Old 06-19-2008, 04:13 AM   #99
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by BillTex View Post
Suburban...
Well all you need for that is 12v for the fan, right? So you'd be fine with a 1000. I don't know how many watts a coffee maker is, but it ought to be under 1,000 I'd guess.
Old 06-19-2008, 05:41 AM   #100
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Originally Posted by olddog299 View Post
Bob, it's really going to depend on how big the draw of your coffee maker is. My little 4 cup Mr. Coffee only draws about 750 watts when keeping the coffee warm, but when the coffee is brewing it wants just as much juice as it's bigger brother - that 12 cup wanker. Then they both expect at least 1250 watts... too much draw for a 1K genset to handle. So, Bob, is there any real reason to eschew the old stovetop perk coffee maker or that old Melitta decanter you have gathering dust in a box in the garage?
My '90 Excella draws about 9.1 amps/hour when operating the heater with the burner firing and about 8 a/h when it's just the fan blowing. The Uni-volt accounts for a hair over 1 amp of that load - that's ALL that is going to batteries in the form of a charge. So, yes, you could power the furnace and charge the battery, albeit very slowly and inefficiently. That's about 1100 watts, by the way (1092)
The real answer appears to be a battery conditioner/charger with all the hi-tech digital goodies like float charge and the ability to de-scale the battery plates and pull teeth on a bad day... Just take that Uni-volt out of the equation entirely.And why that is really requires your Tesla impersonator. Or a competent electrical engineer or Lew Farber or someone similar...
thanx wil, after reading this it makes me think that a 1000 is about useless. It then makes sense to step up to the next size, and if you want to carry just 1 genset, and possibly run your A/C, you may as well go with the Yammi 2400. The Honda 2000 would make you coffee, and charge your batts, but that is about it. The Yammi 2400 would do it all with 1 unit.
I think my next project will be an updated 3 stage charger/converter and a nice Yammi 2400...
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 06-19-2008, 01:35 PM   #101
_
...Given these conditions,
-charge batteries
-run a coffee maker
-and a heater, but not at the same time....
which would be better choice?...
thanx wil, after reading this it makes me think that a 1000 is about useless... you may as well go with the Yammi 2400....
ok bill....
given YOUR original conditions ONLY...
and the 2 gensets considered...
the red eu1000i is the best choice.
-they are more widely available
-can be purchased used MORE easily at a discount
-are VERY easy to sell at nearly the original "used" price...
-and there are WAY more service centers for the reds.
still neither 1000 will run many coffee pots or heaters that are in the common 1200-1500 watt range for power consumption...
i've got an electric coffee maker that is 650-800 watts but they aren't common and usually r just 4 cup size.
so buying a used 1k red is an easy introduction, 2 learn IF and how much u wanna be a gen-setter,
and IF the decision is, gen-setting is not 4 u, they are very easy to pass on.
but don't waste money of lpgas conversion UNTIL knowing IF u really are a gen-setter.
it is very easy to NOT charge the batteries while using the small gensets...
JUST PLUG THE APPLICANCE into the genset DIRECTLY, bypassing the trailer systems completely.
now given YOU also suggested running the a/s was NOT needed, but still considering your other parameters...
the best option for u is still a red eu2000i...
-it will power most space heaters and coffee pots, just not simultaneously
-it will power blow dryers and vacuum cleaners and many power tools.
-it will run the water heater on electric (1000 will not)
-it weighs less and takes less space than a blue 2400...
-and there are STILL more service centers and vendors...
-and a LARGER pool of people using them (look for used or sell it) in the marketplace...
-it is VERY easy to parallel IF/WHEN ya wanna run a/c...
-the red 2k is quieter than the blue 2400, according 2 the specs.
-and while a 2400 is the smallest SINGLE unit that 'might' run the SMALLER a/s (11k btu)
-ya still gotta remember to switch fridge to gas and NOT use electric water heat...
-dometic RECOMMENDS 3500 watts as the MINIMUM genset for the 13/15,000 btu a/c...
-so if doing much a/c OR with the larger a/c or in the hopes of NOT killing the ac...
i'd still opt for 2x2000, so that every other appliance doesn't have to be OFF, to just 'barely, maybe' get the ac up2speed...
and 2x2000 reds is QUIETER underload than 1x2400 blue or the other LARGER blue genset...
as always YMMV and these views those of d'poster, and do not represent the site or its sponsors and ...
this opinion is void where prohibited...
cheers
2air'
Old 06-19-2008, 02:41 PM   #102
2008 31' Classic
Sweet Valley , Pennsylvania
I agree with Air on the above points. I love running my 2000'sx2 .......or x1 if I am not on AC or other heavy use. It is just flexable as can be!
TROPHYJIM2 is offline   Reply With Quote
Old 06-19-2008, 05:46 PM   #103
2005 30' Classic
Images: 12
I just lightly scanned this thread and have a question (pardon me if I missed it somewhere): does anyone know the expected lifespan of the different makes/models/fuel-type in terms of hours?
GetOutDoors is offline   Reply With Quote
Old 06-19-2008, 06:20 PM   #104
RivetED's Avatar
North Central , USA
I do not recommend this but, my Honda 2000 has run our 11K A/C on 2 different occasions (once for a week-end, once for an afternoon). Had to run it with the ECO 'off' (full-power) and keep an eye on gas, (it ran out just in time for breakfast!)....BUT when in a pinch the little red came through.
