Old 02-27-2010, 09:00 PM   #21
fr8tshaker's Avatar
2022 16' Bambi
2022 Atlas
Sioux Falls , Arkansas
Foldable Dog Ramp
We have the Yamaha that we run on LP. It is heavy so we use a foldable dog ramp to load and unload. Makes it a one person job.
FWIW
'shaker
2006 34' Classic LTD
2010 Ford F250 PSD
Hensley Arrow Hitch
fr8tshaker is offline   Reply With Quote
Old 02-27-2010, 10:56 PM   #22
Originally Posted by TomW View Post
Heh, heh - You're baiting me, markdoane, after a previous post of mine
While you are MORE than capable of such a rigging, people with your uncanny insight tend to be older than me.
Why would you want the extra effort? Even Dumbledore can lift an EU2000.
Your buddy,
Tom
Ha! You two are practically AirForums royalty, so it's always fun to see a "Duel Arcane" between a couple of mighty powers such as yourselves...
Anyway, one nice thing about the Handi is that Harry Potter can lift it by himself and it's not like HE is anybody's Hulk Hogan...
Old 02-28-2010, 02:18 AM   #23
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Marcus is concealing his true abilities... He is a rather "Buff" dude. As a mater of fact, he and his wife spend "date night" competing in feats of strength and endurance. (evidence below)
As TomW said "A Honda 3000[anything] is still going to be heavy"
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
https://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 02-28-2010, 05:21 AM   #24
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
if you can lift a case of beer 12oz. bottles ,you can lift a Honda EU3000 i
wbcci ,#3510 NEU & 4cu https://fire1.smugmug.com
firedog is offline   Reply With Quote
Old 02-28-2010, 05:45 AM   #25
r carl's Avatar
Lin , Ne
The eu3000is size and 140# weight can easily hurt your back. Most cases its a 2 person job. Carrying 2 eu2000i gens is far easier. A plastic coated cable lock will help keep them from walking away.
Old 02-28-2010, 05:57 AM   #26
2011 30' Flying Cloud
Arvada , Colorado
We bought one recently and though we have not used it yet in traveling, here are some initial thoughts. It is light enough for me to be ableto lift into the back of our Suburban. Easy to pull start and very quiet. Disappointed that an extended fuel application has not been developed for it, other than if you are able to position the external tank to work off gravity. Something about lacking fuel pump?? My decision was based entirely on a price comparison of this unit against two 2000i's, parallel setup,etc. Jack
Jack46 is offline   Reply With Quote
Old 02-28-2010, 05:58 AM   #27
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
77.6 lbs. call it 78 lbs with gas.I am 55 years old with a bad back, and i can lift it easily,maybe at 60 years it will be to heavy.The wheels and ramp make it easier to load.
Old 02-28-2010, 06:25 AM   #28
"Cloudsplitter"
Question
134lb case 'a brew?
EU3000IS Specifications
Engine Honda GX200
Displacement 196cc
AC Output 120V 3000W max.(25A) 2800W rated (23.3A)
Receptacles 20A 125V Duplex, 30A 125V Locking Plug
DC Output 12V, 144W (12A)
Starting System Recoil, electric
Fuel Tank Capacity 3.4 gals.
Run Time per Tankful 7.2 hrs. @ rated load, 20 hrs. @ 1/4 load
Dimensions (L x W x H) 25.8" x 18.9" x 22.4"
Noise Level 58 dB @ rated load 49 dB @ 1/4 load
Dry Weight 134 lbs.
Residential Warranty 3 Years
Commercial Warranty 3 Years
Old 02-28-2010, 07:32 AM   #29
1972 23' Safari
Atlanta , Georgia
I've been using a pair of EU2000 gens hooked in parallel for a year or so now. It takes both to run the AC and microwave, but the small size if each was the big appeal to me. One is enough in seasonal weather for all other trailer electric functions. The big downside was the price, but I was willing to pay it for the uber-quiet running noise of the Honda....best in the industry
drcamo is offline   Reply With Quote
Old 02-28-2010, 07:36 AM   #30
Originally Posted by ROBERT CROSS View Post
134lb case 'a brew?
Engine Honda GX200
Displacement 196cc
Dry Weight 134 lbs.
Just to clarify, there are two Honda 3000 inverter-type generators. The 134 lb one is the "original" but that is not what the original poster asked about. The original poster asked about the "Handi" model, which is the "new" one. It only weighs ~78 lbs.
