Old 04-18-2016, 02:16 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Honda Handi3000i generator
Thinking about buying. But will it handle one of our air conditioners? We have two ACs in our 2015 FC28. Input anyone?
DeltaRon is offline   Reply With Quote
Old 04-18-2016, 02:56 PM   #2
Long Island , New York
http://www.airforums.com/forums/f448...is-129162.html
Old 04-18-2016, 02:57 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
A 3000 watt generator will be more than enough for one AC unit. If you don't travel in the "deep south" or "southwest" in the summer, a 2400 watt generator will also be fine.
Bob Martel
WBCCI# 5766
Old 04-18-2016, 03:03 PM   #4
2010 27' FB Classic
N/A , Texas
I don't know what the specs are for the Handi 3000 or your air conditioner that you want to run. So,, I'll have to just tell you that I have a Yamaha 3000 w/boost and it runs my 15,000 btu air just fine.
Check out the specs for each ( air conditioner and gen) and see if they match up.
Old 04-25-2016, 09:10 AM   #5
robert@honda's Avatar
Alpharetta , Georgia
The Honda EU3000i Handi will usually handle ONE standard 13,500 BTU rooftop A/C system just fine. Some older systems maybe not, and under extreme conditions (high elevations, above 95 degrees, etc.) maybe not. Ideally, try and test your rig with a demo unit at a Honda dealer to be sure.
The Handi will NOT run two A/C systems at the same time. No 3,000 watt generator can do this...the loads are too large, especially if you fire them up at the same time.
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@honda is offline   Reply With Quote
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Honda generator suggestions from Honda Mudflap Electrical - Systems, Generators, Batteries & Solar 16 12-17-2015 03:37 PM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
Honda EU 3000 vs 2x Honda EU 2000 vajeep Generators & Solar Power 93 07-23-2008 11:02 AM
