Ladson , South Carolina
We are very satisfied with our Honda 2000. However, we seldom use it. We only carry it if we know we are going somewhere that will require it. We are usually at campgrounds with hookups - not much dry camping- so we don't pack it. We did just use it at home during the major flood in Charleston as we lost power and I needed to charge cell phone!
Kathy Narowski
#2555
SC Coastal Unit
TAC-SC5
Safari Streamer is offline   Reply With Quote
Old 10-29-2015, 10:13 AM   #28
Refugee from Napa, CA
Photobum's Avatar
Madison , South Dakota
I have 400w of solar which is great. But I also have TWO Honda 2000 generators.
One reason:
Clouds.
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
How many miles are too many??? crabbey1 Tow Vehicles 26 03-29-2014 07:34 PM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
00 Airstream 190 CLASS B*93K Miles*Generator*Sleeps 4*MANY UPGRADES eBay Watch Airstreams on eBay 0 02-20-2012 07:10 PM
OT: How many trailers is too many? Amazing short video. SilvrSausage On The Road... 1 09-10-2008 04:44 PM
Honda Generator - Carry in Van PARKS1963 Generators & Solar Power 8 08-21-2006 07:51 PM
