Old 07-05-2010, 07:47 AM   #1
2008 23' Safari FB SE
Boulder , Colorado
How long will gas last in generator?
We just finished our first boondocking trip and our next trip is currently planned for late August. How long can I leave the gasoline in the generator sitting before it goes bad/gums up the carburator?
I know I can add stabil but just wondering if anyone has experience leaving it for a couple of months without issues.
Gens: 2 Honda EU 2000i units.
bonginator is offline   Reply With Quote
Old 07-05-2010, 07:59 AM   #2
Central , Mississippi
The only time I have gone past 30 days it gummed up the carb on my 2000i
Carb cleaning on one of those is no fun.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-05-2010, 08:00 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Temperature makes a big difference. Two months is pushing it in the summer.
We'll probably have a long thread on the benefits or not of Sta-bil since the topic brings posters out of the woodwork whenever it comes up. It is my view that it does nothing to improve the storage life of gasoline, based on both experience and my understanding, such as it is, of the chemistry involved.
Old 07-05-2010, 08:13 AM   #4
Boulder , Colorado
Interesting -guess I need to get the siphon out and then run until empty!
Old 07-05-2010, 08:32 AM   #5
Thats pretty much what I do. I usually run it dry then pull off the side cover and drain the bowl to get the last few drops out. Its so easy to do it's just not worth taking the chance of a plugged carb (again)
Old 07-05-2010, 09:17 AM   #6
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
On the long long long honey moon...Sean says they will give power for about 19 hours.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 07-05-2010, 09:25 AM   #7
2006 19' Safari
New Smyrna Beach , Florida
I regularly leave gas treated with Marine Stabil in my Honda 3500 for six to eight months without issue. That way I'm set for hurricane season.
nsbcpa is offline   Reply With Quote
Old 07-05-2010, 09:35 AM   #8
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
Two year old gas with sta-bil in mine fired right up during a power outage a couple of weeks ago. I filled it back up and treated it with sta-bil once again before returning it to storage. After two years, I figured it wasn't going to run, but it started right up and ran just fine. I'm convinced that the stuff works.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 07-05-2010, 09:42 AM   #9
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
I run the gas out of the carb, but leave it in the tank with no problems , gas over a year old using stabilizer.
SilverHoot is offline   Reply With Quote
Old 07-05-2010, 10:00 AM   #10
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
My small engine mechanic said to siphon all but a pint out and start it every month or so. He also said to make sure that you put a load on the generator to exercise the generator itself as well as the engine.
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 07-05-2010, 12:10 PM   #11
Maniacal Engineer
barts's Avatar
Menlo Park , California
Silverhoot has it right...
Carb jets get plugged because the light components in gasoline evaporate and leave heavier stuff ("varnish") behind. If you leave the gas on, the carb refills from the tank all the time and you've got plugged jets. Turn off the gas supply and run the carb dry, and you're fine.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-10-2010, 01:53 PM   #12
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
- Bart
I just picked up a Honda EU2000i, and if I am inderstanding the manua correctly the engine shut off switch both cuts the igntion and closes the fuel supply valve so it wouldn't be possible to shut the fuel off and run the carb dry.
That is certainly what I would have preferred to do. Is there a simple workaround on the EU 2000i that allows you to do this perhaps?
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-10-2010, 02:34 PM   #13
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I have a small engine shop and I recommend not leaving untreated fuel in a tank or carburetor for more than 30 days. All major mfgrs. now are recommending the same. I do use Sta-Bil in my own personal equipment year round. I only store about 10 gallons at a time.(2 /5gallon containers,plastic) This means I have treated fuel in everything at all times,that includes mix for weedeaters and chainsaws and backpack blowers. Most of the time my saws dont get started for a yr or more.
I have not experienced any carburetor problems in the past 20 yrs I have used the product.
So treat your fuel source and you should be ok.
Roger
PS Please don't try to mix fuel treatment in the tank, only in the fuel source,the container you carry to fuel to your genni in, be it 2 gal 5 gal or whatever,always treat the source.Only use 2 1/2 oz per 5 gal.
Good Luck
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-11-2010, 06:53 AM   #14
Boulder , Colorado
eu2000 carb drain
I drained the carbs on my eu2000 this weekend - very easy process.
It is in the manual and took mess less than 5 mins per generator:
Burn gas out of main gas tank until empty or low
Open front servicie cover
Turn drain screw below carb and catch gas coming out of drain tube
Open rear top service cover
Disconnect spark plug cover
Turn gen switch to on and pull starter 3 times - more gas drains from tube
Close all up in reverse starting with spark plug cover
I am letting mine sit for 30 days so we;ll see how they start.
The Long, Long, Trailer by Clinton Twiss overlander64 Off Topic Forum 274 12-02-2013 07:57 AM
96 Airstream Class A RV Ford Gas Generator Solid Wood eBay Watch Airstreams on eBay 0 05-02-2009 01:00 AM
The LONG LONG TRAILER Movie Trivia rseagle Off Topic Forum 26 06-23-2008 03:43 PM
Our long, long trailer (AKA 19' CCD) crazylev 1997 - 2004 Bambi 60 05-11-2006 12:53 AM
