Old 09-25-2012, 05:53 PM   #1
Hiwheel Joe's Avatar
1984 27' Sovereign
Oklahoma City , Oklahoma
Honda Gen Problem
Not saying it is the generator, but curious if others have had this problem and how it may have been corrected. Need some guidance on what to look at.
We have the Honda EU 2000 and the Companion EU 2000 paralleled together. When the trailer is plugged in as required, running the Air conditioner seems to be causing an issue. This is the first time we have used both generators together. Used only one during the winter trips last year trouble free.
While the AC is on, 13500 Coleman, the generators RPMs will rev way up and at the same time, the AC fan almost comes to a complete stop until the generator RPMs drop. Maybe this is when the compressor is trying to kick on?? I can run the AC fan all day long without problem. After several of these the generator circuit overload light will come on and kill the AC power.
All I have read leads me to believe that this set up should at least run the AC and television at least. Have tried it without the TV on and get the same results?? Have tried it with eco setting on and off. One guy suggested it is a converter problem, one says the AC.
I am having the generators checked for proper operation first.
We ran the AC on shore power the weekend before without problems.
Anybody have any ideas as to where to go with this problem?
Hiwheel Joe is offline   Reply With Quote
Old 09-25-2012, 06:00 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Turn the ECO switch OFF on both generators.
Old 09-25-2012, 06:07 PM   #3
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
I can run my 15k Dometic with my EU2000i and Companion paralleled, but both eco mode switches must be off before starting the AC. If the Eco mode is on the generators will not rev up fast enough and the overload light comes on. Assume you are plugged in to the twist lock 26.6A outlet on the Companion and not the 15A regular outlet?
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 09-25-2012, 06:13 PM   #4
1984 27' Sovereign
The title is a bit wrong, maybe I should have called it problem while running Honda
Gen. I do love my Honda Generator set. Nice and quite.. except when the problem occurs. Even then it is quieter than most.
Old 09-25-2012, 06:16 PM   #5
1984 27' Sovereign
Yes, plugged in to the twist lock 26.6A. Have tried with the ecos off, with the same results.
Old 09-25-2012, 06:23 PM   #6
Well Preserved
1993 21' Sovereign
If you are running the generators with the ECO switches OFF, check the hard start capacitor for the compressor.
Old 09-25-2012, 08:11 PM   #7
1988 32' Excella
Robbinsville , New Jersey
You could try asking someone else to try their AC on your generators.
Old 09-25-2012, 09:40 PM   #8
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Ran my 15k BTU unit on Sunday with no problem with Eco throttle switches on. They were running at barely above the low speed/idle. By the way, one of them will start and run the AC but it is at full load then. I tried it just out of curiosity.
As suggested, you may want to check out the capacitor in the AC unit.
Alphonse is offline   Reply With Quote
Old 09-26-2012, 06:09 AM   #9
robert@honda's Avatar
Alpharetta , Georgia
You may wish to contact a local Honda dealer and arrange for them to be inspected and tested. Most Honda dealer have load bank test rig, that's used to load and measure the output of a generator. They can used the load bank to confirm both EU2000i units are functioning correctly.
You can find a Honda dealer in your area using this link:
Find a Honda Dealer
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@honda is offline   Reply With Quote
Old 09-26-2012, 08:11 PM   #10
1984 27' Sovereign
Hondas are at dealer being load banked right now. I will try another trailer when I get them back. If that works out then I will check the capacitor.
That's what I love about this forum. Lots of ideas I would never have thought of. I will post again when I find the solution. I appreciate ALL of the advice and avenues to try out. Thanks to all.
Joe
Old 10-01-2012, 07:26 AM   #11
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Originally Posted by Hiwheel Joe View Post
<snip>
I had a similar problem with the AC in my '71 Safari tripping the overload circuit in my Honda EU3000is Generator. Initially, I thought my generator was faulty, but after a bit of investigation it turned out the hard start capacitor in my AC was faulty. After I replaced the hard start capacitor the generator fired up the AC correctly and was not overloaded in the process. I also replaced the run capacitor in the AC after I verified the hard start cap replacement fixed the issue. That seemed to also help the AC.
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 10-01-2012, 08:54 PM   #12
mefly2's Avatar
2015 25' FB Eddie Bauer
Our EU200s will not start the AC in Eco-mode ...
Old 10-01-2012, 09:20 PM   #13
nautiqueman's Avatar
2009 34' Classic
Birmingham , Alabama
Highweel, I had the same problem with my friends new Hondas running parallel. I will try them without echoboost on and see what happens. They ran all night with no problem, then I tried the echoboost and the coffee pot and my Bose surround sound system and one of the generators shut off and the ac would not run. I cut the generators off and reset the AC and still had some problems, but didnt have time to completely check everything back out. Let me know what you discover.
nautiqueman is offline   Reply With Quote
Old 10-01-2012, 09:21 PM   #14
2009 34' Classic
Also, will this activity tear up anything?
