Old 08-21-2006, 07:12 AM   #1
Honda Generator - Carry in Van
I have a Honda Generator EU2000i (2000 watts)with a shut off on the gas cap. I plan to carry it in the back of my large van. I do not plan to carry a gasoline can. Please advise. Thanks, LCP
1992 25' Airstream Classic/Excella Trailer
Wilmington, DE
PARKS1963 is offline   Reply With Quote
Old 08-21-2006, 07:40 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
We carry ours in the back of a Suburban. As long as you close the vent on the gas cap, it should be fine. We do not notice any gasoline odor. Your run time will vary with load requirements.
Uwe
www.area63productions.com
Old 08-21-2006, 08:50 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Eu-1000
Phew, no one wants their vehicle to smell like gasoline. Propane certainly isn't odorless either. One thing you could do would be carry the generator empty, fill it using a siphon from your tow vehicle's gas tank, run it dry or re-siphon back into your vehicle, then throw away the siphon.
You can buy clear flexible tubing from Home Depot or one of the other big box stores for chump change. If you want, rather than reusing it, you could toss it in the trash. Of course it WOULD burn nicely in a campfire, but the plastic could be toxic if burned. You could also siphon some soapy dishwater through it, let it drain dry and reuse.
Paula
Old 08-21-2006, 09:43 AM   #4
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
easy...
we carry ours in the back of our van too. I just cover it with a plastic bag, I really don't notice any smell either.
Marc
Old 08-21-2006, 09:49 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
If your gasoline supply is to be siphoned from your tow vehicle's gas tank, try it at home first. Some newer vehicles come with an anti-siphon baffle to prevent theft. If you do use the siphon method, you can store your hose exposed on you battery box where it will gwt plenty of ventilation and won't stink up anything.
SuEllyn & Brian McCabe
Old 08-21-2006, 07:00 PM   #6
Frank S
peoria , Illinois
Hi Foiled Again--I tried to siphon gas from the tank of my 2001 1/2 ton Suburban. Couldn't get the hose very far into the filler neck. Couldn't reach gas. Guess it has anti-siphin baffles like moosetags said.--Frank S
Frank S is offline   Reply With Quote
Old 08-21-2006, 07:40 PM   #7
nilesrob's Avatar
Marietta , Georgia
Images: 12
We also have the same generator (Honda eu2000i). That bad boy is heavy. In order to avoid moving it around too much, and to avoid carrying it in our Excursion, I had a receiver installed on the front of our Excursion. I then install a rack in the receiver and place the generator on the rack.
When we get to where we are going, I never move the generator. I just run an extension cord long enough to run from the electrical on the AS to the generator on the front of the Excursion.
Saves my back, avoids gasoline smell (and risk) in the Excursion, and reduces the potential for a 150 pound generator from being tossed around in our TV in the event of an accident.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 08-21-2006, 07:47 PM   #8
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Ahem, are we talking about the same Generator?
An EU2000i weighs 46lbs. according to Honda. Add a few ounces of gas, and you're at 50lbs, perhaps.
http://www.hondapowerequipment.com/M...elName=eu2000i
Uwe
Old 08-21-2006, 07:51 PM   #9
1960 24' Tradewind
santa barbara , California
parks1963 ,I have carried my eu2000 with the vent cap shut ,inside the travelall on my trips .Never had any fuel smell.Remember these units cannot
emit vapors anyway by law these days ,and if you run the gen with the cap vent shut ,it will run out of fuel and die.They seal very well .I don't think you have a problem with it in the vehical .
Scott
scottanlily is offline   Reply With Quote
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 5 04-09-2010 05:09 PM
towing and the Banks Power Pack kooblekidz Airstream Motorhome Forums 11 10-31-2002 12:09 AM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
1981 Airstream Executive Van PeterH-Airstreamer Airstream Motorhome Forums 1 07-03-2002 10:00 PM