Here are the specs:
Engine Honda GX160
Displacement 163cc
AC Output 120V 3000W max.(25A) 2600W rated (21.7A)
DC Output 12V, 100W (8A)
Fuel Tank Capacity 1.56 gal.
Run Time per Tankful 3.6 hrs. @ rated load, 7.7 hrs. @ 1/4 load Dimensions (L x W x H) 24.5” x 14.9” x 19.3” Noise Level 65 dB @ rated load, 57 dB @ 1/4 load
Dry Weight 78 lbs.
This is what it looks like:
As I stated above, it has plenty of power to run your trailer. You don't need two 2000s in parallel, though that's certainly a viable option as well.
And Steve-- my wife can out-lift me on the 12 oz curls every time.
Old 02-28-2010, 07:42 AM   #31
"Cloudsplitter"
Wow...very kool unit!!!
Old 02-28-2010, 08:07 AM   #32
Yes, I think it's pretty cool too. The performance has been excellent, the only challenge I've had with it is the small fuel tank.
I did run across this article on eHow that explains how to create an auxiliary fuel tank using readily available parts. I'll probably try to do this as soon as I get some time.
How to add an aux fuel tank to a generator | eHow.com
Old 02-28-2010, 08:25 AM   #33
Orion , Illinois
Utee 94 got it right, that's the model I'm interested in. It came out late last year and it weighs a lot less than the other 3000. As far as fuel use goes it would just be a matter of an extra cap and adapting a portable boat tank to it.
63air is offline   Reply With Quote
Old 02-28-2010, 08:43 AM   #34
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Originally Posted by TBRich View Post
The pull start on a 2000 was a concern of mine, too, remembering how frustrating starting a lawnmower used to be (I suppose even they are easier these days)...but we got a 2000i with a pull-start and it is really easy to start. It usually starts on the very first pull (unless I forget to turn the switch to "on" or to choke it when it's cold)... They really are a dream to operate...and lift-able.
If I have any problems starting any of my power equipment I take the air filter out and give a short spay of starter/carb cleaner fluid. Never fails. If you do not remove the filter, the cleaner will disolve it.
I have 2 EU2000i's and a parallel "kit". I do not want to have to pay for back surgery either.
Michelle TAC MT-0
Sarah, Snowball
Old 02-28-2010, 08:51 AM   #35
_
Originally Posted by 63air View Post
Anyone out there using one of these yet ? I have not seen anyone in our area stocking them. The 73# weight seems very manageable for getting it into the back of a truck and it looks like it would run my AC ( Coleman mach II ). I'm trying to decide between this or two Honda 2000's.
we've had several recent threads on this issue and going back to the release of this newly package 3k...
http://www.airforums.com/forums/f448...tor-58042.html
http://www.airforums.com/forums/f448...end-60349.html
http://www.airforums.com/forums/f448...0is-57897.html
most of the changes in the new 3k model are DEcontenting to get it lighter.
items mentioned so far...
-LESS housing and LESS muffler which results in a unit up2 4+ times LOUDER than the original 3k or 2x2000 units.
-removal of the electric start and a MUCH smaller fuel tank.
4-5 hours between fueling is really near the NOT practical limit for many.
-and it STILL is under rated for most 13/15k btu ac according to the AC makers recommendations.
__________
for the o.p. using a coleman/mach/power saver series ac there might be BETTER options....
1. 2000 watt honday appears to be RIGHT at the requirements....
2. a yam ef2400is might be the BEST option....
MUCH larger fuel tank, less noise at peak out put and a few pounds lighter than even the handi'...
___________
i like the flexibility of carrying 1 or both of the 2k hondays and now paralleling them is so much easier (no kit needed)...
however,
i'd be inclined to give the yam a whirl in the humid summer that middle america camping brings...
and with this SMALL ac and SMALL trailer.
blue over red? this time yes!
and robertsunrus has posted LOTS of info on using his yammer...
http://www.airforums.com/forums/f37/...tor-61297.html
http://www.airforums.com/forums/f448...ers-47292.html
http://www.airforums.com/forums/f448...ors-39684.html
cheers
2air'
Old 02-28-2010, 01:32 PM   #36
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
my friends in the club, had a yamaha 2400, no good for AC,need a honda 3000.
Honda EU3000i Handi jsvetrano Electrical - Systems, Generators, Batteries & Solar 26 08-29-2015 09:50 PM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
Honda EU3000i Handi Wayne&Sam Generators & Solar Power 0 05-20-2009 09:21 AM
Honda EU 3000 vs 2x Honda EU 2000 vajeep Generators & Solar Power 93 07-23-2008 11:02 AM
