Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 04-19-2008, 07:00 PM   #1
Cracker's Avatar
Profile:  2000 30' Excella
Pittsfield , Maine
Honda Pair With 30 amp Parallel Setup
I've had a set of 2000i Hondas for several years now - along with the old style parallel hookup and 30 amp plug. I also have a small onboard 110 volt air compressor - but it requires slightly more starting amps than a single generator can provide. My question is, if I plug the air compressor into the provided standard outlet on one of the generators, with the parallel hookup in place, and both generators running, will it boost the amperage output of the standard outlet? The alternate solution would be to fabricate a pigtail with a standard female and 30 amp male to match the female outlet on the parallel box - but that's a tad costly! The reason for my question is that I know Honda sells a simple set of pigtails to parallel the generators - but without the 30 amp plug. That said, what is the function of this set of pigtails if they don't somehow boost the output of a single generator??? Yeah, yeah - I know ---I could just try it and see but I like to pretend I know what I'm talking about!
Cracker
Cracker is offline   Reply With Quote
Old 04-19-2008, 07:30 PM   #2
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula maybe Helena soon , Montana
No. If you look at the wiring diagram the circuit breaker is dirctly before the outlet.
This is what you are going to have to do. Do you have the facilities to makea pig tail yourself? Cost would be about $50 for quality parts.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 04-20-2008, 08:20 PM   #3
Cracker's Avatar
Pittsfield , Maine
Yep - that's about what I figured! I might be able to shave it a tad by using a standard duplex in a rough-in box - but it's the darn 30 amp plug that's so expensive. The other solution would be to put a 30 amp male plug on the compressor cord - since 15 amp to 30 amp converter plugs are readily available. Fact tis, I've been using one on the house duplex all winter while wating for the electrician to install a dedicated 30 amp outlet. I'm still curious what function those parallel wires serve when a 30 amp plug isn't in the circuit???
Cracker
Old 04-21-2008, 09:06 AM   #4
They just sit there. They do not get used unless the parallel kit is used.
Michelle
Sarah
Old 04-21-2008, 10:16 AM   #5
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Unless I misunderstood, it sounds like you need a 30A to 15A converter. I have one that looks just like the black plastic adaptor that lets us plug our 30A rv into a standard outlet but it goes the other way. Plug it into a 30 A outlet and it has a standard wall type pug for using normal 110v devices.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 04-21-2008, 05:34 PM   #6
Cracker's Avatar
Pittsfield , Maine
That's exactly what I need - but in all my searching around I've never come across a conversion plug that went from 30 amp to 15 amp. Where did you get it??? Make, model, etc???
Cracker
Old 04-21-2008, 10:38 PM   #7
DFord79's Avatar
Profile:  Currently Looking...
Yakima , Washington
Campingworld.com has all sorts of these adaptors. They are not hard to find. You local Honda genny store might have one? They either come in a corded lenght or just the male/female plug.
Power Generators - Electric Generator Store Also this place has everything know to man if you can't find it here you don't need it.
Generator Power Cords and Plugs - Power Generators - Electric Generator Store This link might be the exact page you need.
DFord79 is offline   Reply With Quote
Old 04-22-2008, 06:43 AM   #8
Cracker's Avatar
Pittsfield , Maine
The problem seems to be trying to adapt from a 30 amp RV plug to the 15 amp plug. There were several 4-prong, 30 amp to 15 amp adapters listed.
I'll see if Camper's World has anything shown on-line.
Cracker
Old 04-22-2008, 07:13 AM   #9
Images: 26
Humm , I dunno where I got it. Mees gussin' it was in one of the rv's/trailers I aquired over the years...If I remember I'll take a look at it this afternoon when I get home. It looks exactly like a 15/30 black rubber puck adaptor but it goes the other way.
The only times I've needed it was where the 15A outlet was bad at a campsite. The camper would hook to the 50A via a dogbone, that would free up the 30A for my extension cord.
Hi Ho Silver RV!
Old 04-23-2008, 08:48 AM   #10
Images: 26
Well I tumbled through the 'Stream last night and couldn't find hide nor hair of the plug. It must be in the SOB, I'll look this weekend if the ole brain doesn't jump a gear and forget
Hi Ho Silver RV!
Old 04-23-2008, 06:32 PM   #11
Cracker's Avatar
Pittsfield , Maine
The big RV dealer here in Bangor, Maine solved the problem. He recently tripled his store area for parts, gadgets, and gilhinkles and the 30 amp RV to 15 amp standard plug was available in several forms. The simplest was the single converter plug for $6.19 and the pigtail version was $8.69 - or thereabouts. Thanks for all of the input.
Cracker
Old 04-24-2008, 12:19 PM   #12
I wnadered into one our local Rv places yesterday for propane. They had a 30 to 15 adapter fro sale for about $10. Good luck!
Michelle
Sarah
Pingbacks are On
Reese WD & dual cam chain setup Safari64 Towing, Tow Vehicles & Hitches 21 03-19-2006 12:19 AM
Brakesmart & Hensley setup Dwight Hitches 9 02-26-2005 10:41 AM
Running Honda Generators in Parallel Cracker Generators & Solar Power 16 05-16-2004 06:49 PM
Honda parallel banana plug source gklott Generators & Solar Power 2 08-09-2003 03:42 PM
SEO by vBSEO 3.1.0
