Old 10-03-2012, 07:01 AM   #15
robert@honda's Avatar
Alpharetta , Georgia
Originally Posted by nautiqueman View Post
Also, will this activity tear up anything?
The Honda generators have multiple protective features, including a thermal-based circuit protector, circuit breaker, low-oil shutdown, etc. They are all designed to prevent damage, so it's okay to try different configurations (Eco-Throttle ON/OFF) to see what works best for your set-up.
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
robert@honda is offline   Reply With Quote
Old 10-15-2012, 06:34 PM   #16
Hiwheel Joe's Avatar
1984 27' Sovereign
Oklahoma City , Oklahoma
Quick update. I had them load bank tested at the dealer and the generators are fine. Still have the same problem with my trailer. I am more suspecting it is the A/C. Been gone on the road for a couple of weeks and have not had time to check further. This morning the A/C fan locked up while running only the fan on shore power so, here we go again. I will post when I check them on another trailer and let you know what I find out.
Hiwheel Joe is offline   Reply With Quote
Old 10-15-2012, 08:37 PM   #17
1988 32' Excella
Robbinsville , New Jersey
Hate to say it but sounds like you found the problem. That fan would be drawing extra power for a while before it locked up. Unfortunately that fan cost close to half the price of a new AC when I checked on 1 for mine (that did not include labor). If you get a new AC get a high efficiency one, using close to 4 amps less helps a lot when running on a generator.
Old 01-15-2013, 02:19 PM   #18
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Originally Posted by Hiwheel Joe View Post
Hondas are at dealer being load banked right now. I will try another trailer when I get them back. If that works out then I will check the capacitor.
That's what I love about this forum. Lots of ideas I would never have thought of. I will post again when I find the solution. I appreciate ALL of the advice and avenues to try out. Thanks to all.
Joe
Joe, did you ever get this sorted out? Curious as to the outcome.
Alan
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 01-16-2013, 05:23 PM   #19
1984 27' Sovereign
No, I have not. Shortly after this problem, the motor went out on the AC. Locked completely up. Have the new one, but just have not had the time to get it in yet. That may have been causing my problem?? Have not needed the AC lately, with it being 20-30 degree range. As soon as I do and it is warm enough to test it, I will gladly post the results. Thanks for asking.
Old 01-16-2013, 05:24 PM   #20
1984 27' Sovereign
.... and yes I did try it on another trailer and it seemed to work OK on it. So..... we shall see.
Old 01-17-2013, 05:20 AM   #21
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Sure could - if it was drawing too much power trying to turn, just before it seized.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-17-2013, 06:48 AM   #22
Alphonse's Avatar
Lower Alabama , USA
Thanks for the insights Robert - good to know.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 01-21-2013, 08:37 PM   #23
I don't know if you have one, but I highly recommend a hard-start capacitor for the A/C, like the ones made by SUPCO. These help greatly with dealing with the initial inrush current from the compressor.
Of course, even with the hard-start cap, eco throttle can cause the generator fail to "catch" the incoming locked-rotor amps and overload.
mlts22 is offline   Reply With Quote
