Old 07-11-2010, 09:25 AM   #15
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Interesting discussion. I've got two Yamaha generators, and I always do the same thing ... when I'm shutting down for more than a refuel or a few hours, I shut off the fuel shutoff petcock at the tank and let the engine run until it shuts itself down because it runs out of gas (I'm supposing that this drains the fuel line and the float bowl, etc.) Then I open to float bowl drain (they've both got small screws for this - just in case I could get a few more drops out, but seldom get aything. Then crank the engine a few revolutions to suck out anything remaining in the jets, and I think I'm good to go. At least have never had a problem.
And like Roger, I use Sta-Bil in the big cans when they are filled ... might not do any good, but doesn't seem to do any harm!
AirsDream is offline   Reply With Quote
Old 07-11-2010, 10:17 AM   #16
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
With the newer fuel requirements with cleaners things are better but every 3 months adding a little tech-ron fuel cleaner will keep everything sparkley clean. I used it in a gas motorhome for years and probably didn't fire the onboard generator up once every 3 months .
arcamedies is offline   Reply With Quote
Old 07-11-2010, 12:44 PM   #17
1972 Travelux Princess 25
Cobourg , Ontario
With Stabilizer added gas will keep up to several years depending on temperature. Without it, several months.
Drain the gas and use it in your lawn mower or put it in your car tank. If you add stabilizer fill the tank and run the engine for a few minutes. This way you will be sure the gas in the carb has stabilizer in it. The reason for filling the tank is that the less air in the tank the less condensation and corrosion.
When you restart, a shot of methanol will pick up any water. Methanol is the same thing as dry gas sold at gas stations, but cheaper.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 02-06-2012, 01:55 PM   #18
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Is it necessary to drain the carb if you shut off the gas and run the generator dry? I have a Honda EU3000is and want to make sure I don't gum up the carb.
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 02-06-2012, 02:56 PM   #19
r carl's Avatar
Lin , Ne
I would being that it so easy and quik.
Old 02-06-2012, 02:57 PM   #20
Mrs.Mod's Avatar
1977 31' Sovereign
Fresno , California
Drain it!
Hi there,
30 days is about as long as gas will last (in California) without a stabilizer. California gasoline is worse than gasoline everywhere else! It's formulated to comply with Emisson regulations, so it burns a little cleaner but it does not last long at all. A stabilizer with help keep if good for about 4-6 months.
I worked in a Honda motorcycle/generator dealership service department for a few years and carb cleans were the most commom repair.
Even if you have bad fuel it may fire up, but expect it to be tempermental. it may run fine for a while but eventually, the bits of debris will clog the passage ways and cause dying or rough running. Sometimes, the debris can settle and it may run again, but it won't be great until the debris is removed.
Adding stablizer can be easy to forget. Make a point to be diligent about it and you will save yourself a headache. A month goes by fast! Don't forget the stabilizer!
Cheers!
Cara
Mrs.Mod is offline   Reply With Quote
Old 02-06-2012, 03:22 PM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I always use sta-bil during storage. I do leave the treated gas in tank.
Ours has dual use LPG conversion, I shut down gas supply, (top clamp above yellow LPG line), run 'til it stumbles, shut down and drain carb. SFSG.
Name:	HONDA CONVERSION add vid pix2-3 006.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-06-2012, 03:58 PM   #22
2005 30' Classic
Images: 12
So, do they have propane carbs for Honda or Yamaha gens?
Propane lasts much longer ...
GetOutDoors is offline   Reply With Quote
Old 02-06-2012, 05:11 PM   #23
1981 31' Excella II
New Market , Alabama
DO NOT PUT ETHANOL in your generator. It is sits more than a few weeks that stuff will cause corrosion. If you use pure gas and something like Stabil you can probably go 6 months. Stabil does not work with Ethanol. If you can run it periodically that would be the best. Maybe once a month. Shutting off the gas and running it till it dies will help a lot. If you leave the gas on it tend to evaporate from the carb and then more comes in and it evaporates till you have a lot of gunk in the float bowl. This gunk won't ignite even if it makes it through the jets. It will fowl your plug.
Perry
Old 02-06-2012, 06:09 PM   #24
Thumbs up
GoD,
Yes....same carb, modified venturi to accept the LPG supply line.
Yamaha too...
I was able to use the Honda during a power outage this Winter without having to fill the gas tank, nice feature.
Name:	PROPANE CONVERSION, HONDA 2000 001.jpg
PFC
"Tahawus"
RLC
John Prine
Old 02-06-2012, 06:50 PM   #25
2005 30' Classic
Images: 12
Originally Posted by ROBERT CROSS View Post
GoD,
Well, that's the way to go: forget the gas and all the related issues and go with propane!
For this reason I went with a propane outfit (Onan Microlight). Mounted it under the queen in the back, starts from a switch inside, and runs off the propane tanks of the trailer.
Don't have worry about it walking off and don't have to worry about fouled carbs.
Propane - its good for what ail's them!
Old 02-07-2012, 07:09 AM   #26
1981 31' Excella II
Propane is a great idea. Many home backup generators use propane because of the ability to sit for long periods of time and start right up.
Perry
Old 02-07-2012, 09:16 AM   #27
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
I'm applying information gleaned from the wildland firefighting community regarding portable pumps.
When I shut down my generator, I use this sequence: While the engine is running, shut off the fuel petcock. As the engine starts to stumble (from lack of fuel), push the choke lever to full choke. It will smooth out. When it starts to stumble once again, shake the genset a little bit. (This will get the last drops of gas that may be 'hiding in the corners' somewhere.) I find this easier than taking carb bowls or drains loose.
I keep stabilizer in the fuel at all times. Generator starts right up, first pull nearly every time (unless it's really cold outside, then it's the 2nd pull.)
I also run the generator every 30 days, under some load.
All kids are gifted; some just open their packages earlier than others. - Michael Carr
JazzDad is offline   Reply With Quote
The Long, Long, Trailer by Clinton Twiss overlander64 Off Topic Forum 274 12-02-2013 07:57 AM
96 Airstream Class A RV Ford Gas Generator Solid Wood eBay Watch Airstreams on eBay 0 05-02-2009 01:00 AM
The LONG LONG TRAILER Movie Trivia rseagle Off Topic Forum 26 06-23-2008 03:43 PM
Our long, long trailer (AKA 19' CCD) crazylev 1997 - 2004 Bambi 60 05-11-2006 12:53 AM
