Old 01-21-2013, 08:45 PM   #1
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
Honda vs. Dometic
We are looking to buy a generator. Honda seems to be the Gold Standard with Yamaha on its heels. I see where Dometic also makes a 3000KW generator rated at 59D. It is substantially less than a Honda by about 50%. Does anyone have any experience with this generator? I know they make a lot of other RV items.
Ron
Ronman is offline   Reply With Quote
Old 01-21-2013, 09:21 PM   #2
I've heard almost nothing on the Dometic generator.
If you are looking in the 3kW range, here is what I've read from forums I've been on:
The Honda 3000 is a top tier model.
The Yamaha 3000iSEB has the advantage of being able to use the starter battery for 10 seconds if you need 500 more watts.
The Boliy 3000 watt generator has good marks. It is about $1300 last time I checked, uses the same engine as the Yamaha, and is rated at more wattage (peak and sustained ) than the Yammy.
There are other Chinese brands which are getting better over time, but because they have so many generations, finding parts can be dicey, so you either have something perfectly working or something that is only useful as scrap, no real way to fix.
My take: I ponied up the 2000 clams for the Yamaha non-boost model. It doesn't have the flexibility as two 2000 watt Hondas that are paired, but every time I've had the Yamaha, it starts on the first pull of the recoil starter or a quick twitch of the electric starter. If you can afford it, I'd highly recommend going for a Honda or Yamaha, just because the life of the generator is long, service is easy to find, and that the power is extremely clean for a generator. The only downside is that it might have a tough time starting some 15,000 BTU A/Cs, but this can be mitigated by installing a hard-start capacitor on the A/C. It also may not "catch" the load from a 15,000 BTU A/C if the econ throttle is on, but usually after a couple hours running, that tends to go away.
As an alternative to 3000 watt models, you might consider two Honda eu2000i models paired up (preferably an EU2000i and EU2000i Companion.) You get 3500 (not 4000) watts which can handle the inrush current of almost any A/C, and you can attach an extended run tank to either or both the generators. With a decent extended run tank, you can run your generators for days on end.
mlts22 is offline   Reply With Quote
Old 01-21-2013, 09:45 PM   #3
Ronman's Avatar
WOW, 22! You have more than answered the obvious questions while shedding some humor along the way. Who needs a door stop when you are in need of a generator!
Thanks for the insight.
Ron
Old 01-21-2013, 09:54 PM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
We chose the twin Hondas.
They are easy to handle and when paired run our AC.
One is all you need for the cool months.
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-21-2013, 11:26 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The Honda and Yamaha generators are quiet and have great reputations for service. The noise level of some (maybe all) the cheaper Chinese generators is unbearable for you and all around you.
doug k
Old 01-21-2013, 11:51 PM   #6
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
We got the Honda 3000i Handi about a year before we got our AS while we were renting SOBs.... Then after we got our AS I wished we had purchased the Honda 2000i plus the Honda 2000i Companion.... Now that we are adding a 400 watt solar system I am glad we have the 3000i Handi.... Go figure....
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 01-22-2013, 12:03 AM   #7
tpi
Trabuco Canyon , California
I heard the Dometic run at Dana Point on one trip. It was clearly noisier than the Honda/Yamaha.
For me I'd avoid the Dometic nameplate in general if there are alternatives with Yamaha and Honda nameplates.
tpi is offline   Reply With Quote
Old 01-22-2013, 10:14 PM   #8
Ronman's Avatar
Very succinct, TPI! I appreciate it very much. The fact you experienced the Dometic means a lot.
Thanks again!
Ron
Old 01-23-2013, 12:12 AM   #9
2008 23' Safari FB SE
Boulder , Colorado
JD
That is my setup too. Make sure that if they are going to sit idle for longer than 3 weeks that you drain the gas and carb. The carbs can get gummy pretty quickly especially with the ethanol gas. These are great generators and very reliable but you have to maintain the carbs... (Or find non ethanol based fuel)
bonginator is offline   Reply With Quote
Old 01-23-2013, 06:44 AM   #10
r carl's Avatar
Lin , Ne
Non ethanol unleaded will varnish a carb too. Adding stablizer to the gas in the tank and draining the carb is necessary for storage.
Old 01-23-2013, 08:09 AM   #11
robert@honda's Avatar
Alpharetta , Georgia
The 2 x Honda EU2000i is a popular configuration, for a number of reasons:
Each unit weighs 49 lbs., so easy to load/move
Only one is needed for most power, unless you run A/C, then two are required
Gets excellent fuel economy, inverter technology means engine will only run as fast as needed to match the load
4,000 watts peak power can handle most RV loads
3-year warranty, thousands of Honda dealers nationwide
Not with out a few cons...
Twice the oil changes, fuel drains, etc.
Smaller fuel tanks = shorter run times than larger generators
More details here: Honda Generators: Portable Generator Power for Home, Work, and Play
I'm the Honda guy, so ask me anything about 'em.
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@honda is offline   Reply With Quote
Old 01-25-2013, 07:08 PM   #12
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Just the person , I would like to ask this question:
Why is Honda not making a 4 KW generator, since there is such an obvious need for it. I have installed and used the now no longer available RV gensets EV4010/EV6010 and loved the dependability.
1990 29' Excella Trailer
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 01-25-2013, 08:10 PM   #13
No. 13's Avatar
2012 25' FB Flying Cloud
Orange County , California
Here is a very unscientific poll for you:
In New York over the holidays I noticed every street vendor had a beat-to-crap Honda
1000 or 2000 chained to their cart.
No. 13 is offline   Reply With Quote
Old 01-28-2013, 11:35 AM   #14
mefly2's Avatar
2015 25' FB Eddie Bauer
Twin Hondas and never looked back.
Don't sweat the oil changes (~1/2 qt each) other than the potential mess. Get the extension for the filler and it makes the OC a breeze. Suggest also an hr meter for at least one of the gens as they build time very quickly.
Aux / extended run tanks are easily added as you feel the need ... they are much easier not only to fill, but also to not overfill!
