Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 02-01-2008, 12:23 PM   #1
walter1
Profile:
Hour meter for Honda EU2000i
Is there a fairly simple way to install an hour meter on a Honda EU2000i generator?
walter1 is offline   Reply With Quote
Old 02-01-2008, 12:25 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Simplest way I know is to wire it to the 12v part of the unit. It will only "run" when the generator is running.
Change is inevitable, except from a vending machine
AIR#2611
Old 02-01-2008, 01:24 PM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Walter,
Look up SenDec on Yahoo and you will find multiple sources for SenDec Corporation hour meter/tachometer devices. Even a number of Yamaha generator sources sell the SenDec hour meter. I installed one on my Yamaha 3000iSEB generator just after I got it and it works great. All you have to do is roll the end of the wire attached to the meter around the spark plug wire going to the spark plug. The meter has a peel and stick backing so that you can mount it to the generator where you want it.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-01-2008, 01:24 PM   #4
DFord79
DFord79's Avatar
Profile:  Currently Looking...
Yakima , Washington
You can buy an hour meter at sears for around 30 dollars. Other places have them also. All you need to do is mount the meter on the unit (its rea small) and attach the lead to the spark plug wire by wrapping it around the wire. This is the way many small garden tractors and small engines have hour meters attached. IT is very very simple.
DFord79 is offline   Reply With Quote
Old 02-01-2008, 01:28 PM   #5
DFord79
DFord79's Avatar
Yakima , Washington
Redundant posts at exactly the same time....He who asks...gets answers....lol
Old 02-01-2008, 04:33 PM   #6
walter1
Profile:
thanks for the help
Old 02-01-2008, 05:45 PM   #7
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Look for something called "Tiny Tach", it wires around the sparkplug wire and shows RPM and run hours. Fully automatic.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
HiHoAgRV is online now   Reply With Quote
Old 02-01-2008, 05:48 PM   #8
zamboni
zamboni's Avatar
Profile:
Either of the above mentioned items should be available at local Lawn & Garden Equipment supplier...or Grainger
zamboni is offline   Reply With Quote
I Love my Honda EU2000i Generators panabax Generators & Solar Power 13 08-13-2008 08:29 PM
best online price for honda eu2000i? beckybillrae Generators & Solar Power 11 10-30-2007 07:24 PM
Noise level of TWO (2) honda eu2000i DFord79 Generators & Solar Power 31 09-05-2007 10:38 AM
Honda EU2000i dmac Generators & Solar Power 33 07-18-2007 10:24 PM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 06:33 PM
