Old 08-03-2010, 07:38 PM   #15
2011 28' INTERNATIONAL
2010 28' International
Campbell , California
the short is in my RV. direct connection to non-FGCI shorepower works ok, but as soon as I use surge protector inline to shorepower, surge protector trips. From one of your eary posts(2006?), you had a similar problem with neutral and ground being connected that caused GFCI at campsites to fail. However, I have not heard from anyone on this forum that states definitively whether they are or are not supposed to connected together in AS. I have a call into AS tech support, so I should here something back any time now, but wanted to pick your brain a little first.
pip8688 is offline   Reply With Quote
Old 08-03-2010, 07:44 PM   #16
_
ok, that's clearer...
yes i reported about the neutral/ground SHORT in my unit....
http://www.airforums.com/forums/f37/...lks-21082.html
and NO it's not supposed to be that way normally.
the short in my unit was a result of an a/s service tech OVER tightening a screw in the airconditioner junction box...
before they agreed to LOOK for the problem and found it, i spent a YEAR dealing with gfci TRIPPING...
the company line was "don't use parks with gfci connections"
and that BS was dropped immediately after finding and fixing the short.
this all gets very frustrating so hang with it and don't give up.
cheers
2air'
Old 08-04-2010, 12:36 PM   #17
2air, I just got word from the dealer service tech that neutral and ground are not supposed to be bonded together just as you said. Now, I got my work cutout for me. I am going on my inaugural trip in 2 days and want this problem fixed before that. i think the short is in my 110V outlets so I need to open them up one at a time. Hopefully, it's just a loose wire somewhere.
Old 08-04-2010, 04:30 PM   #18
_
i'm no electrician...
but it's not necessary to open EVERY connection to bird dog this.
first EACH breaker can be checked for the ground fault.
then only STUFF on the OFFENDING breaker need be explored
with regard to fixtures, outlets, appliances and junctions/connections.
________
depending on WHICH BREAKER has the short, this may not take a lot of checking...
it's important to UNPLUG all 115/ac appliances BEFORE exploring too...
for example a tv, the microwave, the charger/converter or even the fridge could be the source of the ground fault.
________
ok please don't rely on my posting for guidance...
use some1 with LEGIT juice mastery for this process.
cheers
2air'
Old 08-04-2010, 07:40 PM   #19
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Originally Posted by 2airishuman View Post
....<big snip>....
and don't RUN the gensets on ECO if hooked up in parallel.
...<big snip>...
cheers
2air'
Quick question, 2Air... is this advice (in post #9) specific to this particular situation/discussion ... or a general statement when running 2 generators in parallel... just wondering...if it's the latter, what's the reason? Thx...TB
TB & Greg and Abbey Schnauzer
#3954
Old 08-04-2010, 08:03 PM   #20
_
it was specific to trouble shooting the problem
and the voltage/output CHANGING that goes with eco might add 2 the odd behavior.
______
IF 2 are needed for a/c use eco isn't a great idea either.
i seem to recall the owner's manual suggesting NOT to use eco when paralleled...
but could just be imagining that reference so check da' book or honda faqs...
cheers
2air'
Old 08-04-2010, 11:34 PM   #21
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
______
cheers
2air'
Thanks for the clarification, 2Air...appreciated... TB
#3954
Old 08-05-2010, 11:52 AM   #22
Wise Elder
Jammer's Avatar
2010 30' Classic
TBRich to find a neutral to ground short you have to physically disconnect the white wires from each circuit in turn until the fault goes away. Better to use an ohmmeter than actual shore power for this process for safety. Just tripping the breakers only disconnects the hots and won't help isolate it.
They can be a nuisance to find but if you are methodical about it you shouldn't have any trouble.
Again be sure you have all power sources disconnected and locked out before you start.
Honda vs Yamaha Generators ROBERTSUNRUS Generators & Solar Power 115 06-13-2016 09:32 AM
Best Prices on Honda Generators? gaylejoe Generators & Solar Power 51 09-05-2011 05:13 PM
Converter fan noise - parallax vs others Jammer Batteries, Univolts, Converters & Inverters 4 05-11-2010 07:59 PM
Parallax Converter Replacement with Xantrex SilverGate Batteries, Univolts, Converters & Inverters 18 10-03-2009 07:49 AM
Why are Honda Generators quiet? JimGolden Generators & Solar Power 48 02-18-2008 05:34 AM
