Honda Generator Ramp Up
My twin 2000i Honda generators have always started the AS AC with no problem running in parallel.
Now, one of them consistently overloads and the AC fails to start.
Both generators will individually power the AS electrical system through the parallel kit. So, I assume they are also running in parallel when both on.
My suspicion is that one of the generators is not "ramping up" under load. Is that possible?
Alternatively, it was 90+ degrees here yesterday. Could the compressor on the 5 y/o Dometic Penguin 13.5K AC be getting older, and, thus needing more juice to crank?
Thanks, Tom W
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
