Old 04-14-2015, 09:02 AM   #1
2004 19' Bambi
2010 23' FB Flying Cloud
Bridger-Teton , Wyoming
How can I tell if my 2004 Bambi is prewired for solar?
I just bought a new to me 2004 19' Bambi. I'm still getting to know it so How can I tell if it is prewired for solar?
veg hed is offline   Reply With Quote
Old 04-14-2015, 10:58 AM   #2
dznf0g's Avatar
Oswego , Illinois
I assume...eh hmm, that AS uses consistent wire coloring. But if you find blunt cut non connected green and yellow wires close to your batteries and/or electrical center, I would be confident you are pre-wired. Adequately? Depending on your power needs, maybe not.
-Rich-
Old 04-14-2015, 11:47 AM   #3
2002 19' Bambi
Lafayette , California
We have a 2002 19' Bambi and it came pre-wired for solar, so yours surely did, also.
We have had solar on ours since shortly after buying the trailer new and used the pre-wiring. There has never been any problem with that wiring. Of course, there is so little space on the roof of the 19' that it would be really hard to have panels which could overload the wires.
Below is a scan from our Bambi about the solar pre-wire.
Tim
Name:	19 Bambi Solar.jpg
Tim A. is offline   Reply With Quote
Old 04-14-2015, 12:26 PM   #4
dznf0g's Avatar
Oswego , Illinois
Just to be clear, I wasn't insinuating any kind of overload situation. Merely pointing out that the losses in amperage delivery may be adversely affected by the relatively small wiring AS provides and depending upon the OP's power requirements, that may or may not be significant.
-Rich-
Old 04-14-2015, 04:57 PM   #5
2004 19' Bambi
Tim
I found the red/black wires up front and the yellow green wires behind the front light like the description you posted shows. Where are the yellow/green wires behind the control box?
Old 04-14-2015, 05:50 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
How about on a 2006 Safari 23 rear bed model. Where would the wires be located?
MICHAEL
Old 04-14-2015, 05:52 PM   #7
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
How many panels do you have up there? I was thinking of it.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 04-14-2015, 07:36 PM   #8
2002 19' Bambi
It has been a long time since I did the install, but the cover for our control box is in the closet and I think I found the wires there.
As for the question of how many panels you can put on a 19', we put one on the front of the roof on the street side. I suppose you could put two more behind the AC.
Tim
Old 04-15-2015, 12:01 PM   #9
2005 19' International CCD
Campbell , California
We have a 2005 19 and used the solar pre-wire. The yellow/green wires were marked and coiled near the battery buss under the front bench and in the ceiling between the AC and front vent. The factory pre-wire was judged to be adequate due to short wire run and modest load after efficiency changes - all LED lights, all 12v appliances/chargers, new variable speed fantastic fan.
Due to roof space limitations, used to 50W panels. Considered relocating TV antenna to allow for a 100w panel, but the system has worked very well as-is for our camping needs. Some pics attached.
Good luck with your project.
~ Ken
Name:	Solar System - Roof Layout.jpg
ID:	236358   Click image for larger version
Name:	Solar System - Controller.JPG
Name:	Solar System - Remote Monitor.JPG
KenS is offline   Reply With Quote
Old 04-15-2015, 04:51 PM   #10
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
If you look in the owners manual, which is available online, it will say whether it is prewired for solar.
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 04-15-2015, 07:03 PM   #11
2004 19' Bambi
~ Ken
Awesome! Thanks for posting those pics. Those really help me put a picture to what I have to do. I might pick your brain a little bit about the install...
Old 04-15-2015, 10:29 PM   #12
Glad to help if I can. Lots of good information on this forum.
Old 04-15-2015, 10:51 PM   #13
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
You can also contact customer service at airstream.com . They may take a day or so to get back to you, but are very helpful.
Len n Jeanne is offline   Reply With Quote
Old 04-16-2015, 12:05 AM   #14
2004 25' Safari
1968 17' Caravel
Fountain Valley , California
Just a future trouble shooting note for solar.
I have a 2004 AS with solar from the time the AS was new. Six months ago I had problems with the solar charging and with the solar controller. After doing my own trouble shooting I was convinced that I needed to either replace the solar controller, or at a minimum send it back to the factory to have it repaired. I had checked the 10 amp fuse in the battery compartment and it was good, but the controller was operating intermittently. (Blue Sky Solar Boost 2000e controller). I called the Blue Sky on this to see what they would charge to look at and repair the controller, and wound up talking to the president. He said he was 95% certain that if I physically replaced the 10-amp in-line fuse holder that it would rectify the problem. I was doubtful, but a $2 fuse holder replacement was easy to do, and to my surprise the system was back working 100% reliable again. (kinda humbling, but nonetheless I recommend you make a mental note of it, maybe even buying a replacement in-line fuse holder from Walmart or somewhere else to have on hand).
WindyJim is offline   Reply With Quote
Awning type - How can I tell? tiniree Awnings 22 11-09-2016 01:14 PM
Backup Camera Prewired? jtripp Sprinter and B-van Forum 0 03-21-2013 07:27 AM
Prewired Solar in 1999? cwf Electrical - Systems, Generators, Batteries & Solar 6 03-20-2013 09:44 PM
Prewired for Solar??? 2010 Int'l THEPILL Generators & Solar Power 0 02-10-2010 04:21 PM
can somebody tell me something about the bath section on some airstreams lower BobNetherlands Plumbing - Systems & Fixtures 2 10-21-2003 01:55 PM
