Old 09-29-2017, 11:38 AM   #1
1978 31' Sovereign
Brooklyn , New York
How do I hook up both a power converter and solar panels to my '78 Airstream.
I tried to look through some threads so as not to duplicate, but I may have missed something. I have a 78 Sovereign and I'm trying to figure out how to start working on the electrical system. It's got the original transformer, and I've read that it's a good idea to replace it. I'm leaning toward the progressive dynamic 60 amp power converter charge wizard. What I don't understand is the exact capability of this device, do I also need an inverter for providing 110 power? or is an inverter built into this device. I also have a few solar panels, and I want to hook them up to top the battery off. Can I hook them to the power converter or do I need a separate solar charge controller, and if I get that can I connect it directly to the battery?
estock is offline   Reply With Quote
Old 09-29-2017, 12:43 PM   #2
2000 30' Excella
Toledo , Ohio
I just installed one in mine but I can't answer your questions . call Progressive Teck support .
woodfox45 is offline   Reply With Quote
Old 11-07-2017, 10:47 PM   #3
1970 25' Caravanner
Incline Village , Nevada
estock. Any follow up on your questions? What did you end up setting up?
Jeremy9107 is offline   Reply With Quote
Old 11-07-2017, 11:24 PM   #4
1980 24' Caravelle
vallejo , California
hello estock, you will need a solar controller for your panels. hook the controller to the batts, hook panels to the controller. you can mount your pa nels on your roof, or remote them like i do. your comverter should be replaced; it does not have an inverter in it.
ke6gkv is offline   Reply With Quote
Old 11-08-2017, 01:44 AM   #5
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
My method may be a bit convoluted and overly complex, but here it is:
http://theouterlimits.ws/projects/airstream/solar/
WayneG is offline   Reply With Quote
Battery charging: role of the converter when there are solar panels? Runaground 2016 - Current International 32 10-30-2017 05:47 AM
Solar panels in series or parallel - but why not both? drboyd Generators & Solar Power 19 10-16-2017 08:39 PM
Startup Voltage for Solar Charger and 12v solar panels ggreen63304 Generators & Solar Power 12 09-01-2017 06:58 PM
My Hook Things Won't Hook Sbb Rock Guards, Segment & Window Protectors 2 04-12-2015 06:16 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
