Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 09-26-2006, 05:33 PM   #1
The Flintstones
The Flintstones's Avatar
Profile:  1970 27' Overlander
Houston , Texas
How Long without City Power
HI
Have searched but can't seem to find and answer so I'll ask. New to AS owner of one month now and have most of what I need working.
How long can one go without pluging into city power and I assume the AC draws too much power using battery alone. We are going to Llano, Texas deer hunting and won't be anywhere near power all weekend. I realize this is exactly what the AS is for, just unsure as to what to expect as it will be the maiden voyage.
thanks for any information
James
The Flintstones is offline   Reply With Quote
Old 09-26-2006, 05:53 PM   #2
Gunnyusmc
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Shore Power
The AC will not work on Battery's.
Everything in the trailer draws amp's, what you use and how long will determine how long the battery last. Also do you have one or two batterys.
When I deer hunt, I take a generater.
Honda's are the best.
Don
Gunnyusmc is offline   Reply With Quote
Old 09-26-2006, 06:04 PM   #3
The Flintstones
Houston , Texas
Thanks for the reply
I have one battery, a generator is not an option right now acording to the wife . Also the PO put in a fridge that I assume runs off of 110. So I guess we would open windows and use fan and lighting at night would be kept to a minimum.
James
Old 09-26-2006, 07:30 PM   #4
silverback
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
A couple of ideas
Well you probably don't have time to install solar panels so I would get a new deep cycle AGM battery. If you don't run a lot of stuff that could last a couple days. Are you sure that your fridge doesn't run on gas too? Your tow vehicle is actually sort of a battery charger. Not an ideal solution though. With solar and a Honda EU2000 you could last quite a while.
-KL
4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
silverback is online now   Reply With Quote
Old 09-26-2006, 08:16 PM   #5
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
I have gone 3 days, no problems. I now have a honda EU1000 to top the battery when needed and could go much longer.
Richard
Charter Member Four Corners Unit
Old 09-26-2006, 08:21 PM   #6
Creampuff
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
We often boondock for 3 days on one deep-cycle battery, but I admit we use lighting sparingly. Run your frig on gas and you should have no problems getting 3-4 days out of a decent battery IMHO.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 09-26-2006, 09:49 PM   #7
Danetree
Profile:  1972 25' Tradewind
Wentworth , South Dakota
I can go three days on my one battery with no problem. This includes the furnace at 20 deg nights. We are very careful with lights and other use.
Danetree is offline   Reply With Quote
Old 09-27-2006, 01:02 AM   #8
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 70
We've gotten 3 days using a deep cycle battery. Could have gone longer, but haven't yet determined exactly how long that is. The meter read low (yellow) but hasn't ever hit the red. We currently have no fridge, so we're just using juice for the lights and water pump. Most of my hunting/camping friends that boondock for extended periods of time supplement their power with a generator.
JB
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is online now   Reply With Quote
"Power On" indicator davidz71 Electrical - Systems, Generators, Batteries & Solar 23 09-15-2005 09:52 AM
Power Jack Problems Daniel Conroy Electrical - Systems, Generators, Batteries & Solar 4 04-15-2004 10:40 PM
External Power Cord Replacement jstaad Electrical - Systems, Generators, Batteries & Solar 3 01-23-2003 06:16 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
