Old 11-14-2014, 08:32 AM   #1
2013 25' International
mont st hilaire , Quebec
Honda generator with propane conversion
Hi evryone
I`m looking to buy a generator and no place in the airstream or in my SUV to keep the gaz tank for the generator...and I dont want to smell it of course
When I make my research to find a honda dealer I find a ebay link to sale a GAS PROPANE GENERATOR CONVERSION !!!
so Im curius to know if someone already use it and any problem with ?
I know if I install it I will lost my warranty so I plan to buy a use one !!
and any think I need to know if I buy a use one ?
thank you so much .....
socool69 is offline   Reply With Quote
Old 11-14-2014, 09:35 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I converted a Honda 3000i. The kit was about $175.00 from Central Maine Diesel. They advised me that their mechanic would not convert a 3000i so I did it myself to run on 3 fuels. The 3000ie is commonly converted.
2004 Excursion 4x4
Old 11-14-2014, 10:04 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
As we are considering mounting a Honda 3000 in the truck bed, please tell us more about how you like the LP conversion. I have read some information that generators operating on LP do not do well at higher altitudes (over 5000').
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 11-14-2014, 12:11 PM   #4
1981 31' Excella II
New Market , Alabama
LP is a great way to go since you don't have the long term storage issue with Ethanol fuel being left in the unit and then to find out it won't run because the carb has corroded.
Perry
Old 11-14-2014, 12:16 PM   #5
Im looking a 2000i only or may be a 1000i
dont know if my microwave will work in a 1000i ?
I never read anything about altitudee overs 5000'
where do you read this ?
Old 11-14-2014, 12:26 PM   #6
moosetags's Avatar
If you Google 'generator operation at high altitude' there a number of articles on the subject. One of them states that a generator's power output is reduced by 14% at 4,500 feet above sea level.
Brian
Old 11-14-2014, 12:30 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My microwave just barely works on the 2000. I do not think the 1000 will handle it. The 1000 actually makes 800 watts. That is somewhere around 7-8 amps. The converter draws a good bit of that.
Old 11-14-2014, 12:38 PM   #8
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Generator at high altitude
We live at 5,100 feet. We bought a Honda 1000 watt generator. It was a regular gasoline model. It was hard to start, but it ran OK once it got going. Honda sells alternative jets for high-altitude operation. My wife bought one and installed it; the generator starts and runs better now.
We have not converted the generator to propane (and we have never used it to power the trailer; we have lots of solar on the trailer).
SSquared is offline   Reply With Quote
Old 11-14-2014, 01:01 PM   #9
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
I have used my two propane powered 2000I up to 7000 ft with no problem never changed the jets. They are for sale, PM me.
jkcru is offline   Reply With Quote
Old 11-15-2014, 12:55 PM   #10
1966 20' Globetrotter
Globe , Arizona
Altitude and internal combustion engines
All non turbo charged internal combustion engines produce less power at altitude. This is true even if the jets are changed.
The problem at altitude is that you have less oxygen so burn less fuel in the combustion chamber. The different jets reduce the amount of fuel in the charge so that you operate more efficiently.
In some piston powered aircraft we have turbochargers to maintain sea level power at altitude but I have not seen this on a generator. Depending on turbocharger design this can also be true of some turbocharged trucks.
Mike
Mike_cfi is offline   Reply With Quote
Old 11-16-2014, 07:59 AM   #11
wow make logic
thnk you
Old 11-16-2014, 08:43 AM   #12
I carry a gas Honda generator in the back of my Suv. When the vent on the gas cap is sealed, the Honda emits no odors. I carried my gas in a plastic jug for a while but was bothered by odors. I purchased a premium Eagle gas can for about $35 and there aren't any odors and it doesn't spill fuel when I fill up the generator. There are threads in this forum about other premium gas cans which some say are better than the Eagles.
I realize that even a premium gas can and perhaps the generator itself might spill fuel in the event of a rollover or serious accident. A propane bottle is less likely to leak.
handn is offline   Reply With Quote
Old 11-16-2014, 09:08 AM   #13
Tincampers's Avatar
Sneedville , Tennessee
That's a major factor in a propane conversion. No extra propane tank to carry around with you. Use the ones on the trailer.
Tincampers is offline   Reply With Quote
Old 11-16-2014, 09:16 AM   #14
HowieE's Avatar
Images: 12
On a converted engine altitude should not be a problem. The screw on the right side of the fitting coming off the regulator diaphragm is easily adjusted. I have one setting for propane and one setting for natural gas depending on camping or home.
Once you know the setting for the various altitudes it would just take a second.
2004 Excursion 4x4
Old 11-16-2014, 10:06 AM   #15
that what I want no extra to carrie and no odor
I think the convestion will be my best buy
Old 11-16-2014, 02:14 PM   #16
2003 25' Safari
spokane , Washington
honda ei3000i conversion
I have used mine for nine years. No problems in the cold or at altitude (never needed AC at 9000', rand microwave just fine), just adjust the screw on side of "carb".
wasafari is offline   Reply With Quote
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 04:04 PM
GenConneX Propane Conversion for Honda EU2000i Airrogant Generators & Solar Power 56 08-26-2016 09:36 AM
Honda Propane Portable Generator Akronguy Generators & Solar Power 8 11-14-2014 06:58 PM
Honda EU3000is conversion to propane pickerdd Generators & Solar Power 2 10-02-2011 04:41 PM