P.S. This is not my recommendation, I just got stuck and had to improvise, the 2 in parallel is the way to go, plenty of reserve power...
RivetED is offline   Reply With Quote
Old 06-21-2008, 05:28 PM   #105
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Send a message via AIM to Airboss Send a message via MSN to Airboss Send a message via Yahoo to Airboss
I run my little 4 cup coffee pot off my 1000 alot.. Not problems at all..Works just fine but not sure about the bigger 12 cup units...
"If your not living life on the edge... Your taking up too much room. WANTED, Single lady who loves and has a Airstream. Please send photo of Airstream and Tow Vehicle
Operation "SAVE RUDY" Strike Team (Charter Member) RALPH, KW8G..WBCCI # 4201 Metro Detroit & 4CU TAC # MI-007
Airboss is offline   Reply With Quote
Old 06-21-2008, 06:30 PM   #106
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My EU1000i has no problem with my coffee pot...
Richard
Old 06-21-2008, 07:49 PM   #107
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
This thread has taught me a lot about generators but most of all it has taught me Airstreamers like to drink coffee in the air conditioning,
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 06-21-2008, 10:56 PM   #108
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
It's here!
Hi, well my new Yamaha 2400 arrived Friday. I carefully unpacked it and read all the information that came with it. My wife likes the color; Goes with the stripes on our Airstream. Today I added oil and gas, turned on the ignition switch, turned on the fuel valve switch, pulled the rope starter, and it amazingly started on the very first pull. The generator is a bit larger than it looks in pictures; [I haven't actually seen one in person before] And it wasn't as hard to pick up as I thought it would have been; Better stance and grip with the two handles. Two things that I read that I haven't heard on this site are: (1.) You need to keep it three feet away from walls or objects so it doesn't overheat. [I have seen these running in truck beds, up against a corner] (2.) You cannot use the 12 volt and 110/120 volt system at the same time. The real tests may be months from now. Also the "Factory Service Center" is in Cypress, Ca. about five miles from my home so it doesn't matter that the local Yamaha dealers are not generator dealers.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 06-22-2008, 04:02 AM   #109
Wayne&Sam's Avatar
Images: 21
So if you can break that habit, you don't need a generator at all!
Old 06-23-2008, 06:34 AM   #110
1 Rivet Short
1989 25' Excella
Thanx 2air, yes our A/C is 13.5 so I guess that becomes a non-issue. Again, we have probably used our A/C a total of 3 times…just don’t need it here in New England. Future trips will be out West though…
And Richard, we also carry and use a percolator when off the grid…but I guess we are kind of coffee snobs…it just don’t taste the same as drip
Wayne & Sam-you must be kidding! Give up my java? I’ll die with a coffee in one hand, a beer in the other, and a gun in the other….wait a minute that 3 hands...oh never mind...
Bill
Old 10-20-2012, 07:40 PM   #111
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
It is amazing. I was searching on the Internet about generators and a link led me right back to the forum! I found this older thread but I wanted to add some info. I have been shopping for a generator since February (9 months) and finally pulled out the card and got one yesterday. Primarily I shopped Honda and Yamaha. There are some differences besides sound and color that should be mentioned. First, Yamahas are direct drive versus the Honda belt drive. Also, the boost technology on the 2400isHC and the 3000SB is handy for starting motors like AC units. One person in the thread a few years back asked the question about rated life expectancy. The Yamaha ratings are higher by EPA testing. I purchased a 2400isHC tri-fuel model and I hope it all works out. I like the idea of propane for a once-in-a-while used engine fuel that leaves no residue to ruin a carb.
I will let others know of my experience. I do know that the 2400isHC was load tested and was able to maintain power to a 30amp circuit for around 10 seconds. That is above spec but it says a lot about this one unit. I found an artlcle that tested Yamahas against Hondas and here was some great info on sound and fuel usage per hour during their testing:
Sound tested at 20 feet distance (have two dB ratings for quiet mode/normal mode if available on unit)
Fuel usage tested at normal settings on all generators with same proportion load applied
Honda EU1000 52/57dB 9.3 hrs/gal
Honda EU2000 52/58 dB 7.3 hrs/gal
Yamaha EF1000is 54/57 dB 10 hrs/gal
Yamaha EF2400is 54 dB 7.4 hrs/gal
As you can see, the Yamaha and Honda are very similar in sound and fuel usage. The Yamaha 2400is provides more power on tap but with 0.1 more fuel usage. I looked up Yammy dealers that service generators and came up with about eight places in my city. Again, this is only an update to my findings.
Old 06-08-2016, 08:57 AM   #112
redeagle313's Avatar
NE , Indiana
Question for future reference: we sold our trailer three years ago, but kept our Yamaha 2400 generator for emergency use around home and for our next Airstream. The Yamaha was able to run the 13500 btu AC on our former trailer, an '05 28' International. Will it be able to run a 15000 btu AC on a current or late model 25-28' Airstream?
Just looking ahead to future Airstreaming ;-)
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
redeagle313 is offline   Reply With Quote
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
Why are Honda Generators quiet? JimGolden Generators & Solar Power 48 02-18-2008 05:34 AM
Cummins vs. Yamaha vs. Honda! Sean Michael Generators & Solar Power 26 06-27-2007 02:24 PM
Yamaha Generators, again... Tavis76 Generators & Solar Power 63 10-17-2006 07:21 PM
Yamaha Generators Bilouie Generators & Solar Power 27 04-23-2006 04:14 PM
