Old 06-06-2010, 06:44 PM   #1
Long Beach , California
How do I connect a Honda 1000?
Ok, maybe dumb question but how do I connect a Honda 1000 gen to my 08 Sport with 30 amp outside plug? Do I make a 30 amp to 110 pigtail? Can I buy that? Will it automatically charge my battery? Or 110 to 110 and plug into outside outlet...
Thanks!
BC
bcripe is offline   Reply With Quote
Old 06-06-2010, 06:48 PM   #2
silverback's Avatar
2006 28' Safari SE
1981 28' Airstream 280
Phoenix , Arizona
Smile
Yes. You need to get an adapter/pigtail, 30 amp to 20 amp. They are available at any RV store (Camping World for sure). And it will definitely charge your batteries. A 1000 watt Honda will probably not let you make popcorn in the microwave though.
-Ken
4CU Charter Member
1981 Excella 280 Turbo Diesel Motorhome
silverback is offline   Reply With Quote
Old 06-06-2010, 06:49 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
You can buy a 30 amp to 20 amp converting plug at any RV store and probably walmart. Your regular 30 amp cord will plug into it.
The 30 amp cord and plug is 110 volts, just can handle higher current than a regular plug like you are used to seeing,
Your battery will charge from the converter in your trailer just as though you were plugged into a normal outlet
Rick Davis 1602 TAC TN-2 K8DOC
PP VAC 2002-03
61 tradewind, 70 Globetrotter
69 Ambassador 64 Overlander
Old 06-06-2010, 07:05 PM   #4
azflycaster's Avatar
1975 25' Tradewind
Phoenix , Arizona
Images: 63
I got a pigtail at Wally World and I like it better then the small adapters. The small adapters seems to get loose in the generator from the weight of the plug.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 06-06-2010, 10:14 PM   #5
But that one will not plug into my trailer side. I found some 30-15 amp connectors. I assume this will work?
Amazon.com: Marinco Marine Electrical Shore Power Pigtail Adapter…
Old 06-06-2010, 11:39 PM   #6
Gene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
You use the 30 amp cable that came with the trailer and plug the male end into the adapter or pigtail Richard described which is then plugged into the generator output.
Gene
Help to connect TV to Stereo mojo Audio, Video & TV 0 05-11-2010 12:11 PM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
Honda EU 3000 vs 2x Honda EU 2000 vajeep Generators & Solar Power 93 07-23-2008 11:02 AM
Where to connect 12v monitor weevey22 Batteries, Univolts, Converters & Inverters 5 02-25-2007 08:56 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
